POV-Ray : Newsgroups : povray.unix : Knoppix and povray Server Time
28 Oct 2024 14:18:54 EDT (-0400)
  Knoppix and povray (Message 1 to 5 of 5)
Subject: Knoppix and povray
Date: 13 Jul 2005 21:41:57
Message: <42d5c2e5$1@news.povray.org>
I posted an "idea" about povray and knoppix and was suggested to file a bug
report.  It's #2 for the 4.0 DVD!
http://www.knoppix.net/wiki/Bugs/4.0
http://www.knoppix.net/forum/viewtopic.php?p=88147#88147
I may have done a service to povray or I may have tried to remake it in my
own image in a very annoying way.  Maybe both.
Subject: Re: Knoppix and povray
Date: 14 Jul 2005 14:50:01
Message: <web.42d6b2f8ee18cbbfa0c272b50@news.povray.org>
I doubt if you did any disservice, and if Knoppix adds PovRay so it works
out of the box, then you've probably accomplished something, but I don't
think its a Knoppix problem.  I had the same issue with Slackware.
KPovModeler seems to ship with KDE and get installed with it whether there
is a PovRay available or not. Since I was installing PovRay anyway, no
biggie, but it was annoying to have it on the menu but not able to use it.
(And after trying KPovModeler I decided it only had a couple useful tools
anyways)
RG
Date: 9 Aug 2005 20:15:00
Message: <web.42f946e0ee18cbbf44365ed70@news.povray.org>
> anyways)
I believe the problem is that the POV-Ray redistribution licence is
_slightly_ incompatable with the DFSG [Debian Free Software Guidelines] --
which makes distribution slightly difficult; haven't you noticed how there
isn't a pov-ray package for Debian that is any newer than 3.5?  Debian
_does_ have a tendency to try and maintain patches and build it's own
packages from source...
That said, I don't think Ubantu would mind distributing the latest and
greatest POV-Ray packages; it has [among other things] mplayer binaries,
and everything else under the sun, it seems...  -- Thing is, IIRC, Ubantu
packages don't always work on Debian; I don't use Ubantu myself.
AFAIK, it might be easier for Knoppix to use one of those dynamic
install-in-ramdisk scripts for POV-Ray (to get around distribution issues)
and download the latest POV-Ray from the site, and automate the install for
the user.  Doesn't sound too hard [provide a GUI, check for connection,
download, untar/gz, execute install under sudo, execute install user/kde
under sudo].  Would allow you to squeeze it onto the Knoppix CD too,
possibly.
Date: 9 Aug 2005 23:15:09
Message: <42f9713d@news.povray.org>
Hmm...  I primarily use RedHat Fedora, but "dabble" with other distros,
including Debian 3.1 (Sarge).  I simply downloaded the Linux POVRay
package directly from povray.org and did a normal install with that.
Version 3.6.1 installs properly and runs fine.  Although I confess I
haven't done anything more than a few test renders (from the standard
"Scene" examples), simply to verify that it does work.
Of course, I can't say anything about Knoppix, but 3.6.1 is okay with
standard Debian.
      -=- Larry -=-
Date: 10 Aug 2005 04:06:00
Message: <42f9b568@news.povray.org>
Actually, the reason seems to be more the lack of a competent maintainer
with sufficient time.  For example the "POV-Ray 3.5" Debian distributes
contains broken patches and untested code.  And before that they distributed
(and still do it seems) a completely outdated POV-Ray 3.0 with completely
obsolete patches added to it, i.e. the macro patch - obsolete since POV-Ray
3.1 and not even remotely compatible with any official version of POV-Ray.
In short, the POV-Ray versions Debian distributes are basically useless.
Unfortunately, pointing this out to the current Debian maintainer (see the
bug reports) had no effect whatsoever :-(
As such, it can only be recommended to use the official POV-Ray rather than
the broken versions Debian distributes, even in case of POV-Ray 3.5 or
POV-Ray 3.0!
	Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Visit POV-Ray on the web: http://www.povray.org
