POV-Ray : Newsgroups : povray.unix : Pyvon - Multilanguage Server Time
31 Oct 2024 08:18:12 EDT (-0400)
  Pyvon - Multilanguage (Message 1 to 10 of 16)
Subject: Pyvon - Multilanguage
Date: 3 Sep 2002 13:13:46
Message: <3D74ECFC.8040002@caramail.com>
It now supports 4 different languages (so far) : French, English,
German, Italian.
Thanks to the translators who help me.
There is room for 3-4 more
Is there a spaniard around here to help me ?
Something else :
When I try to render a file with a space in it I get an error:
povray +iJupiter test.pov +w320 +h240 -f
I get 'Could not find file test.pov
I tried
povray +iJupiter\ test.pov...
and
povray +i'Jupiter test.pov' +w320 +h240 ...
but that was useless.
Any idea what's going wrong ?
Is it only on my system or a common problem ?
Thanks
Fabien
Subject: Re: Pyvon - Multilanguage
Date: 3 Sep 2002 14:32:10
Message: <3D750029.5090205@free.fr>
> I tried
> and
	I don't know if it's a "missing feature" in the command line
parsing, but a least you can overcome that problem by asking POV-Ray
to read the script from stdin. I saw this in the code, I don't know
whether it's documented or not.
cat Jupiter\ test.pov | povray +i- +d +anyotheroptions
or
cat Jupiter\ test.pov | povray +istdin +d +anyotheroptions
	Hope this helps.
Date: 3 Sep 2002 14:36:32
Message: <3D750130.2040004@free.fr>
Quoting myself:
> or
	But hey, then there's the same problem with the filename
for the output image, that you must specify since POV-Ray cannot
get the basename from a pipe...
	Have to find another solution or the correct syntax for
space-including arguments.
Date: 4 Sep 2002 14:05:31
Message: <slrnanagvf.14v.steev@hot.pl>
On my system it doesn't work neither...
> Fabien
  ________ 170. Zgodnie z Ewangelia sw. Mateusza
_/ __/ __/ wszyscy czytaja "Gell-Manna".
 \__ \__ \_______________________________________________________________
Date: 4 Sep 2002 16:40:08
Message: <3D766EF9.6040205@caramail.com>
I think you were the one who told me about this bug.
We have to search what we have in common.
Linux mandrake 8.2, Kde 2.?, run povray from Konsole.
I don't think of anything else for the moment.
Fabien
What system do you have ?
>>Fabien
Date: 4 Sep 2002 23:45:15
Message: <3D76D3A1.9040908@netscape.net>
> I tried
> and
I've been trying different ways to get povray to accept a filename
with a space in it as an argument too but with no luck. I get the
same kind of message that you're getting.
I am running the Linux version (my own compiled one) 3.5 on RedHat
7.1, KDE 3.01 and I am also running it from Konsole. I tested it
at a text only console though and it did the same thing so I doubt
it's KDE related. I suspect it's just something to do with the way
povray is parsing the command line arguments. But have not tested
this suspicion out nor looked at the source code yet. I'm hoping
to find some time to do that soon.
-Roz
Date: 5 Sep 2002 16:56:42
Message: <slrnanfgsv.287.steev@hot.pl>
> Fabien
Red Hat 7.2, Gnome 1.? and povray started by pyvon.
_/ __/ __/ John Steinbeck
Date: 6 Sep 2002 17:01:38
Message: <3D7916F9.6090809@caramail.com>
Does povray deal correctly with spaces in the name of the scenes when
you start it from a console ?
As far as I am concerned, the problem does not come from Pyvon.
Fabien
>>Fabien
Date: 6 Sep 2002 20:38:44
Message: <3D794AEC.5090301@netscape.net>
> Fabien
The Windows version has the same problem. I ran pvengine.exe from
a DOS prompt, passing it scene file names with spaces in the name
and I got the same sort of error message. I tried surrounding the
filename in quotes but that didn't solve the problem.
Attempting to run a scene file with one or more spaces in the name
in a Linux console does the same thing.
It's not Pyvon, it's POV-Ray. I still have MegaPOV (xmegapov) on
my system and it also has the same behavior. I don't know if it's
really that big of a deal that POV-Ray doesn't handle filenames
with spaces in it nicely on the commandline.
Maybe just place a note in your readme.txt file and/or on your
web site about this small issue with pov.
-Roz
Date: 6 Sep 2002 23:58:17
Message: <3D7979B2.2080709@netscape.net>
> Fabien
I found a fix for this problem. Instead of passing a space containing
filename on the command line with the +i switch, use Input_File_Name=...
For example, instead of a line like this:
povray +i"test file.pov" +a0.2 +w800 +h600
Use a line like this:
povray Input_File_Name="test file.pov" +a0.2 +w800 +h600
Hope this helps you guys out!
-Roz
