POV-Ray : Newsgroups : povray.unofficial.patches : crackle: suggested extensions Server Time
5 Jul 2026 12:02:07 EDT (-0400)
  crackle: suggested extensions (Message 11 to 19 of 19)
Subject: Re: crackle: suggested extensions
Date: 16 May 2001 22:39:34
Message: <3B033A20.637F891D@pobox.com>
Anton Sherwood wrote:
> theta = rx*2*pi;
> phi = acos(2*ry-1);
> v0 = sphere_to_xyz(theta,phi); /* uniform by Archimedean theorem */
> vtemp = one of the axis vectors,
>         corresponding to the smallest component of v0;
> v1 = vaxis_rotate(vtemp,v0,rz*360);
> v2 = vcross(v0,v1);
> v0 = vcross(v1,v2);
oops, make that last line v1=vcross(v2,v0).
> v0,v1,v2 are the new basis.
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu/
Date: 19 May 2001 17:25:37
Message: <3B06E510.A1811A1B@pobox.com>
> Christoph Hormann wrote:
> > I really wonder if the actual implementation would look the same...
> I'd expect some difference because I only rotated the pyramids on z --
> and because I've no idea how crackle places the nuclei.
And (oops) some of the pyramids ought to have flat peaks.
Date: 21 May 2001 19:41:10
Message: <3B09A7D7.79260A8D@pobox.com>
Ron Parker wrote:
> Do you happen to have a formula that will translate a random vector in
> the unit cube between <0,0,0> and <1,1,1> into a set of basis vectors
> and give uniform coverage of the space of all possible basis vectors?
> I seem to have left mine in my other coat.
I forgot to ask: are the noise-vector's components independent?
Date: 22 May 2001 01:09:48
Message: <slrn9gjt50.v61.ron.parker@fwi.com>
They should be.  If they aren't, we have a bigger problem. :)
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 6 Jun 2002 22:21:22
Message: <3D00188D.86C4C89E@pobox.com>
(Will anyone ever read this?)
> > > vector in the unit cube between <0,0,0> and <1,1,1> into a set
> > > of basis vectors and give uniform coverage of the space of all
> > > possible basis vectors?  I seem to have left mine in my other
> > > coat.
> > I'll think about it some more, and come up with a dumb idea.
> Got it.  (I'll call your random vector <rx,ry,rz>)
> [...code...]
A year later, it hits me that this ought to work just as well:
	rotate <360*rx, degrees(asin(1-2*ry)), 360*rz>
(though of course one wouldn't really use degrees arithmetic)
Choosing a basis is equivalent to choosing a point on the sphere and a
rotation around it.  My first code essentially did it in that order.
The reverse looks more efficient.
Anton Sherwood, http://www.ogre.nu/
Date: 16 Jul 2002 16:21:12
Message: <slrnaj901q.lnd.ron.parker@fwi.com>
No.
Now I have to go back and find the articles it's referring to...
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 7 Feb 2014 23:45:59
Message: <52f5b687@news.povray.org>
On 2001-5-15 22:40, Anton Sherwood wrote:
> ... Meanwhile, another idea: if (dx,dy,dz) were replaced with
> (dx+dy,dx+dz,dy+dz), the `crystal' would be a rhombic dodecahedron.
Or not.  Less than 13 years later, as I was thinking about something
unrelated to ray-tracing, it hit me that it would have to be
	(dx+dy, dx-dy, dx+dz, dx-dz, dy+dz, dy-dz).
*\\* Anton Sherwood *\\* www.bendwavy.org
Date: 21 Mar 2014 18:27:06
Message: <532cbcba$1@news.povray.org>
Or ( abs(dx)+abs(dy), abs(dx)+abs(dz), abs(dy)+abs(dz) ),
which is probably what I meant in the first place.
Date: 22 Mar 2014 07:15:00
Message: <web.532d6f93ad8c17a9e0ead47e0@news.povray.org>
You persevere I'll say that for you. :-)
