![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
There's an example of it's use in the Patterns.htm file which is packaged with
MegaPOV patch.
It's basically a texture_map using a image as guidelines for the texture index.
"Fabian Brau" <fab### [at] umh ac be> wrote in message
news:388F30B7.B024EBDD@umh.ac.be...
| > > someone can tell me the difference between image_pattern and
| > > material_map? What can image_pattern do that material_map cannot?
| > > A simple example would be cool :)
| > > Thanks
| > > Fabian.
| > That was the very first question asked in this group when it was new.
| > I know because I asked it :)
| > The answer that Nathan gave me was -
| > This was made for Thomas Baier for use with 3DS to POV conversions. Let's
| > say you have two textures, and you want to use a black and white image
| > to fade between the two textures. Now lets say all you have to work with
| > is material_map. That would be a lot of work. If you only wanted to use
| > two textures (no fading between), that would be easy, but since material_map
| > uses indices and single textures, fading would be very difficult and you'd
| > have a lot of "average{ texture_map { [0.5 t1] [0.4 t2] }}" statements.
| > You could put it in a while loop, but that would still be a lot of extra
| > work.
| > Now, on the other hand, if you have image_pattern, you can use texture_map
| > instead of material_map, and just use the image as your image_pattern.
| > Simple. Fast. Saves memory (no need for 256 textures for those 256
| > shades of grey).
| Yes but one can use a gif with only 2 color define in the palette.
| But I feel that I don't understand yet this feature. I certainly need
| an example to see the advantage of this :)
| Thanks!
| Fabian.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sorry, I think I see what you're getting at and I didn't before. If I
understand it correctly a 'material_map' does not allow for manipulation of the
indices the way 'image_pattern' does.
You can specify a [value texture] format instead of just list textures out 0 to
255.
#declare IPp=
image_pattern { tga "belinda.tga" use_alpha}
texture_map {
[0 pigment {rgb <1,0,0>} ] // index 0
[.5 pigment {rgb <0,1,0>} ] // index 127
[1 pigment {rgb <0,0,1>} ] // index 255
} translate -.5 scale 1.5 // transformations
Where as 'material_map' goes like this:
#declare IPm=
material_map { tga "belinda.tga"
texture { pigment {rgb <1,0,0>}} // index 0
texture { pigment {rgb <0,1,0>}} // index 1
texture { pigment {rgb <0,0,1>}} // index 2
That is if I understand any of it right. You can include image_patterns inside
of image patterns apparently (nesting), material_maps don't seem to be capable
of that.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>255.
The other difference is that it fades from one texture to another if it gets
an intermediate index.
These are my opinions. I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Fabian Brau <fab### [at] umh ac be> wrote...
> Hello,
Advantages of image_pattern:
1) it is not limited to textures; it can be used directly with normals and
pigments
2) it can provide more than 256 entries
3) it fades between entries (especially useful when you have fewer than 256)
4) it can be nested
5) it follows a more standard format (like most other patterns), unlike
material_map, which is specialized
6) interpolation of the bitmap works better (see documentation on
material_map for an explanation of why interpolation is not effective with
material_maps)
-Nathan
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This gets edited into the patterns.htm file I have here immediately, thanks
Nathan.
Didn't know about the "more than 256" thing. Great, but I don't see how it
could. After all, if there's only a 256 color palette or one 8-bit plane of a
24bit image how does it apply textures to other than those specific areas of a
image then? A kind of interpolation?
"Nathan Kopp" <Nat### [at] Kopp com> wrote in message
news:388faaaa@news.povray.org...
| pigments
| 4) it can be nested
| material_maps)
| -Nathan
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's a good question. Is this addressed in Warp's VFAQ (I've got to
get myself a local copy)?
Alan - ako### [at] povray org - a k o n g <at> p o v r a y <dot> o r g
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Actually the question has not come up that many times. If it repeats
again in the future there may be a need to include it in the VFAQ but
-I- don't think it's needed quite yet.
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Bob Hughes <omn### [at] hotmail com?subject=PoV-News:> wrote...
thanks
> Nathan.
it
of a
of a
But let's just imagine that you're using a 36 bit PNG file as your input
file, instead of a 24 bit TGA. (now, I have not yet looked to see if POV
will support a 36 bit image internally, but if not now, it probably will in
the future)
-Nathan
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks All :)
I have played with image_pattern and well (I think :)) understand this!
Ok this is an interesting feature! For some use it is more interesting
than material_map for many reason!
Great job :)!
Fabian.
Fabian Brau wrote:
> Hello,
> Thanks
> Fabian.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <388faaaa@news.povray.org>, "Nathan Kopp" <Nat### [at] Kopp com>
> and pigments
And don't forget isosurfaces. Although you could use an image_map
pigment, image_pattern would probably be more versatile(or at least far
easier to get certain effects with).
Chris Huff
e-mail: chr### [at] yahoo com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
