POV-Ray : Newsgroups : povray.unofficial.patches : UberPOV v1.37.0.0-beta.6 released Server Time
30 Apr 2024 07:30:16 EDT (-0400)
  UberPOV v1.37.0.0-beta.6 released (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: UberPOV v1.37.0.0-beta.6 released
Date: 11 Aug 2014 06:24:23
Message: <53e899d7@news.povray.org>
> Now with those fancy finish features recently shown off in
> povray.binary.images.
> Also does stochastic global illumination now.
I found under some conditions you get a visible pattern to the noise
when doing a low quality "preview" render with no_cache. It's almost as
if the random number generator is seeded off the pixel coordinate or
something? Is this possible or am I seeing patterns where none exist?
Date: 12 Aug 2014 14:17:26
Message: <53ea5a36@news.povray.org>
A simple way to check that: Launch a 2 or 3 frames animation with no
changes between the frames.
If there is a repeatable pattern, the images will show the same pattern.
If the pattern is just random noise, it will change from frame to frame.
Date: 13 Aug 2014 02:57:04
Message: <53eb0c40$1@news.povray.org>
OK it's the same every frame, I'll post an image in p.b.i.
Date: 27 Aug 2014 02:57:29
Message: <53fd8159$1@news.povray.org>
Actually I just realised this has an implication, that you can't render
N times on one machine (or I assume on N machines) and then average the
result. Should there be a way to set the RNG seed that is used for
choosing the direction to shoot rays?
Date: 27 Aug 2014 11:29:22
Message: <53fdf952$1@news.povray.org>
Am 27.08.2014 08:57, schrieb scott:
By default UberPOV will seed each thread's stochastic RNG with the
current time plus thread number, but I guess I should change this so
that a render started 1 second later doesn't give you the same seeds for
threads 1..N as the previous one for threads 0..(N-1), and I should also
look into why this doesn't seem to work for animations.
That aside, you can always specify a custom seed (or, more precisely,
seed base, as UberPOV will still add the thread number to it) using the
"+SSn" or "Stochastic_Seed=n" option.
Date: 28 Aug 2014 05:12:34
Message: <53fef282$1@news.povray.org>
Hmmm, something strange is going on, when I look at the difference
between the exact same scene rendered a few minutes apart there are
about 10% of blocks that are totally identical, the rest are random
noise. See image I just posted to p.b.i.
It doesn't recognise the +SS option here (beta 7 release).
Date: 28 Aug 2014 05:19:39
Message: <53fef42b$1@news.povray.org>
If I reduce the thread count to 1 then it's only the first top-left
block that is identical - the rest of the image is random.
Date: 28 Aug 2014 12:34:35
Message: <53ff5a1b$1@news.povray.org>
Am 28.08.2014 11:12, schrieb scott:
Dang. Forget everything I've said; I just notice that I haven't built
any Windows beta yet that includes those changes; in beta 7, the RNG is
indeed seeded with a default value. Help is on the way, expect a new
beta release later tonight.
Date: 28 Aug 2014 20:04:51
Message: <53ffc3a3@news.povray.org>
Am 28.08.2014 18:34, schrieb clipka:
Done.
Date: 29 Aug 2014 02:55:13
Message: <540023d1$1@news.povray.org>
> Done.
Excellent thanks :-)
