![](/i/fill.gif) |
Warp found some problems with cutaway_textures
(his message in this newsgroup from 09/15/00).
I have similar problem with following:
difference {
union {
sphere {<0, 0, 0>, 5 texture {pigment {color blue 1}}}
sphere {<-5, 0, 0>, 2 texture {pigment {color red 1}}}
plane {<0, 0, 1>, 0}
cutaway_textures
works good, but
difference {
union {
union {
plane {<-1, 0, 0>, 0}
cutaway_textures
ignores cutaway_textures. I think, that the reason is that POV-Ray
automatically asigns default texture to the second union in difference
and cutaway_textures thinks, that this union has texture assigned
with user.
Q: should cutaway_texture ignore all textures in subtracted objects?
I know, that it works good when the planes are not composed to union,
but I have some cases, where I first compose some objects, which
will represent holes to another object in the future (for example
windows in wall, they are added by some macros to one composite) and
after I need cut them from another object in way like
difference {
object {Actually_composed_wall}
object {All_window_holes}
cutaway_textures
Disnel
![](/i/fill.gif) |
![](/i/fill.gif) |
"Disnel" <dis### [at] hlavacek-partner cz> wrote in message
news:39F00638.36C4E0F6@hlavacek-partner.cz...
> with user.
Think you may be right, the union probably doesn't adhere to a proper entity
for that purpose. Must be that CSG isn't applicable to the cutaway_textures
feature, doing it only on a per primitive basis.
![](/i/fill.gif) |
![](/i/fill.gif) |
> > with user.
> Bob
I can remember all holes in array instead "storing" them in union,
but it is more complicated and I am limited with some fixed array
size .... possible growing array will be very useful ;-).
Disnel
![](/i/fill.gif) |
![](/i/fill.gif) |
"Disnel" <dis### [at] hlavacek-partner cz> wrote...
[clip]
> with user.
This sounds like a bug. I don't have time to try to fix it now,
unfortunately. I'll look into it, though. It probably has something to do
with the fact that unions get split up.
-Nathan
![](/i/fill.gif) |
