POV-Ray : Newsgroups : povray.unofficial.patches : Major bug in MegaPOV Plus? Server Time
13 Aug 2026 09:05:07 EDT (-0400)
  Major bug in MegaPOV Plus? (Message 31 to 40 of 81)
Subject: Re: Major bug in MegaPOV Plus?
Date: 8 Sep 2000 15:54:35
Message: <01c019ce$7da07900$917889d0@daysix>
Yo, Chris,  when can we expect the fixed version of the +.3?  The memory
leak has sorta crippled my IRTC anim...
Oops.
H.E. Day
Date: 8 Sep 2000 16:23:20
Message: <slrn8rijef.1e2.ron.parker@fwi.com>
On Fri, 08 Sep 2000 13:36:17 -0500, Thorsten Froehlich wrote:
>For inserting:       O(n * log(n))
>For retrieval:       O(n * log(n))
>Total:               O(n * log(n) + n * log(n))
>I can get:
>For inserting:       O(n)
>For sorting *:       O(n * log(n))
>For retrieval:       O(n)
>Total:               O(2 * n + n * log(n))
>* No fancy algorithm, just quicksort.
You seem to have a misconception about how O() notation works.  The total
for the first case is O(n*log(n)) and the total for the second case is...
O(n*log(n)).  They might have different constant factors, but the determination
of which is faster is entirely a matter of determining those constant factors
(which depend on the constant factors in the component parts of the algorithm.)
BTW, if this comparison method worked, I could beat you both.  I have a
balanced, fully-threaded 2-3 tree implementation with O(n log n) insertion
and O(n) traversal.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 8 Sep 2000 16:55:13
Message: <chrishuff-B3D295.15565908092000@news.povray.org>
In article <39b9050f@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
>   So instead of spending 1/2 hour once to learn how to use the STL you
> spend 2 hours every time you want to use a weighted binary tree?
No, I want to spend 2-5 hours learning how to implement it myself. Then
I can spend 1.5 hours figuring out the STL(or fighting with the STL) to
do the same thing.
> : And because I don't want to be
> : separated from what my program is doing?
>   Sorry, I didn't understand at all what are you talking about here.
If I use the STL, I don't know exactly what is happening in my program.
If something goes wrong with a program using something I implemented, I
know the code, and can figure out the problem quickly. If something goes
wrong and I am using the STL, I end up trying to figure out why STL
files are producing errors, whether or not the problem is actually *in*
the STL.
> : And because when I was *trying*
> : to learn the STL, I often got errors and couldn't figure out why?
>   Get a proper compiler and try again. You can get one by free.
I have an excellent compiler and good libraries. That doesn't help
understanding the reasons I get errors.
>   And read documentation and tutorials.
I have been collecting links to various STL tutorials/overviews on the
web. I also plan to buy some books, when I can. I have a book with a lot
of detailed information on the STL, but it seems more reference oriented
than tutorial oriented.
Christopher James Huff
Date: 8 Sep 2000 17:01:46
Message: <chrishuff-383F5B.16033308092000@news.povray.org>
In article <39b91926@news.povray.org>, "Thorsten Froehlich"
<tho### [at] trfde> wrote:
> Hmm, sounds like reinventing the wheel to me ;-)
Exactly.
> The thing is once you have done it two or three times it gets really
> boring writing the same code over and over again and it distracts
> from the fun part of programming and especially it distracts from the
> actual problem you want to solve.
That is fine, but at the moment, I want to have a grasp of how they
work. I can imagine programmers taught to always use the STL
encountering a simple doubly linked list in someone else's code and
being completely baffled by it...I want to understand the tools I use,
and how to implement them myself if necessary. For example: a game
project with extremely severe speed requirements, developing for
platforms where the STL isn't useable, writing in other languages which
I may learn in the future, etc. Especially that last one...I don't
expect C++ and STL to last forever, knowledge of algorithms is portable,
knowledge of the STL is not.
Date: 8 Sep 2000 18:33:07
Message: <chrishuff-C76C1B.17345408092000@news.povray.org>
In article <01c019ce$7da07900$917889d0@daysix>, "H. E. Day"
Real Soon Now. I have a couple more things to work out, and a couple
small features I want to add.
Date: 8 Sep 2000 19:00:45
Message: <39b96f9d$1@news.povray.org>
In article <slr### [at] fwicom> , ron### [at] povrayorg (Ron
Parker) wrote:
> You seem to have a misconception about how O() notation works.  The total for
I know, but I don't care enough (especially as a full "prove" is rather
long) as all I want to point out is that a map will not perform better than
a slightly different and in plain C easier to write algorithm than the
RB-tree most likely used for the map.   As for the total, you are right that
I shouldn't just have copy and pasted it together assuming anybody would get
the idea I wanted to show.
> determination of which is faster is entirely a matter of determining those
> constant factors (which depend on the constant factors in the component parts
> of the algorithm.)
Yes, I am aware the constants matter here when using a simple sorting method
(merge sort) as I suggested.
To make you happy, I could have written (for the worst cases):
Numbers following variables should be read as subscripts!
T1(n) = (c1 * n * log n + c2) + (c3 * n * log n + c4) =
        (c1 + c3) * n * log n + (c2 + c4)
T2(n) = (c5 * n + c6) + (c7 * n + c8) + (c9 * n * log n + c10) =
        (c5 + c7) * n + (c9 * n * log n) + (c6 + c8 + c10)
For a large enough n this will hold:
c2 + c4 < (c5 + c7) * log n
and
c6 + c8 + c10 < (c5 + c7) * log n
So, I simply eliminate c2, c4, c6, c8 and c10 (set them to one) and can get:
T1(n) = (c1 + c3) * n * log n
T2(n) = (c5 + c7) * n + (c9 * n * log n)
Lets further assume that c1 = c3:
T1(n) = 2 * c1 * n * log n
And now comes the tricky part because I have to show that (c1 + c3) > c9.  I
do not need to assume anything about c5 and c7 as n * log n > n for a big
enough n. this leaves:
T2(n) = c9 * n * log n
I assume that for map a RB-tree is used and for list.sort a merge sort that
just flips the pointers of two strings.  In both cases the algorithms need
to perform n * log n string comparisons, so we can just not count those.
This leaves the recursive calls and the swap operation for the merge sort,
and the walking through the tree (twice).
I assume that the merge sort will be faster*, but if anybody is not happy
with this, for string sorting there are plenty of other algorithms out
there...
In conclusion it is without problems possible to outperform the map used in
this case, and this is all I wanted to point out.
     Thorsten
* I don't want to spend the time to show this now.
e-mail: tho### [at] trfde
Date: 8 Sep 2000 19:19:29
Message: <39b97401@news.povray.org>
>>I can get:
>>For inserting:       O(n)
>>For retrieval:       O(n)
> of the algorithm.)
> and O(n) traversal.
(Referring to my previous reply):
Or, I could just prove that
 lim   2n lg n   >   lim   2n + n lg n
n->oo               n->oo
 lim   n lg n  >   lim   2n
n->oo             n->oo
        Thorsten
Date: 8 Sep 2000 20:02:17
Message: <slrn8rioib.3e4.hjp-usenet@teal.h.hjp.at>
which is O(n * log(n)
which is also O(n * log(n)
No difference there.
Which one of the two algorithms is really faster depends on the
implementation and the input data.
	hp
   _  | Peter J. Holzer    | Nicht an Tueren mangelt es,
|_|_) | Sysadmin WSR       | sondern an der Einrichtung (aka Content).
| |   | hjp### [at] wsracat      |    -- Ale### [at] univieacat
__/   | http://www.hjp.at/ |       zum Thema Portale in at.linux
Date: 9 Sep 2000 00:24:53
Message: <39b9bb95$1@news.povray.org>
In article <slr### [at] tealhhjpat> ,
Yes, because I was lazy and just did a copy and paste.  In big-O notation
this will be the result, but this is not the whole issue (just eliminate the
big-O in the total!).
No, it is a clear which one is faster, just my notation for the total was
incorrect:  See my later posts explaining it in more detail.
      Thorsten
Date: 9 Sep 2000 00:36:43
Message: <39b9be5b$1@news.povray.org>
No, it does not depend on the input data too much.  The reason being that
the tree used for the map will be balanced so you should always have about
log n access time.  And for the merge sort it also does not matter, it will
always take n log n time.
I fell for the trap of the big-O notation at first, too, when replying to
Ron, but I was simply implying the wrong thing at first by using big-O
notation for the totals, especially because you can't compare big-Os of
functions anyway ...
      Thorsten
