POV-Ray : Newsgroups : povray.unofficial.patches : Diffuse==0 in step functions, problem solved? Server Time
7 Apr 2026 12:13:59 EDT (-0400)
  Diffuse==0 in step functions, problem solved? (Message 1 to 5 of 5)
Subject: Diffuse==0 in step functions, problem solved?
Date: 6 Nov 2000 13:18:59
Message: <3A06F4C7.3AB43D80@my-dejanews.com>
I found this page on the Japanese povray webring.
http://www.cs-w.com/~earth/material/isopattern.htm
There is here the use of the cells pattern in a way that does not give
diffuse=0 on the edges of step functions.  I will study the source code,
but the reason why it looks so good hasn't hit me yet.  Any clues?
Subject: Re: Diffuse==0 in step functions, problem solved?
Date: 6 Nov 2000 13:37:24
Message: <3A06FA60.946A2FA5@schunter.etc.tu-bs.de>
I'm not totally sure what you mean by diffuse=0 but i suspect you meant the
problems occuring with abrupt steps in the pattern.
You can see in the source code, that the critical patterns all use higher
max_gradient values (20/50) and there are still errors occuring although not
very strong.  On 'isopattern2.htm' they are even better visible.
Date: 7 Nov 2000 06:54:20
Message: <chrishuff-2A58F8.06542107112000@news.povray.org>
In article <3A06F4C7.3AB43D80@my-dejanews.com>,
As I have mentioned before: I think the problem is not that the diffuse
is being set to 0(which sounds impossible), but that there is a problem
calculating the normal for these functions. If the resulting normal is
bad(containing NaN or something) or is just wrong, the lighting
calculations will not work properly.
Christopher James Huff
Date: 7 Nov 2000 08:27:55
Message: <3a08035b@news.povray.org>
Thanks for the reply, but the point is that in this gentleman's (Makoto Mukui)
image, there is no such problem.
Thus it is not a fundamental, inescapable problem with step functions in
to sleep.
Date: 7 Nov 2000 14:43:18
Message: <chrishuff-E9E7EC.14431907112000@news.povray.org>
In article <3a08035b@news.povray.org>, "Greg M. Johnson"
> (Makoto Mukui) image, there is no such problem.
> in isosurfaces.? Perhaps his solution is simply a clever use of the
> max_gradient at 50 that none of us thought of before.? Will
> experiment after I put the baby to sleep.
I understand that...and I would like to see some experiments using the
object pattern with this technique. He seems to have overlooked it...
However, if it is a problem with normal calculation(or self shadowing,
another possibility), there might be a better way to solve it than using
an extremely high gradient. If someone takes a closer look at what goes
wrong and why his code gives a better image, they might find a faster
rendering compromise.
