POV-Ray : Newsgroups : povray.unofficial.patches : MegaPOV Plus ipf_profile problem Server Time
19 Mar 2026 07:47:18 EDT (-0400)
  MegaPOV Plus ipf_profile problem (Message 11 to 13 of 13)
Subject: Re: MegaPOV Plus ipf_profile problem
Date: 18 Jul 2000 11:26:45
Message: <chrishuff-BD35FE.10271718072000@news.povray.org>
In article <3973D2BD.A92017E7@peak.edu.ee>, Margus Ramst
<mar### [at] peakeduee> wrote:
> Yes, but is this really worth the computational expense? I suspect
> the spin of individual particles has little perceptible effect on the
> overall behaviour a large particle system.
It may, especially when you have a large number of particles with the
same spin bouncing off of an object. And what if the particles are
*supposed* to represent a large number of large objects?
As for the computational expense...it should, of course, be able to be
turned off. Maybe a simple "angular_forces on/off" flag.
Date: 18 Jul 2000 11:29:20
Message: <chrishuff-044107.10295218072000@news.povray.org>
In article <397### [at] hotmailcom>, Pabs <pab### [at] hotmailcom>
wrote:
> I think when considering *Solid Particles* or balls/spheres we are
> getting out of the _particle_ domain (aren't particles 1D not 3D) &
> into the physics of solid objects a bit more, which is a lot more
> complex than that of particles.
A 1D particle would be a point on a line, with no mass, no velocity,
etc. Not very useful.
And there is no reason to restrict particles to points...it is just that
inter-particle collisions aren't necessary or wanted in liquid
simulations.
Date: 18 Jul 2000 11:42:34
Message: <chrishuff-5C943C.10430318072000@news.povray.org>
In article <397### [at] peakeduee>, Margus Ramst
> Strange, it sometimes happens without running ipf previously
> (although that seems to be a sure-fire way). Haven't found the
> connection yet.
It still sounds like an uninitialized variable or a dangling pointer.
> I see. Actually, I think this is sufficient in most cases, especially
> with liquids.
Inter-particle collisions would probably just interfere with liquid-like
behavior.
> As for the "solid" particles - I don't think inter-particle collision
> and deflection would be at all expensive for spherical particles, and
> prohibitively expensive for most other shapes.
Actually, the only way I can think of doing it would also work for
arbitrary shaped objects(like meshes), but would be computationally
expensive for all of them. I suppose the cheapest one would be a
triangle, followed by triangle pairs, other simple, non-solid shapes,
and boxes. Spheres would definitely not be the cheapest.
I definitely need to learn more about rigid body dynamics before I try
this.
> What physical properties would be needed? Collision is easy,
> deflection and impact energy absorption too, friction I'm not so sure
> about... What else?
Impact energy absorption already exists, as elasticity. Friction
coefficient, shatter speed, geometry, etc. Internally, center of
gravity, angular velocity, a bounding box...
> BTW, I found an interesting page discussing sorting algorithms for
> particle systems (specifically kd-trees and Barnes-Hut trees). I saw
> no actual code, but pretty informative nevertheless. The URL is:
> http://physics.gmu.edu/~large/lr_forces/lr_general.html
Thanks, I will take a look...
