POV-Ray : Newsgroups : povray.unofficial.patches : 2 Problems with Megapov .5 Server Time
28 Nov 2026 01:06:44 EST (-0500)
  2 Problems with Megapov .5 (Message 6 to 25 of 25)
<<< Previous 5 Messages Goto Initial 25 Messages
Subject: Re: 2 Problems with Megapov .5
Date: 16 May 2000 22:58:04
Message: <39220abc@news.povray.org>
If something in DOS doesn't like the non-8.3 file name it doesn't "pass go",
at least nothing I've ever seen has any recognition of a file like
foobar~1.tga, so it can cause trouble.
Windows version would be fine like that though  ;-)  if you could surpass the
naming limit in POV.
"Nathan Kopp" <Nat### [at] Koppcom> wrote in message
news:3921f499$1@news.povray.org...
| DEPerere <per### [at] infomaniakch> wrote...
| > I suppose that if you have an animation of "Final_Frame=999", your name
| > should be of 3 letters max. At the end of the calculation of the frames,
| > you'll have a serial of frame with 6 characters and another serial with
| > those same characters and ending by "PP", also 8 characters.
| I hadn't thought of the truncation that
| occurs because of the 8 character limit in relation to animation files.  Any
| suggestions?  Could we forget about the 8-character limit (and simply append
| the "_PP" without truncating), or would that cause big problems for DOS?  Is
| there a better solution?
Date: 17 May 2000 00:38:34
Message: <0R0iOSdstqPqLfQ4yl=GvZPtm6li@4ax.com>
On Tue, 16 May 2000 21:21:08 -0400, "Nathan Kopp" <Nat### [at] Koppcom>
wrote:
> Is there a better solution?
What about outputing animation frames to an "archive file" of some
type (ie ZIP file)?  If you went this route, then there would only be
one file for all the frames, and its name would be easier to deal
with. The individual frames inside the archive could then have a pure
numerical sequence for their names. Something like 00000001.TGA could
be the first file name inside the archive, and 00000002.TGA could be
the second, and so on.
In case there is some objection to the compression of ZIP files,
remember that there is also provision for non-compressed ZIP files as
well. Of course, we could always use some other archive format. I just
mentioned this as an example case. If I'm not mistaken, DTA will work
with ZIP archives, for whatever that's worth.
Later,
Glen Berry
( Remove the "7" from 7no### [at] ezwvcom to email me. )
Date: 17 May 2000 01:34:39
Message: <39222D72.32A6F149@heday.freeservers.com>
> global_settings{
> post_process{overwrite_file}
Thank you. Thank you. Thank you. Thank you. Thank you. Thank you. Thank you.
I mean it.
H.E. Day
Date: 17 May 2000 06:37:56
Message: <qqmya59h37f.fsf@schlatt.fmi.uni-konstanz.de>
Glen Berry <7no### [at] ezwvcom> writes:
For compression I suggest using zlib. This is the same as gzip and it
has the advantage that zlib is already included in POV-Ray.
http://thomas.willhalm.de/ (includes pgp key)
Date: 17 May 2000 07:34:05
Message: <392283ad@news.povray.org>
Nathan Kopp <Nat### [at] koppcom> wrote:
: What you are saying is clear.  I hadn't thought of the truncation that
: occurs because of the 8 character limit in relation to animation files.  Any
: suggestions?  Could we forget about the 8-character limit (and simply append
: the "_PP" without truncating), or would that cause big problems for DOS?  Is
: there a better solution?
  Why do every platform have to suffer from the limitation of just one
platform? Why do Unix, Win9x, NT, Mac and any other platform have to use
a limited version which is intended to one platform: DOS?
  I would suggest some #ifdef's in the povray source code. If we are NOT
compiling for DOS, then just use as long file names as needed. If we are
compiling for DOS, then truncate and don't care about the consecuences.
Date: 17 May 2000 07:50:25
Message: <39228755.F640A210@stud.ntnu.no>
What about creating a folder with the scene name and place the numbered
files there?
sig
Date: 17 May 2000 09:14:56
Message: <39229AE6.8ABE3A6A@gci.net>
This one seems to make the most sense. Every platform
suports a directory. And even if you still stuck to
the 8.3 name for each of the files inside, going from
00000000.xxx to 99999999.xxx is just more frames than
I would want to render.
Mr. Art
> files there?
> sig
Date: 17 May 2000 14:59:00
Message: <3922F223.BA027B9D@merlin.net.au>
I agree, how many people use the MS-DOS version?
PoD.
Date: 17 May 2000 15:29:29
Message: <3922F26B.E689B3A6@pacbell.net>
Still quite a few using it from what I have heard. Chris Colefax
for example still uses the dos version for all of his include file
development work.
Date: 18 May 2000 00:51:21
Message: <x3EjOTSGDcxUi7SXcL8103twtI1O@4ax.com>
I would prefer Sigmund Kyrre Aas's idea of using a subdirectory for
animation frames output. If we are using DOS, then output the frames
into a subdirectory. The name of the subdirectory could be taken from
the "+O" command line parameter. Alternately, it could be named after
the parent POV scene file. Each frame in the subdirectory would be
sequentially named  from 00000001.tga, to a possible 99999999.tga
(assuming a tga output format.)
This could be done conditionally with #ifdef's in the source code, and
make it a DOS-specific feature. If we'd rather, it could also be an
option for all platforms, by adding an option to POV's ini file, or
command line. That way, the end user could pick the behaviour that
suited them best.
I don't really like truncation at all. It's simply an awkward
arrangement.
Later,
Glen Berry
Date: 18 May 2000 00:51:24
Message: <DXQjOWKotiTuz1wtb+odWK5pp8Gt@4ax.com>
I do. I imagine that there would be several others as well. I also use
the Windows version, but if I need to squeeze the most out of my
available system resources, then the DOS version is my choice. There
have been several scenes that I could render with the DOS version
entirely in RAM, while the WIN95 version went into swap quite early.
This isn't a problem with POV, of course, but a characteristic of
using WIN95. DOS simply demands far less of my computer's resources,
which leaves more for POV-Ray.
I hope there will always be a DOS version of POV-Ray. I also hope that
it never gets to be a neglected orphan.
Later,
Glen Berry
Date: 18 May 2000 03:53:24
Message: <3923a174@news.povray.org>
I have measured this, and (to my surprise) the MSVC compile of WinPov
renders a bit faster than any DOS compile when there's no need for swapping
or when both have to swap. Of course when the scene uses just as much memory
to need swapping in windows but not in DOS, there may be a difference in
favor of the DOS compile, but I think it's a rarer situation.
Date: 18 May 2000 03:54:33
Message: <3923a1b9@news.povray.org>
This sounds like a good solution as well.
Subject: DOS (was: Re: 2 Problems with Megapov .5)
Date: 18 May 2000 05:01:47
Message: <qqmog64nsec.fsf_-_@schlatt.fmi.uni-konstanz.de>
Have you tried Linux (or another free Unix)? I haven't compared it
directly in respect of POV-Ray, but I guess that it can be configured
to be almost as modest as DOS. A boot disc might be enough in your case.
Follow'up to povray.unix
Date: 18 May 2000 08:35:32
Message: <7OIjOV2O4TFDfWbrkies5Hgdc5j2@4ax.com>
Unless I'm mistaken, not everyone can run the MSVC compile. Doesn't
that require a recent model of Pentium processor to work properly?
This is *exactly* the situation I was referring to. It isn't nearly as
rare as you make it sound. It has happened to me several times.
Later,
Glen Berry
Date: 18 May 2000 11:34:36
Message: <39240CBE.DD6803E5@pacbell.net>
The MSVC pentium II compile can be run on any windows machine as
far as I know. I have a PI 200 mmx and it runs with no problem.
In fact even though it is optimized for a PII I still realize a
little faster performance over the watcom compile of the program.
The standard Windows distribution is compiled with watcom PII
optimized so there is little difference.
Date: 18 May 2000 12:14:50
Message: <39241DD6.58769B21@merlin.net.au>
> development work.
OK, I didn't think that many people would be using it and I didn't mean
any offence.
However there's no reason to limit all other platforms to 8.3 filenames
anyway.
The proposal to use an #ifdef seems the best solution.
PoD.
Date: 20 May 2000 06:02:34
Message: <392662ba@news.povray.org>
PoD <pod### [at] merlinnetau> wrote in message
news:3922F223.BA027B9D@merlin.net.au...
are NOT
we are
consecuences.
I do for one, and my other box doesn't even have windoze installed.
I would accept Warp's suggestion though.
Alf
http://www.peake42.freeserve.co.uk/
http://ourworld.compuserve.com/homepages/Alf_Peake/
Date: 23 May 2000 01:54:02
Message: <QhwqOdnmRebAvKiE9yONBkUb3ZoI@4ax.com>
Yes, but which #ifdef proposal? I hope you are refering to the one
that uses #ifdef to modify the DOS version to create subdirectories,
and place sequentially numbered files into it.
There was another proposal that involved #ifdef and filename
truncation/mangling, without subdirectory creation. I don't like that
idea nearly as well.
Later,
Glen Berry
Date: 23 May 2000 05:49:30
Message: <392a542a@news.povray.org>
Glen Berry <7no### [at] ezwvcom> wrote:
: Yes, but which #ifdef proposal? I hope you are refering to the one
: that uses #ifdef to modify the DOS version to create subdirectories,
: and place sequentially numbered files into it.
: There was another proposal that involved #ifdef and filename
: truncation/mangling, without subdirectory creation. I don't like that
: idea nearly as well.
  I really don't care which one as long as I get long filenames here :)
