POV-Ray : Newsgroups : povray.unofficial.patches : megapov bug Server Time
5 Jul 2026 18:58:13 EDT (-0400)
  megapov bug (Message 2 to 11 of 31)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: megapov bug
Date: 7 Feb 2001 12:41:28
Message: <3A8188C7.4208CEE6@nanterre.marelli.fr>
Tom Melly wrote:
(something)
It's because of the 256 map entries limitations....
Bouf.
Date: 7 Feb 2001 12:43:40
Message: <3A8189F6.4937A03A@pacbell.net>
Tom Melly wrote:
> The following code fails in both pov and megapov (list too long) - but
> megapov crashes.
You are not allowed more than 256 entries in a color map which explains
the warning message in the official version. You are correct however in
assuming that MP should not crash as a result.
Date: 7 Feb 2001 12:48:32
Message: <3a818a70@news.povray.org>
Christophe Bouffartigue <Chr### [at] nanterremarellifr> wrote:
: It's because of the 256 map entries limitations....
  That's right, but crashing is still a bug.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 7 Feb 2001 13:59:44
Message: <3A819B20.178355ED@gmx.de>
I think Chris Huff was working on removing that limitation, or was it
someone else?
Date: 7 Feb 2001 14:14:16
Message: <3A819F31.8892A310@pacbell.net>
> someone else?
What would be gained by it ?
Date: 7 Feb 2001 16:17:37
Message: <3A81CC82.DB3B2CF@free.fr>
> > someone else?
	The delightful idea that no software should contain size limitations
of any kind. Especially since today's home computers may accept several Gbytes
of onboard memory. I personnaly don't think that (again nowadays) memory size,
as disk space, is a "good reason" compared to CPU time. But even the last becomes
smaller day after day for the same jobs. So why bother with limitations ?
	[Well, sorry for that, but I'm currently enjoying supercomputers for
my research calculations, and once I ran a "small" job using 96 processors in
parallel. Was just for fun since 8 are much more efficient in my case... the
device has something like 256 R12000 MIPS processors though]
*** Nicolas Calimet
*** http://pov4grasp.free.fr
Date: 7 Feb 2001 16:43:23
Message: <chrishuff-1EB4D0.16442407022001@news.povray.org>
In article <3A819B20.178355ED@gmx.de>, Christoph Hormann
> someone else?
I was, but haven't gotten it working right yet. If my code got stuck in
0.7, that might explain the crash...
Christopher James Huff
Date: 7 Feb 2001 16:45:32
Message: <chrishuff-C8DEEF.16463307022001@news.povray.org>
In article <3A819F31.8892A310@pacbell.net>, lin### [at] povrayorg
Simple: the ability to have more than 255 elements in blend maps.
Date: 8 Feb 2001 07:42:33
Message: <3a829438@news.povray.org>
The problem with dynamic data containers is that they usually take extra
memory (at least temporarily) and are sometimes slower than fixed-sized
data containers.
  Of course this shouldn't matter in this case since the required size can
be calculated first, then a proper array allocated and initialized from the
input.
Date: 8 Feb 2001 16:19:41
Message: <chrishuff-5C2537.16202508022001@news.povray.org>
In article <3a829438@news.povray.org>, Warp <war### [at] tagpovrayorg>
> extra memory (at least temporarily) and are sometimes slower than
> fixed-sized data containers.
Well, the unlimited version will parse a little slower, since it will
have to resize the array every so often, but unless you have some really
huge blend maps it won't be noticeable, and it will only affect parse
time. I took the approach of resizing the array when needed for
simplicity.
I think color_maps will reallocate to an array of exactly the right size
after parsing, but I'm not certain about the other blend_map types...but
the memory waste for each bland_map won't be very bad even if there are
unused entries.
