POV-Ray : Newsgroups : povray.unofficial.patches : Inverse Transformations patch Server Time
25 Mar 2026 06:45:28 EDT (-0400)
  Inverse Transformations patch (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Inverse Transformations patch
Date: 25 Apr 2000 10:23:59
Message: <3905aa7f@news.povray.org>
There's another problem. What about this:
box
{ <1,2,3>, <4,5,6>
  rotate x*30
  texture { Whatever }
  rotate y*45
  What will be the transformation got out of that?
  Btw: I have one idea (which has only little to do with this transformations
thing):
  In latex you can attach a label to most items, for example:
\section{Why povray is the best?} \label{First section}
  Then you can refer to that section by writing for example:
For more information, see section \ref{First section}.
  This will substitute the \ref-statement with the appropriate section number
(which may change when adding more section before that one).
  In povray this kind of labeling would just be a shortcut for first
#declaring the thing and then creating an instance of it. It would just
do both things at once.
  Then perhaps you could do something like (not necessarily with this syntax):
box \label{MyBox}
{ <1,2,3>, <4,5,6>
  transform \label{MyBoxTrans}
  { rotate x*30
object { MyBox transform { MyBoxTrans inverse } }
  This would create two boxes. The first with transformations and the second
without.
Date: 25 Apr 2000 12:03:49
Message: <chrishuff_99-2E8B51.11064625042000@news.povray.org>
In article <3905aa7f@news.povray.org>, Warp <war### [at] tagpovrayorg>
> box
> { <1,2,3>, <4,5,6>
>   rotate x*30
>   rotate y*45
transform {rotate x*30 rotate y*45}
There is only one transform struct per object, all transforms are added
into it. The transform struct contains two matrices, this is what made
implementing "inverse" so easy.
>   syntax):
> box \label{MyBox}
> { <1,2,3>, <4,5,6>
>   { rotate x*30
> second without.
Maybe an "identifier" keyword could be added to everything that can be
defined, something like this:
object {...
    identifier local LocalObject
    texture {...
        identifier global GlobalTex
While I think all #declare and #local statements should at least allow a
semicolon ending, I don't think one should be used here. It would be
inconsistent with the other flags/settings.
While something like this might be handy, I don't think it is really
necessary.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 25 Apr 2000 18:10:40
Message: <390617e0@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote...
>   I think that this patch is not of very much use if we can't get the
> transformations from an object. You seldom define the transformations of
> an object separately.
But if you really cared about the transformations and needed to use them
(and/or their inverse) somewhere, it would be very easy to declare the
transformations separately.  This feature, though useful, is not necessary
for the functionality of Chris' patch.
-Nathan
Date: 25 Apr 2000 18:16:52
Message: <39061954@news.povray.org>
syntax):
> box \label{MyBox}
> { <1,2,3>, <4,5,6>
>   { rotate x*30
There are problems with this approach (by which I mean using labeling to
#declare and create an instance).  The problems are these:
1) memory consumption.  If you #declare and then make an instance, you have
two copies of the object in memory.  One copy is created in the symbol table
when you #declare it.  The second copy is created when you make an instance
of the object.  The first copy remains in the symbol table in case you want
to make another instance.  If you did this with too many objects (or just a
few large objects) in a scene, it would be very bad.
2) ambiguity.  Because there are two copies of object "MyBox", if you tried
to access an attribute of MyBox, which would it access -- the copy in the
symbol table or the copy in the scene.  That one might be a bit too easy to
answer, so what if you were able to modify "MyBox", such as adding a new
transform or texture -- then which copy would be modified, and how would it
affect past and future instances?
These issues could be resolved, but it would not at all be easy to do so
with the current POV code.  I ran into these same problems when dealing with
labels for persistent scenes for animations.
-Nathan
Date: 26 Apr 2000 05:15:54
Message: <3906b3c9@news.povray.org>
Suppose that I have this:
#declare MyObject=
  box
  { 0, 1
    rotate x*30
    scale <1,.5,1> translate x*10 rotate y*60
  How should I declare the transformations so that I could apply them to
MyObject as above and the use the sum of all those transformations (for
example inverted)?
Date: 26 Apr 2000 07:53:00
Message: <qqm8zy1xen9.fsf@ramsen.fmi.uni-konstanz.de>
Warp <war### [at] tagpovrayorg> writes:
>   How about a function to get the transformations applied to an object?
> Something like:
> #declare Trans = transformations(MyObject)
> object
> { MyObject
>   transform { Trans inverse }
>   This would create an instance of MyObject without transformations.
>   Of course there's a problem: What if MyObject is a CSG with nested
> transformations?
A further problem is that this doesn't work with the recent patche of
"plane" and "triangle". As far as I know, the transformations are omitted
by the patch to increase the rendering speed.
http://thomas.willhalm.de/ (includes pgp key)
Date: 26 Apr 2000 08:29:18
Message: <chrishuff_99-1BF663.07321726042000@news.povray.org>
In article <3906b3c9@news.povray.org>, Warp <war### [at] tagpovrayorg>
> #declare MyObject=
>   box
>   { 0, 1
>     rotate x*30
> example inverted)?
#declare TransA = transform {rotate x*30}
#declare TransB = transform {scale <1,.5,1> translate x*10 rotate y*60}
#declare InvTrans =
transform {
    transform {TransA}
    transform {TransB}
    inverse
#declare MyObject=
box { 0, 1
    transform {TransA}
    transform {TransB}
Using the additional syntax of my patch, of course.
Date: 27 Apr 2000 17:12:04
Message: <slrn8ghbv7.5ud.ron.parker@linux.parkerr.fwi.com>
>> box
>> { <1,2,3>, <4,5,6>
>>   rotate x*30
>>   rotate y*45
Trick question: what's the transform matrix for the sphere in
sphere {
  0, 2
  translate <1,0,1>
  scale 2
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
These are my opinions.  I do NOT speak for the POV-Team.
Date: 27 Apr 2000 19:32:55
Message: <chrishuff_99-85B210.18355827042000@news.povray.org>
In article <slr### [at] linuxparkerrfwicom>,
> sphere {
>   0, 2
>   translate <1,0,1>
>   scale 2
NULL
The translate value is added to the position in this case, and the
transform structure isn't even created, so the matrix doesn't exist.
Right?
Date: 27 Apr 2000 19:42:19
Message: <chrishuff_99-377FE4.18452227042000@news.povray.org>
In article <39061954@news.povray.org>, "Nathan Kopp" <Nat### [at] Koppcom>
> you have two copies of the object in memory.  One copy is created in
> the symbol table when you #declare it.  The second copy is created
> when you make an instance of the object.  The first copy remains in
> the symbol table in case you want to make another instance.  If you
> did this with too many objects (or just a few large objects) in a
I don't see this as being a huge problem...you would get the same by
#declaring the object, wouldn't you?
> tried to access an attribute of MyBox, which would it access -- the
> copy in the symbol table or the copy in the scene.  That one might be
> a bit too easy to answer, so what if you were able to modify "MyBox",
> such as adding a new transform or texture -- then which copy would be
> modified, and how would it affect past and future instances?
This is a bigger problem. I would say the variable is separate from the
object in the scene, so you would always manipulate the one in the
symbol table. Otherwise, you would sometimes be manipulating one of the
in-scene copies(of which there could be many), and sometimes the one in
the symbol table(when there aren't any in the scene). Future instances
would reflect changes made.
> so with the current POV code.  I ran into these same problems when
> dealing with labels for persistent scenes for animations.
They would definitely be hard to fix...hopefully, during the C++
rewrite, these things could at least be planned for.
