Greg M. Johnson <"gregj;-"@aol.c;-om> wrote in message
>Shouldn't we simply tell those with the archaic readers simply to upgrade
to
>Win2000 and Netscape or MSIE? That is in essence what we say when someone
>cannot read a bleeding edge video format.
And while we are throwing mud around, for unknown reasons, messages from you
cause Outlook Express to display all future messages in extra-large bold
face non-monospaced type, despite the fact that I have it set to use
10-point Courier for displaying everything.
Mark
In article <39EE5054.E0F94FC1@hotmail.com>, Pabs <pab### [at] hotmailcom>
wrote:
> Also Chis could we have a system whereby you can specify a certain
> number of particles to be created at the start of the simulation in
> certain positions?
I have been thinking of something like this...maybe add_particle() and
delete_particle() functions which can be called for any declared
particle_system object, or maybe just a way to specify a set of
particles to start with.
Christopher James Huff
Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:39ee792b@news.povray.org...
> >Shouldn't we simply tell those with the archaic readers simply to upgrade to
You need to upgrade <smirk> to OE 5.5 because it seems that doesn't happen for
me.
Apparently Greg has a user defined font.
What's this about particles? j/k
> > certain positions?
The add & delete functions would be more flexible or perhaps the spline
thing could do this?
Bye
Pabs
http://zip.to/pabs3 -> http://www.crosswinds.net/~pabs3
In article <39EF90FB.FDAD0263@hotmail.com>, Pabs <pab### [at] hotmailcom>
But sometimes harder to use, maybe...
> or perhaps the spline thing could do this?
I don't understand what you have in mind...could you explain more?
I'm not really sure myself.
but perhaps as well as emmitters you could have volumes (defined by
different objects) where particles appear randomly with a spline
specifying the amount of particles created at each timestep. Also you
could integrate a probabilty pattern into this -
while nump <= maxp
1 Generate a random position inside the volume = pos
2 Find the probability that a particle will be created at pos (from
the pattern) = p
3 If a random number (0...1) <= p then create the particle
4 If the user wants to have maxp particles & not less do nump++ only
when particles are created
end
Bye
Pabs
In article <39EFBB8D.F37E196B@hotmail.com>, Pabs <pab### [at] hotmailcom>
Oh, like an object emitter but with control of the probability that a
particle will land each point, using a pattern and a spline as a kind of
float_map?
Tell me which settings to change on my netscape browser to remove the bleeding
edge features that cause you difficulty and consider it done.....
> to
> Mark
<39f1f85b@news.povray.org>...
bleeding
I said it's an unknown reason. I'm guessing it's either this header:
X-Accept-Language: en,zh-TW,zh,zh-CN
or this one:
Content-Type: text/plain; charset=x-user-defined
I don't know how you would go about changing either one.
Mark
> float_map?
Yep
Bye
Pabs
