POV-Ray : Newsgroups : povray.unofficial.patches : Hgpovray38, current state Server Time
26 Jun 2026 17:35:32 EDT (-0400)
  Hgpovray38, current state (Message 29 to 38 of 48)
Subject: Re: Hgpovray38, current state
Date: 4 Oct 2020 10:50:00
Message: <web.5f79e00ab933d8376adeaecb0@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> My upfront guess is the windows libraries directory is out of date for
> the environment in which you are compiling. Give -std=c++11 a try. If
> you're lucky, let us know.
> Bill P.
Indeed, instead of what was in my last message, I just replaced the content of
boost immediate sub-directories with what was in the similarly named directories
of a fresh boost download... That got rid of this error! (I wonder if my two
previous modifications (posix ssize_t specific import and typedef, and cam
tokenizer pointer are still needed. I will assume they were and go on after
switching back to iso c++14 language version) I am left with another error line
506 in pvengine.cpp,
at the end of SCROLLKEYS key2scroll []:
constant expression evaluates to -1 which cannot be narrowed to type 'WORD' (aka
'unsigned short') [-Wc++11-narrowing] GUI
C:\HG-povray\povray-hgpovray38\windows\pvengine.cpp 506
I also have the exact same error for what appears (to my Python-only eye) to be
a negative index, line 223 in pvmisc.cpp
I don't know by what to replace them ?
Date: 23 Oct 2020 10:15:01
Message: <web.5f92e466b933d8376adeaecb0@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> For the people who do not want to bother with git, Hgpovray is now
> available as sources
> https://github.com/LeForgeron/povray/releases/tag/v3.8.0.alpha%2BHg.226-Thermidor-30
> More works on the agenda :
> http://wiki.povray.org/content/User:Le_Forgeron/HgPovray38
Hello, ...With the set of default scenes, the advanced/abyss.pov shows a black
background behind submarine instead of blue with current 3.8 plain pov master.
Date: 24 Oct 2020 11:59:23
Message: <5f944f5b$1@news.povray.org>
Can you identify the version of hgpovray38 ?
Date: 24 Oct 2020 12:11:10
Message: <5f94521e$1@news.povray.org>
Oups, my bad. 226 Thermidor is 2 years old.
I will check with the latest head.
Date: 24 Oct 2020 12:26:56
Message: <5f9455d0$1@news.povray.org>
Ok, happens also with latest head. I will have to search when it
started, not fun as I did not play with media.
Date: 24 Oct 2020 18:00:00
Message: <web.5f94a2aab933d8376adeaecb0@news.povray.org>
maybe color models are to be suspected as so many  relatively recent changes
happened ?
(rgb > srgb rgbf rgbt RAL...)
Date: 24 Oct 2020 21:40:01
Message: <web.5f94d666b933d8371f9dae300@news.povray.org>
> happened ?
Works ok in (qtpovray)3.8, using #version 3.6 and #version 3.8
Line 786 has a negative light source, so maybe scroll down to that section and
start commenting out some lights and see what happens.
after that is // submarine and media
light in lines Line 73 & 74 has media_interaction off
Other than that - no idea.
Date: 25 Oct 2020 05:33:26
Message: <5f954666$1@news.povray.org>
>> happened ?
Negative light are honored, not the problem.
Commenting the media in the last union, get the same bad result as
hgpovray38 with povray master 3.8;
Date: 25 Oct 2020 05:57:40
Message: <5f954c14$1@news.povray.org>
>>> happened ?
Ok, I can fix it... but I do not understand yet why it happened and how
it works.
diff --git a/source/core/render/tracepixel.cpp
b/source/core/render/tracepixel.cpp
index 6d661b07..50d420a1 100644
--- a/source/core/render/tracepixel.cpp
+++ b/source/core/render/tracepixel.cpp
@@ -235,7 +235,7 @@ void TracePixelCameraData::SetupCamera(const Camera&
cam)
     bool normalise = false;
     camera = cam;
     useFocalBlur = false;
-    //precomputeContainingInteriors = true;
+    precomputeContainingInteriors = true;
     cameraDirection = camera.Direction;
     cameraRight = camera.Right;
     cameraUp =  camera.Up;
Date: 25 Oct 2020 08:04:34
Message: <5f9569d2$1@news.povray.org>
I'd not have looked if not for the claim of the same bad results in
povray master 3.8, but I branched off the last commit to master and I do
not see that line in tracepixel.cpp commented. (I've not run the test case)
If any help, I went on to look at the state of tracepixel.cpp for every
commit since the move the github. I see twelve up to v3.8 master head
and none have the precompute... line commented.
> it works.
> cam)
>       camera = cam;
