POV-Ray : Newsgroups : povray.unofficial.patches : I don't understand the slope pattern Server Time
5 Jul 2026 13:25:24 EDT (-0400)
  I don't understand the slope pattern (Message 21 to 25 of 25)
Subject: Re: I don't understand the slope pattern
Date: 2 May 2001 22:10:17
Message: <3AF0BE63.11541F63@pacbell.net>
"Tony[B]" wrote:
> Anybody have the address for the POV-Team?
I do :)
Ken Tyler
Date: 3 May 2001 06:57:54
Message: <3AF13A90.C0811F49@reading.ac.uk>
Mind you, if the 'pigment_pattern' statement makes it into v3.5 it would
probably be worth removing the convoluted extended syntax from 'slope'.
You can do exactly the same effects with pigment_pattern and it is as
easy to understand as the extended slope syntax.
I only tacked the extended syntax on to Hans Detlev-Fink's original
slope concept because no-one had implemented anything like the
pigment_pattern at that time. If we have pigment_pattern to do this (and
many other clever effects) in v3.5 then the extended slope syntax is
pointless and should be depreciated.
It pains me to say this about my only real contribution to The Cause but
Bye for now,
	Mike Andrews.
"Tony[B]" wrote:
> Thanks for your help Rune! I think I mostly understand it now. This
> definitely has to get into 3.5 to help those POVers who are stuck like me...
Date: 3 May 2001 08:02:40
Message: <3AF14908.EAFBD53A@pecos.n.o.s.p.a.m.de>
Yes, it's a pitty. Now that I understand everything at last. ;-)
-Hans-
Date: 3 May 2001 09:44:31
Message: <3af160bf@news.povray.org>
> into v3.5 it would probably be worth removing the
> convoluted extended syntax from 'slope'. You can do
> as as easy to understand as the extended slope syntax.
Do you mean by using an average between a slope pigment and a gradient
pigment, or is there an easier way?
If that's what you mean, then yes, it might be as easy to understand, but
it'd take up many more lines of code to achieve the same effect and you'd
have to do some calculations to be able to control it as well.
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated March 29)
/ Also visit http://www.povrayusers.org
Date: 3 May 2001 11:20:39
Message: <3AF1775C.D99BDD5B@gmx.de>
There already was a discussion on that matter some time ago:
Subject: slope-dependent pattern
Date: Thu, 4 Jan 2001 20:40:41
Newsgroups: povray.unofficial.patches
I still think the extended syntax is worth keeping, but it would not be an
enormous problem if it is removed IMO.  I never made a speed comparison
between extended slope pattern and the average-pigment_pattern construct,
but it probably will be slower at least to some extend.  Since the pattern
is often used for texturing (isosurface) landscapes, speed might be quite
an important argument.
