POV-Ray : Newsgroups : povray.unofficial.patches : MegaPov 0.2 and demos Server Time
29 Mar 2026 14:43:12 EDT (-0400)
  MegaPov 0.2 and demos (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: MegaPov 0.2 and demos
Date: 12 Dec 1999 23:05:33
Message: <3854708d@news.povray.org>
Strange.  I just rendered it with no problems.  How widespread is this
problem?  I'll upload the EXE again (the EXE that I just used to
successfully render the scene).
-Nathan
Carl Bartels <cab### [at] bravo435chemmcgillca> wrote...
> Hi all,
>   There are a lot more things that work now, but when I run through
> Nathan's set of demos, the "splash.pov" demo get's stuck on creating
> bounding slabs.  It worked with the 0.1 version, but now it's been
> "creating bounding slabs" for about half an hour!
> Carl Bartels, Department of Chemsitry, Mcgill University, to reply to
> me,
> just kill a and 5 from the email name, Montreal, QC, cAnAdA
Date: 12 Dec 1999 23:15:48
Message: <385472ED.2835A009@mailbag.com>
Carl is using a Linux version.  I'm not sure if he's using the one he
made himself or mine.  Mine is dumping core for me in this file.  I
suspect some of the existing code has previously undiagnosed platform
dependencies that I haven't chased down yet.  I'll see what I can find
out.
-Mark Gordon
Date: 13 Dec 1999 09:54:57
Message: <385508BF.527D0A9E@bravo435.chem.mcgill.ca>
Actually, I was using my own compile at the time (under Linux).  I get
similar results with Marks version, I just hadn't had a chance to play
with it yet at that point last night.  The difference between the
behavior of my compile and Marks is that his kindly dumps core while
mine just sits there all locked up with the image half rendered (kill -9
is the only way to stop it.) I've found a few more test images that
it'll do this for, including the chess2 image that comes with the
official distribution (I figured I'd check to see if the traditional
images still worked.)
> out.
> -Mark Gordon
me,
Date: 13 Dec 1999 22:18:00
Message: <3855C6E1.6A259982@mailbag.com>
My version also hangs on chess2.pov, just to clarify.  I've had this
same experience.  Carl, are you using my binaries or compiling from
source?
-Mark Gordon
Date: 13 Dec 1999 22:36:21
Message: <3855BB33.9A2FDEB0@xenoarch.com>
I think i know the problem. (i'm
bad i never brought it up before
whip me beat me make me write bad
cheques. =} )
It has to do with the reflection blur.
but it crash dumps if you don't use fastmath
and loops if you do (dunno why just what
happened with me and i never tested the fix
with fast math)
what hapens is in the following snippet of code of reflect:
z = (FRAND() * 2) - 1;
t = FRAND() * M_PI * 2;
r = sqrt(1 - z*z);
x = r * cos(t);
y = r * sin(t);
Make_Vector(Jitter_Offset, x, y, z);
if FRAND ****EVER**** returns something larger then
1 (lets say its really bad and it return 1.01)
z = 1.01 * 2 - 1 = 1.02
r = sqrt( 1 - z*z) = sqrt( 1 - 1.004)
	= sqrt (- 0.004) = NAN
so your vector becomes corrupt and either
a test down the line fails and it trys to
acess a pointer that should be null
or a depth intersection test loops.
the fix is in texture.h
is to change
#define RNDMULTIPLIER ((DBL)0.000030518509476)
cause perl -e 'print 0.000030518509476*(2**15-1);'
1.00000000000009
so i change it to around:
#define RNDMULTIPLIER ((DBL)0.0000305185094759972)
(or round DOWN)
#define RNDMULTIPLIER ((DBL)0.000030518509475)
perl -e 'print 0.0000305185094759972*(2**15-1);'
1
perl -e 'print 0.000030518509475*(2**15-1);'
0.9999999999673251
> > out.
> > -Mark Gordon
> me,
Matthew Corey Brown                                         XenoArch
mcb### [at] xenoarchcom                             http://www.xenoarch.com
Date: 13 Dec 1999 22:46:39
Message: <3855CDAD.3063867E@mailbag.com>
> cheques. =} )
Tsk, tsk, tsk.  Thanks for bringing it up now, though!
-Mark Gordon
Date: 13 Dec 1999 22:55:13
Message: <3855BF9F.35B63D94@xenoarch.com>
> > cheques. =} )
> -Mark Gordon
took me a week to track down that bug in superpatch
did get me to learn gdb though. And has got
me to always use the -g flag, too bad its not
smart enough to know the symbols when you use
-finline-functions
Date: 14 Dec 1999 09:22:26
Message: <385652A1.60072E73@bravo435.chem.mcgill.ca>
My two tests consist of either using your binaries or compiling from
source with my own mangled version.  Basically I'm using the whole thing
as a learning experience.  Should have picked a smaller project to learn
on :P
BTW, I added the #define UNIX stuff to my unixconf.h file and I still
get that stricmp problem during linking, so I'm back to my original fix
until I figure out what's going on.
Mark Gordon wrote:
<snip  stuff about chess2.pov looping/crashing>
> source?
> -Mark Gordon
me,
Date: 14 Dec 1999 20:36:49
Message: <385700C2.6C8F58C3@mailbag.com>
> on :P
There's a suggested fix out there I mean to try out tonight...
Weird.  Was this before or after you independently discovered that you
need to #include "frame.h"?
-Mark Gordon
Date: 14 Dec 1999 21:20:07
Message: <3856FAD7.31EEB203@bravo435.chem.mcgill.ca>
Mark Gordon wrote:
> Carl Bartels wrote:
<snip>
This was before.  I gotta stop posting in different places.  It get's
confusing.
As for the single binary idea I  mentioned in the povray.unix group,
there was one point in a readme for the source where it suggested doing
make newunix ; make xwin ; make svga  to get all the binaries.  I don't
know if that was just with 3.02 or something more recent though.  This
has be noticed before, but I guess it was pretty low priority since it's
easy to work around it.
Another reason I wanted just one binary was because all three takes up
space.  But then, I only ever use x-povray so I guess it doesn't really
matter much.
me,
