POV-Ray : Newsgroups : povray.unofficial.patches : I don't understand the slope pattern Server Time
5 Jul 2026 13:25:07 EDT (-0400)
  I don't understand the slope pattern (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: I don't understand the slope pattern
Date: 1 May 2001 07:53:34
Message: <3aeea3be@news.povray.org>
Tom Melly <tom### [at] tomandlucouk> wrote:
: Perhaps his texture is distorted when scaled.
  Well, he can do this:
heighfield
{ whatever
  scale <10, 1, 20>
  texture { whatever }
  scale <1, 2, 1>
#local D=array[6]{11117333955,7382340,3358,3900569407,970,4254934330}
#local I=0;#macro M()<mod(D[I],13)-6,mod(div(D[I],13),8)-3,10>#end
#while(I<6)cylinder{M()#local D[I]=div(D[I],104);M().1
pigment{rgb M()}}#local I=(D[I]>99?I:I+1);#end              /*- Warp -*/
Date: 1 May 2001 08:25:47
Message: <3aeeab4b$1@news.povray.org>
news:3aeea3be@news.povray.org...
> heighfield
> { whatever
>   scale <10, 1, 20>
>   scale <1, 2, 1>
Shouldn't that be:
 heighfield
 { whatever
   texture { whatever scale <1, 1/2, 1>}
   scale <1, 2, 1>
Date: 1 May 2001 09:09:56
Message: <chrishuff-1590B8.08072801052001@news.povray.org>
In article <3aeeab4b$1@news.povray.org>, "Tom Melly"
> Shouldn't that be:
>  heighfield
>  { whatever
>    scale <1, 2, 1>
#declare HFTrans = transform {...}
heighfield { whatever
    texture {whatever transform {HFTrans inverse}}
Christopher James Huff
Date: 1 May 2001 11:22:28
Message: <3aeed4b4@news.povray.org>
"Tony[B]" wrote:
> Can someone please explain this to me in simpler
> terms than those used in the MegaPOV docs? I've
> been struggling to get this thing to work on
> heightfields higher than 1 unit (in my case a
> heightfield 3.28 units high, which will be
> changed later). Specifically the one with syntax:
> slope, <x,y,z>,<x,y,z>,<u,v>,<u,v>. An example is
> greatly appreciated. TIA
          A       B      C     D
You have four vectors. Let's call them vector A, B, C and D. A and B are 3D
vectors. C and D look like 2D vectors in their syntax, but in fact they have
nothing to do with vectors.
A is a 3D vector controlling the which direction the slope pattern is based
on. As I'm sure you understand that one, I won't go into details.
C is used to give you better control over A. If you're using a heightfield
and A is set to be y you are not having any surfaces that are anti-parallel
to A (-y). Actually, even the most steep surfaces of the HF would be
perpendicular to the slope vector at most. That means the pattern only will
return values from 0.5 (perpendicular) to 1.0 (parallel). The part of your
color_map that uses values from 0.0 to 0.5 is sort of wasted, since it's
never used.
You can use C to specify that only a certain range of slopes are used. The u
part in C sets the lo-slope and the v part sets the hi-slope. For example,
if you set C to be <0.5,1.0> it means that the pattern value goes from 0
when the slope is perpendicular to A, to 1 when the slope is parallel to A.
That means that your entire color_map is used, even though only a certain
Let me know if it's clear so far!
To be continued...
In the next message I'll try to explain how to use the slope pattern with
heightfields higher than 1 unit! But maybe someone will beat me to it...
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated March 29)
/ Also visit http://www.povrayusers.org
Date: 1 May 2001 11:51:38
Message: <3AEEDBAE.C1F5024D@gmx.de>
>           A       B      C     D
That looks really good and understandable, just add some illustrating
pictures (and of course something on B and D) and you have an excellent
slope pattern tutorial.
Date: 1 May 2001 13:35:54
Message: <3aeef3fa@news.povray.org>
Thanks a lot Rune! If you can finish this maybe you can send it to the right
people to include it in the mythical 3.5... :)
Date: 1 May 2001 17:15:48
Message: <3aef2784@news.povray.org>
"Tony[B]" wrote:
> Thanks a lot Rune!
> right people to include it in the mythical 3.5... :)
It took me only about 10 minutes to write, so I'm rather surprised you find
it that good... :)
Anyway, here's the next chapter.
slope <x,y,z>, <x,y,z>, <u,v>, <u,v>
         A        B       C      D
B is a 3D vector controlling the direction of a special gradient. You know
the pattern gradient y will increase the pattern values along the y axis.
Well, the B vector in the slope pattern will increase the pattern values
along the B vector. The B vector can be any vector.
C was used to specify which range of values should be used for A. Similar, D
is used to specify the range of values for B. The u part of the D is the
lo-altitude and the v part is the hi-altitude. Let's say you set B to y, so
the pattern value increases along the y axis. Say you have a heightfield
that is one unit high so the bottom is at y=0 and the top is at y=1. In that
case you should set D to be <0,1>. But if your heightfield is bigger so it
for example goes from y=-1.1 to y=3.5, then you should set D to <-1.1, 3.5>.
So far we have looked at how A+C work (the slope) and at how B+D work (the
altitude). But how does it all work together? Well, the pattern value for a
given point is a weighted average of the slope and the altitude. The weights
are the lengths of the vectors A and B. If vector A is much longer than
vector B it means that the slope has greater effect on the results than the
altitude. If on the other hand vector B is longer, it means that the
altitude has more effect on the result.
That's all for now. Hope that was clear too. I intent to write more and to
improve what I've already written, but that'll require quite a bit more of
time and planning.
Rune
Date: 2 May 2001 08:46:12
Message: <3af00193@news.povray.org>
: Shouldn't that be:
:  heighfield
:  { whatever
:    texture { whatever scale <1, 1/2, 1>}
:    scale <1, 2, 1>
  No. The idea was that the heighfield should be scaled in widht and length
to the appropriate size before texturing (so that the texture would not be
distorted or anything), but the height should be 1 because of the used slope
pattern.
  My suggestion was to first set the width and length of the heightfield to
whatever they should be but leave the height to 1, then texture it and then
set the height to what it should be.
blob{#while(I<6)cylinder{M()#local D[I]=div(D[I],104);M().5,2
pigment{rgb M()}}#local I=(D[I]>99?I:I+1);#end}               /*- Warp -*/
Date: 2 May 2001 09:02:34
Message: <chrishuff-9A11E6.08000702052001@news.povray.org>
In article <3af00193@news.povray.org>, Warp <war### [at] tagpovrayorg>
> length to the appropriate size before texturing (so that the texture
> would not be distorted or anything), but the height should be 1
> because of the used slope pattern.
But when you scaled the height field to it's proper height, the textures
would still be stretched along the y axis.
BTW, you need to do the "scale <1, 1/2, 1>" or "transform {Trans
inverse}" in the textures in the texture_map being controlled with the
slope pattern, not in the slope-mapped texture itself...just thought
that needed to be clarified.
Date: 2 May 2001 09:37:39
Message: <3af00da3$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-9A11E6.08000702052001@news.povray.org...
That's what I thought. Warp, can you confirm, or have I/we missed something?
Sounds right - definately one to suck and see - at least for the
mathematically and spatially challenged.
