POV-Ray : Newsgroups : povray.unofficial.patches : POV+for() Server Time
4 Jul 2026 03:17:52 EDT (-0400)
  POV+for() (Message 15 to 24 of 24)
Subject: Re: POV+for()
Date: 7 May 1999 09:42:34
Message: <3732dfba.0@news.povray.org>
And of course the condition of the while-loop may be dependant of
the calculations.
Date: 7 May 1999 10:07:26
Message: <3732e58e.0@news.povray.org>
On Thu, 06 May 1999 23:57:54 +0200, Ralf Muschall wrote:
>Nieminen Mika wrote:
>> #declare Index+=1;
>> #declare PosX*=1.5;
>> #declare PosY/=2;
>> #declare PosZ-=10;
>Agreed, but I think ++ and -- are not necessary.
>OTOH, I'd like to see the equality operator renamed from
>= to == (I always get bitten by writing something like
>#if(foo==bar)
>and then having to correct it).
Don't forget || and &&.
Date: 7 May 1999 14:40:47
Message: <37332710.4662E9C6@tiac.net>
>Because #declared identifiers in povray are not macros, while #defined
>identifiers in C are macros.
I have to admit my experience with C programming is extremely
limited. I guess I am confused as to what a "macro" is then.
I assumed that constants were macros. What makes #define a
macro and #declare not a macro? They seem to serve the same
purpose.
(There was actually a small discussion in povray.general entitled
"Macro tutorial" started by Andrew Cocker. I mentioned there that
#define and #declare are the same thing. If this is incorrect I
may have mislead Andrew and others.)
Date: 7 May 1999 15:35:16
Message: <37333264.0@news.povray.org>
This reminds me, there was a pure ASM rewite of POV 2.2 i think, crashed
everytime for me tho!!
GrimDude <vos### [at] arkansasnet> wrote in message
news:37321713.0@news.povray.org...
> Aw, what we have now is fine!
> I, too, get bit (heh) by things like this. At least you're not doing:
> loop:
> inc      ax,bitcount
> cmp    cx,ax
> jne      next_color
> inc      cx,01d
> jmp     loop
> Well, it's been awhile. :)
> GrimDude
Date: 7 May 1999 16:20:25
Message: <37333cf9.0@news.povray.org>
>purpose.
C's #define lets you do
  #define FOO(x,y,z) (x*32+y*z)
which you can then use like a function:
  printf( "%d", FOO(1,2,3) );
whereas #declare creates an actual instance of the specified
object and puts it in a "variable."  #declare is a lot like the
BASIC "Let" statement.
#macro is pretty much the same as #define, but with a little
different syntax.
Date: 8 May 1999 01:45:27
Message: <3733C2D9.FD4CB069@tiac.net>
Aah I see! Thanks for your help.
Date: 10 May 1999 09:43:10
Message: <3736d45e.0@news.povray.org>
: I have to admit my experience with C programming is extremely
: limited. I guess I am confused as to what a "macro" is then.
: I assumed that constants were macros. What makes #define a
: macro and #declare not a macro? They seem to serve the same
: purpose.
  A macro identifier is completely replaced by its value. For example:
#define PrintStatus printf("This is the status\n")
  Now you can type something like:
void Function(void)
{ PrintStatus;
  When parsing, the compiler substitutes the macro, so it converts it to:
void Function(void)
{ printf("This is the status\n");
  Povray #declared identifiers do _not_ work this way. For example, you can't
make this:
#declare MyTexture=texture { pigment { rgb 1 } }
sphere { 0,1 MyTexture }
  Povray does _not_ substitute the identifier "MyTexture" with its value, ie.
the result is _not_ this:
sphere { 0,1 texture { pigment { rgb 1 } } }
  Instead, povray will issue an error:
error: No matching } in sphere, texture identifier found instead.
  However, #macros work in povray exactly like #defines in C. You can make
this:
#macro MyTexture() texture { pigment { rgb 1 } } #end
sphere { 0,1 MyTexture() }
and it will work.
  You can make this same thing in C:
#define MyTexture() texture(whatever)
and when you type "MyTexture()" it will be substituted with
"texture(whatever)" (of course the parenthesis are obsolete here). You can
also give arguments the the #defined macro, just like to the povray
#macro.
  A better naming for the commands would be, for example, #let instead
of #declare and #define instead of #macro (although #macro is ok). Of
course it's too late now.
Date: 10 May 1999 17:14:35
Message: <37373FA1.9685D7BD@tiac.net>
Oh so that's why! I've tried to do exactly that, and that's the
error message I got.
Thanks
Phil
Date: 10 May 1999 17:27:21
Message: <3737429F.876797E8@tiac.net>
I was just looking through textures.inc and I found this:
#declare Shadow_Clouds =
texture {                          // The blue sky background for the
clouds
    pigment { rgb <0.196078, 0.6, 0.8> }
    finish { ambient 0.7 diffuse 0 }
texture {                          // The upper part of the clouds
    pigment { FBM_Clouds }
    finish { ambient 1.0 diffuse 0 }
texture {                          // The darker underside of the clouds
    pigment { FBM_Clouds  translate -0.15*y }
    finish { ambient 0.6 diffuse 0 }
This gives the error message you said it would, so I wonder why it's in
there?
Date: 11 May 1999 04:31:17
Message: <3737dcc5.0@news.povray.org>
You have to use texture identifiers this way:
sphere { 0,1 texture { MyTexture } }
