POV-Ray : Newsgroups : povray.unix : how can i run povray on a dual-core? Server Time
20 Mar 2026 23:08:19 EDT (-0400)
  how can i run povray on a dual-core? (Message 1 to 10 of 26)
Subject: how can i run povray on a dual-core?
Date: 9 Aug 2006 08:25:00
Message: <web.44d9d329da747bb7c9f9a50c0@news.povray.org>
hi,
I have to run benchmarks on a linux system ( suse 10.1 ) with a dual-core
processor ( Intel Core Duo 1.6 GHz ). I am currently using PovRay 3.7
beta14. how can I activate my second core? is there any parameter which i
can add to the command line << povray -benchmark >> ? thanks for your help!
scouti
Subject: Re: how can i run povray on a dual-core?
Date: 10 Aug 2006 04:58:29
Message: <44daf535$1@news.povray.org>
	There is no need to "activate" your second code.  By default POV-Ray 3.7
will use 2 render threads, which means both of your cores should be used at
nearly 100% for rendering (if nothing else is taking up cpu power).  You might
check this using the 'top' command.
	There is a new command-line option +wtN (N an integer) to set the number
of "work threads" (number of threads used for rendering).  Increasing this
number from 2 (the default, as mentioned above) might increase or decrease
the rendering speed depending on many factors.
	- NC
Date: 10 Aug 2006 06:49:50
Message: <44db0f4e@news.povray.org>
  Please cite the source where you got this info.
  As far as I know, the official behaviour is to use 2*cores threads.
Date: 10 Aug 2006 07:50:01
Message: <web.44db1c3cfdfbba3fc9f9a50c0@news.povray.org>
:D
Date: 10 Aug 2006 08:15:00
Message: <web.44db220afdfbba3fc9f9a50c0@news.povray.org>
thanks very much for your help!
Date: 10 Aug 2006 08:39:46
Message: <44db2912$1@news.povray.org>
Not on Unix as there is no fully portable way to determine the number of CPU
(cores). Only on Windows and Mac OS the number can be determined in a
unified manner. Every Unix uses its own way to do it, i.e. there is no
standard Posix way of getting this information that works everywhere.
	Thorsten
Date: 10 Aug 2006 12:18:43
Message: <44db5c63@news.povray.org>
  Ah, that explains it. I didn't know there was such a difference between
the windows and the linux versions.
  OTOH, I'm pretty sure it would be possible to retrieve this information
in linux. Perhaps some "#ifdef LINUX" code could be added for this?
Date: 14 Aug 2006 01:30:00
Message: <web.44e00971fdfbba3f4f8f41de0@news.povray.org>
How should this possible ?
A normal user have only a limited bandwith of CPU-power and this is far
away from 100% CPU power. Because a program/user wich gets realy 100% of
the  CPU power would block the computer for all other programs/users.
And this can not be allowed in a Multiuser-System.
(btw. web-severs handles this in the same way, by a bandwith-control).
So the "top" command shows only the capacity of the User-Bandwith....not
the absolute CPU usage.
You can verify this very simple. Go to the "root-mode" and start
provray with the highest possible "nice value" of the privileged mode.
In this mode povray gets *much more* CPU-power than a normal user can
ever get....this reduce on the one hand the Rendering-time,
on the other hand, it is nearly impossible to do any other things
one this computer during the render-time.
Date: 14 Aug 2006 02:17:50
Message: <pan.2006.08.14.06.17.38.878423@nospam.com>
> ever get
Actually, you can renice user processes so they run at the highest
possible level; the behaviour in Linux is that a non-root user can set the
niceness level to a higher value than it's currently set.
There also can be a tradeoff if the processes impacted by running a
program at the highest priority affect processes that control disk i/o and
such - you can actually lose performance, depending on the process
(probably not so much the case with POV-Ray, but with things like bulkload
of a local LDAP server, the bottleneck tends to be the I/O channels rather
than processing, so pushing the niceness level to an 'unfriendly' level
can actually degrade overall performance of the bulkload).
Jim
Date: 14 Aug 2006 08:39:05
Message: <44e06ee9@news.povray.org>
	IIRC the 'top' utility reads the /proc filesystem: it should thus give the
exact same stats whether you are root or a non-privileged user.  (Otherwise, top
would be able to report only the current user's jobs, not all jobs.)
	So I guess your claim is not true.  I'd appreciate if you have pointers
to prove me wrong.
> ever get....
	Could you please backup this second claim with numbers?
	On my monocore machine (AMD Athlon XP), running POV-Ray 3.6.1(a) or 3.7.0.beta.14(b)
as root on a few scenes(c) with either default scheduling priority (nice 0) or highest
priority (-20) and no other cpu-demanding job running, I hardly get one second
speedup.
	So with those limited tests I do *not* observe what you claim above.
	- NC
(a) unofficial build prepared with icc 8.1.
(b) the binary is compiled with icc 9.1; tested using 1 or 2 render threads, see
below.
(c) scenes/advanced/mediasky.pov and grenadine.pov; more are being tested, but the
result
should not depend on the scenes nor the binaries.
===== mediasky.pov
*** 3.7.0.beta14
2 threads,   0:  115.803u 0.012s 1:56.13 99.7%   0+0k 0+0io 0pf+0w
2 threads, -20:  115.091u 0.028s 1:55.36 99.7%   0+0k 0+0io 0pf+0w
1 thread,    0:  115.703u 0.000s 1:56.03 99.7%   0+0k 0+0io 0pf+0w
1 thread,  -20:  115.107u 0.004s 1:55.34 99.7%   0+0k 0+0io 0pf+0w
*** 3.6.1
   0:  118.947u 0.028s 1:59.10 99.8%   0+0k 0+0io 0pf+0w
-20:  118.023u 0.008s 1:58.06 99.9%   0+0k 0+0io 0pf+0w
===== grenadine.pov
*** 3.7.0.beta14
1 thread,    0:   60.591u 0.056s 1:01.06 99.3%    0+0k 0+0io 0pf+0w
1 thread,  -20:   59.947u 0.036s 1:00.24 99.5%    0+0k 0+0io 0pf+0w
