POV-Ray : Newsgroups : povray.unofficial.patches : Seems that the tesselation patch died before even being born Server Time
5 Jul 2026 17:29:05 EDT (-0400)
  Seems that the tesselation patch died before even being born (Message 25 to 34 of 34)
Subject: Re: Seems that the tesselation patch died before even being born
Date: 18 Jan 2001 05:58:05
Message: <3a66cc3d$1@news.povray.org>
> > and change Parse_*() functions.
> But not that one : do you have an idea of the number of functions
> to patch ?
everyone which calls parse_object_mods()
or I don't understand question
as I said I did it for source of megapov 0.6
and it took about 1 hour and it works
> Moreover I found it counter-productive and dangerous:
> let's say we have a CSG operation (not a union) and
> you modify ONE of the component to tesselate while the
> other components remained unchanged.
> I'm not sure the CSG would still be possible.
sometimes when you translate/rotate/scale component of CSG
rest of CSG dissapeare
> Sincerely, I just like the way the tesselation object was introduced:
> it is a new object. dot.
if you have large definition of object you must
jump over source to tesselate it : "tesselation {" at beginning and "}" at end
when you put this as object modifier you must type only in one place.
But consider that I'm talking about ideal tesselation with inheritance of
parameters such no_image, texture, hollow etc. from base object.
> > > When povray parses an object, it creates internally an object of that
> > > type. A tesselation modifier would have to change that object to a mesh
> > > object.
> > when you tesselate object you do it probably to use it insted of original
object
> > for user there could be no difference - only speed up
> No, at least for me: tesselation would also provide a different aspect
>  (the 'polygon'/facet aspect), and that's also interesting.
>  (instead of playing with the normal vector with a complex pattern)
but you still can do it with tesselation as part of object modifiers, just with
this
#declare Object=csg{}
object{ Object }
object{ Object translate x*10 tesselate { 10, 7, 11 ... } }
> > >  I'm not sure if there is any advantage in this either.
> > I know that some peoples don't like such word like "modeller" according to
> > POV-script
> > but in modellers there is taskbar with operations applied to object and
> > rotation, scale and other linear operations are neighbours for
> Yes the classical mods,
> > twisting,
> > bending, screwing
> This is the 'classical' problem with the POV approach: the intersection
> of an object with a curved ray...
But I've resolved this in my putch a little :-)
> The 'twist/bend/screw' cannot be applied to all objects, but you
> could make them to be some new 'object' (?) that would take a
> mesh-like object and some parameters:
What you mean by "cannot" ?
In my patch they can.
> twist { object {my_mesh}, <center.x,center.y,center.z>,<axis.x,axis.y,axis.z>,
>angle... }
> bend { object {my_mesh}, <center.x,center.y,center.z>,...}
> screw { object {my_mesh}, <center.x,center.y,center.z>,<axis.x,axis.y,axis.z>,
> pitch... }
> Then when parsing, your 'object' is twisted/bent/screwed by 'simply' applying
> a blind transformation to each vertex of the mesh
This cause a lot of new types of objects.
All this stuff shuld be IMO in object modifiers.
> (beware: you not only have to transform the position of the vertex, but also
> the normal... so the 'simply' is an overstatement).
perhaps you missed some images in p.b.i
just look at topics with word "deform" sended by me
when I twist box, my eyes see twisted box, not another type of object
even if it is triangulated
ABX
Date: 18 Jan 2001 11:36:32
Message: <3A671B8F.A4774B74@atosorigin.com>
This may be a bug (unless the intersection/difference leave nothing,
in such case I would considere that it is normal).
But I do not think it may be a reason for the tesselation as
an object modifier.
This is only a problem for the editor.
And you may as well have a single line
#local to_be_tessalated = <<your big construct>>
tesselate { object { to_be_tessaleted } }
If clear and understandable source is your purpose.
Ring some bells here about 'object'
> > > POV-script
> > > twisting,
> > > bending, screwing
Yep, looks like we do not have the same definition for 'object'
If I understand your definition, and abuse it somehow,
all we need in Pov is the sphere object.
to make a cylinder, add a cylinder modifier
to make a box, add a box modifier
to make a cone, add a cone modifier
to make a superellipsoid, add a superellipsoid modifier
to make a quartic, ...
My definition of object is based on the internal structure,
once parsed.
So, if you look at the source, there is a sphere object and
another one which is an ellipsoid.
and a box object,
and a cone/cylinder object,
and a superellipsoid object, and so on...
Basically, an object has a method which return all the intersection
of a ray with the object.
So from my current understanding of the tesselate patch (not opened yet),
it is an easy way to obtain a mesh object. I can hardly see tesselate as
a generic modifier, because pov does not end with the same parsed structure:
 without the modifier, the object structure holds pointers to the csg functions,
 with the modifier, the object structure holds pointers to the mesh functions.
It's too much for a modifier, at least for me !
(probably the only object which play this
kind of trick is the sphere when scaled unevenly: it replace the pointers
with the ones for the ellipsoid. But then, they are really similar object
and they are coded in the very same file, so that's very different from
your suggestion with tesselate).
Please, tell me where I can see the code for it.
I'm interested to see how you perform this miracle.
> >angle... }
> > pitch... }
May be they may be just MESH modifiers. But I cannot still understand
how you can apply them into the resolving intersection of a line
and a sphere (e.g. as is currently the function for the sphere object)
when applied to a true basic object (and not a set of triangles)
I also probably missed the deformation of the texture!
And in p.b.i, all I see from you is about ten posts, but
none with deform (but I seems to remember some sliced/twisted box,
so may be my newsreader is bogus)
Your eyes see a twisted box, but the code will probably see a mesh,
which may look like a box but is not really a box.
And if it is not really a box, it should not be parsed as a box...
Best regards, and probably more to come once I will have read the
tesselation patch...
Date: 18 Jan 2001 12:39:31
Message: <3a672a53@news.povray.org>
yes, I'm talking about  leaving nothing
but I can't understand your thinking that
tesselation as object modifier is dangerous
considering ideal tesselation - tesselated object has inside and
outside just like base object - than why it couldn't be part of csg ?
end
I agree
you still have to jump to write #local and tesselate, but nevermind
I'm sorry, my english is not enough to understand meaning of this sentence
is it some idom,  is it sarcasm ?
to
> > > > POV-script
> > > > twisting,
> > > > bending, screwing
I'm affraid you are completly wrong in understanding me
> once parsed.
> and a box object,
I think you are completly wrong in thinking about me.
right
functions,
but for almost every modifer it calls soemthing like "method" to do something -
rotate, translate, set_flag
almost all modifiers are independent of type of object
(I'm talking about internal structure)
(independant this means that they have something like pointer->method or
function(pointer) and this "method" only internal depends of type of object)
never mind if it is sphere, cylinder or isosurface
if you smart replace pointer (internal) to currently parsed object you can make
it invisible
for that tesselated object is putted instead of original object
I play some years with pov
I don't like to be intruder in any community therefore since year I slowly read
whole news.povray.org to understand meaning of life :-) and I never meet opinion
that povsyntax should be mirror of internal structure. Perhaps I'm wrong but I
never meet. It shouldn't go far from internal but if there is something to
simply understand with syntax different than internal structure why not ?
my deformations are internal another kind of object and at first it was another
object in povsyntax
but when I announced my proposition in this group there was opposition that
deformation such like twist should be rather (compared with warp{}) modification
with proper parameters - therefore I changed syntax to object modifiers but
internals it is still another kind of object - it is just easier method to do it
for me becouse it has different method all_intersections()
I've not finished it yet and I don't want publish not finished code only to
proof something.
Although I don't think that I did miracle. I don't want fight with you. Whole
method was descibed here, in p.u-p with symbolic algorithm.
I don't think that my method is best way - it has limitations (reversable
deformations) and it has something like accuracy (like isosurfaces) but it works
for all objects, not only for meshes.
applying
meybe not
by spliting ray to short segments and deform them and intersect base object
also
this is the part what I'm working on
> none with deform
http://www.abx.art.pl/pov/nonlinear/step3.jpg
I see the code, you not
believe me that code see not twisted box
even if I see twisted one
is there any other person who can vote against or opposite for:
a) deform as part of object modifiers
b) tesselate as part of object modifiers
it is not oblique voting for authors of patches but let's disscuse
ABX
Date: 18 Jan 2001 19:07:19
Message: <3A678591.41172CA5@peak.edu.ee>
Chris Huff wrote:
> It basically seems to be that triangles don't always end up where they
> are expected...every once in a while, in a very reproduceable but
> unpredictable manner, one (or more?) vertex of a triangle will end up
> where it shouldn't be, leaving a hole in the mesh. At least, that is
> what I could figure out...(A similar problem killed my warpable mesh
> patch.)
Funny. I had the same problem when I tried to do a tessellation macro, which
used the marching tetrahedrons technique (the same as Warp's patch, no?)...
Of course I never did bother to do a thorough debugging session, so 'twas
probably just something silly.
Margus Ramst
Home page http://www.hot.ee/margusrt
Date: 18 Jan 2001 23:40:23
Message: <3a67c537@news.povray.org>
>to patch ?
26 in the official version, more in MegaPOV.
Mark
Date: 19 Jan 2001 06:34:20
Message: <3A68263D.D04702C7@atosorigin.com>
This discussion is starting to be too long...
Well, Off-topic, but I think that the CSG is not bugged.
Because I have applied (yes, now) the tesselation patch to
a non-megapov version (my personal experimental 3.1),
and within 3.1, mesh cannot be part of a CSG difference/intersection.
No sarcasm. Just the expression that your sentence triggered some thinking
in my head... Alas, my thinking seems to have been wrong.
>> > > > > twisting,
> > > > > bending, screwing
As I do not have access to your patch, all I was able to do was
guessing. Wrongly, I thought that to perform the twist/bend/screw,
you had transformed the object (let's it be a CSG or blob) into a mesh.
Then applying a transformation to the vertex of this mesh.
I agree.
> right
> functions,
Rotate/translate/scale : yes, the object definition must provide a function
for them
Set flag: no, it's part of the core structure of an object and it
is handled by a single parser function.
Yes, because all type of object have the core structure of object.
> it invisible
Well, you may have to reallocate the instanced object structure because some
object have bigger structure than other ones.
That's why I do not like the idea of an object modifier which nearly
substitute a structure for another.
When the script start saying it want a Pizza, I like to end
with a Pizza (even if you change the pepperoni for pineapple
and the sweet pepper for some corn).
From my point of view (nobody has to agree with it), the recipe
for the Pizza is in one single c file (sphere.c, csg.c, blob.c,
super.c, you name it...) and the other c files contains some
recipes for some other meals.
So, currently, my understanding of modifying on the fly the object
pointers via a generic object modifier , outside of the specific
object file, sounds to me like the script seems to ask for a Pizza
 and is finally served with a plate of Sushi.
I do not like this confusing approach, even if I can both like
Pizza and Sushi.
This may be the start of a full chapter of holy war about the pov syntax,
should it be object oriented or not, should it looks like C++ or some
others language, and so on.
I do not care, as I'm not in charge of defending the syntax.
I would prefer to see your patch public, even done with a way I do not
like , rather than nothing. Afterall, the povteam will be able
to change it to the way they want if they ever find it too confusing
or too complex or inadequate (or whatever).
> object in povsyntax
Sound good for me...
Warp are built-in the engine, so that's easy when evaluating the texture to
apply a warp to it.
But deforming an object
I think you should not have listen to the advisers, it would have make
me happier :-)
Or maybe there was a misunderstanding when people see your picture:
(I was assuming you used a mesh due to a final sentence stating in one
of your message that it may be easier to modify the vertex of a mesh)
May be some where saying that since the warp option already provide
a transformation of the space, it would be productive to have your
transformation to use the existing warp, so that adding a warp automatically
add a new transformation of object.
This is logical when one thing you're modifying a mesh: you enter the
original vertex in the warp and you exit of it with the new coordinate vertex.
In this case, it is logical to have a syntax such as
mesh { .... deform { warp_element } }
because there is a definitive added value to the fact of reusing the
transformation made by the warps.
> proof something.
Good, but I would very like to see how you resolve the problem
of the shadow and reflection (transforming an object only for the camera,
I can do it, but my headache starts when I start thinking about
the reflected ray and the lights ray...).
Well, the twist/bend/screw thing is resisting many pov-programmers, including
me recently...
Neither do I.
> Whole
I found the thread, but did not see the symbolic algorithm.
Can you provide the reference of the message, thanks.
I'm curious... I will have to wait...
> meybe not
Well, with my previous hypothesis (which is wrong),
they would only have been modified Mesh.
Now, the tesselate patch introduce an interesting approach.
Applying a mesh-deform patch using warp definition
as mesh modifier to a tesselated
object allow get all the warp being available to play
with all objects that can be tesselated.
Ouch...
Nice!!!
I can imagine how to do it with a warp-based mesh deformation,
but you probably did it with a real checkered box.
I was wrong,
But may I ask to have some background checkered planes and some
shadows of the box casted on them. I'm really curious.
> ABX
May I ask who care ?
IMO, do your patch your way, then let people comment them and
use them.
I prefer to have a lot of patches than none... as long
as you do not break everything...
Date: 19 Jan 2001 07:53:47
Message: <3a6838db@news.povray.org>
the main part of my plans is connected with features of 3.5 and
therefore I think always about features of megapov
but right - solid triangle mesh is part of "Meybe" of
http://www.povray.org/3.5-status.html
there is more about my idea in p.u-p in todays posts
make
> > it invisible
I don't want tesselate anything without agreement of user
> Pizza and Sushi.
well written documentation should have description what deform{} cause
read
opinion
I
right
right
> apply a warp to it.
I plan support this built-in engine of warps
do it
> me happier :-)
perhaps :-)
but I play with this syntax
and it is just simpler to me
> > proof something.
I must finish my opened functions and than I prepare some images to p.b.i
I think it will be ready to send after weekend
> me recently...
Well, currently I play with pure mechanism of inheriting of textures
You can halp me with type of deformations
every deformations should have described four things
b) undeform function
a) deform function (with calculation of new normal)
c) calculation of new bbox of deformed bbox
d) calculations of begining and ending of ray crossing deformed shape (for
twisting it is cylinder)
> > Whole
Here is symbolic notation of my all_intersections method:
take depth1 and depth2 for container or bounding box
take function deform and undeform (opposite to deform)
for i=depth1 to depth2 step accuracy
  point1=evaluate_ray(trace_ray,i)
  point2=evaluate_ray(trace_ray,i+accuracy)
  pointA=undeform(point1)
  pointB=undeform(point2)
  deformed_ray=create_ray_beetwen(pointA,pointB)
  all_intersections(deformed_ray,base_object)
  for every intersection beetween pointA and pointB
    get deformed intersection and deformed normal with deform(intersection)
    if it is beetween pointA and pointB than put it on stack
  end for
end for
works
after advice of Chris Huff I plan to omit this limitations
please read about my plans in "torus torture" thread in p.b.a or p.u.p
> Ouch...
sorry, what's wrong ? :-)
> Nice!!!
right, with uv-mapping
> I was wrong,
as I said I'll prepare some images for you
> > ABX
if there is no difference for me where I put definition of patch
than I want do something for community - where they want
> IMO, do your patch your way, then let people comment them and use them.
ok. here is current list of closed modifications
new module deform.c with definition of Deform object
new Parse_Deform() in parse.c
new closing parts of functions called Parse_Object_Mod()
new CASE in Parse_Object_Mod()
some new tokens
new field in ISTACK
new parameter to all All_Intersections with max_depth
Best regards,
ABX
Date: 19 Jan 2001 09:13:27
Message: <3A684B88.BCAEDE32@atosorigin.com>
Yes !!!
Agreed, now that I've seen your approach...
I would still think it would have been a new object (kind of
CSG variants/mutation...)
Yes. But that's probably for later...
That's a good thing!
This limit you to inversable transformation.
Beware, some warps have singularity...
I am wrong in thinking that the deformation of the normal
is simply the resulting deformation of both extremity ?
Yes, not obvious for some deformation.
But if you have a container object, I do not see the need
for that.
That's the all_intersection of the container, isn't it ?
That was the reason of my 'Ouch...'
It may slow down a lot!
Which one ? the reversable transform ? How ?
> > Ouch...
I just imagined the explosion of additional rays to cast...
> > Nice!!!
Why ? a warp should have been enough...
(deform the box, warp the texture, with the same equations...)
Thanks you.
So, it is an object... I like it.
Obviously.
Here we had a little divergence of opinions, but
please do it your way.
> some new tokens
Yes, Obviously.
> new field in ISTACK
These I will probably not like either...
Have a nice week-end.
Date: 19 Jan 2001 09:38:00
Message: <3a685148@news.povray.org>
but before publicity of code/patch
Thanks redirected to Chris
please read explanation about it in my todays posts in p.u.p
yes, you are wrong, there was some posts about this problem
in this group and in p.a-u
> for that.
I'm talking exactly about container bounding
not exactly, but mainly yes
not so much
less than the same thing realized with isosurface
more than the same thing realized with mash
but as you can observe my method has better accuracy than mesh
object
> > > Ouch...
you only imagine but I have tested this
it is not so bad solution
> > > Nice!!!
why ? just for test that uv-mapping works correct with my patch
thanks
> > new field in ISTACK
perhaps max_depth could be added to ray structure instead of all_intersections
I will check this
ABX
Date: 19 Jan 2001 16:30:10
Message: <chrishuff-1B7207.16311519012001@news.povray.org>
In article <3a685148@news.povray.org>, "Wlodzimierz ABX Skiba"
Me? I just suggested using warps...you are the one implementing this
thing. I still don't quite understand how your algorithm works...though
it obviously does.
Christopher James Huff
