POV-Ray : Newsgroups : povray.unix : Pyvon 0.9 Server Time
31 Oct 2024 10:21:42 EDT (-0400)
  Pyvon 0.9 (Message 1 to 10 of 13)
Subject: Pyvon 0.9
Date: 7 Aug 2002 17:28:45
Message: <3D51906C.9010708@caramail.com>
http://pyvon.sourceforge.net
I have fixed all the bugs that I know of.
There may be a few left. -> I called that release 0.9.
It's going to give me some margin before 1.0 if you can find any bugs.
Main features added :
- Highlights the line in the editor in which there is a problem when POV
returns an error.
- Full syntax highlighting is now implemented (even multiline and single
comments)
- Fixed about thirty bugs which were still lying around.
It's now the only editor I use for POV with Linux.
Subject: Re: Pyvon 0.9
Date: 7 Aug 2002 21:46:55
Message: <1684007.fWIpRgLCUv@3-e.net>
<posted & mailed>
[SNIP]
I got this error (below) when I tried to run it, the last version worked
fine with the streams terminal. What did you change?
Traceback (most recent call last):
  File "res.py", line 16, in ?
    os.system("xterm -cr blue -bg black -fg white -C -title streams
-geometry %dx%d+0+%d -e python c51.py" % (largeur,hauteur,pos_vert) )
NameError: name 'largeur' is not defined
Your connection failed because: backup tape overwritten with copy of system
manager's favourite CD
Date: 8 Aug 2002 12:05:10
Message: <3D529615.1020207@caramail.com>
Hum last minute changes are no good. The patch I sent you should do.
The new file I uploaded on the Pyvon site is fixed whatever your screen
resolution is ( 640x480 -> 1600x1280 and over )
Sorry for the trouble
Daniel Matthews wrote:
> <posted & mailed>
> [SNIP]
Subject: Other question to the Gurus
Date: 8 Aug 2002 12:10:00
Message: <3D529737.6020702@caramail.com>
How do you customize colors in xterm. I read the man page and tried
rgb:FF/FF/BA but it does not work the way I want.
Could you give me a line example for xterm ( and while I am at it for
Eterm and Konsole)
Thanks.
Fabien
> returns an error.
> comments)
Date: 8 Aug 2002 12:13:54
Message: <3D529968.8060402@web.de>
While trying to render I got this message:
/bin/sh: /home/fabien/povray-3.5/povray_athlon: Datei oder Verzeichnis
nicht gefunden
Exception in Tkinter callback
   File "/usr/lib/python2.2/lib-tk/Tkinter.py", line 1292, in __call__
     return apply(self.func, args)
   File "/usr/lib/python2.2/lib-tk/Tkinter.py", line 436, in callit
     apply(func, args)
   File "c51.py", line 889, in tempo
     fd=open("err.txt")
IOError: [Errno 2] No such file or directory: 'err.txt'
-> /home/fabien/povray-3.5/povray_athlon
Maybe no good default povray binary :-)
Sebastian H.
Subject: Re: Other question to the Gurus
Date: 8 Aug 2002 13:20:13
Message: <3d52a84c@news.povray.org>
  I don't know if the colors can be customized (without having to compile
xterm), but at least they can be configured with command-line parameters
with aterm, which is a rather good rxvt clone. Worth trying.
Date: 8 Aug 2002 14:12:17
Message: <3D52B480.9A58BF29@scripps.edu>
> Eterm and Konsole)
> Thanks.
> Fabien
> > returns an error.
> > comments)
On IRIX 6.5 I use this command: xterm -font screen15 -back black -sl 200
which allows you to specify the background colour. I thin you can use the -fg
color or -cr color flags to change the color of the text.
Hope this helps.
mike
Michael DiDonato, PhD
The Scripps Research Institute
Department of Molecular Biology
Maildrop MB4
10550 North Torrey Pines Road
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
http://www.scripps.edu/~didonato
Download 'us-ascii' (2 KB)
Date: 8 Aug 2002 14:14:27
Message: <3D52B503.1853EFBD@scripps.edu>
> Eterm and Konsole)
> Thanks.
> Fabien
> > returns an error.
> > comments)
Actually the -cr flag changes the colour of the cursor only. The -fg flag
changes the colour of the text as well.
Mike
Maildrop MB4
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
Date: 8 Aug 2002 15:45:15
Message: <3D52C9AA.ABF5FCA6@caramail.com>
I meant that I want different colors than those offered by the terminal
: black, white, yellow...
The best would be to be able to give colors as in POV rgb <0.7,0.7,0.4>
Fabien
>> for
>> Eterm and Konsole)
>> Thanks.
>> Fabien
>> bugs.
>> when POV
>> > returns an error.
>> single
>> > comments)
> 200 which allows you to specify the background colour. I thin you can
> use the -fg color or -cr color flags to change the color of the text.
> Hope this helps.
> mike
> Maildrop MB4
> La Jolla, CA, 92037
> Tel: (858) 784-9261
> FAX: (858) 784-2277
Date: 8 Aug 2002 17:20:00
Message: <3D52DFE1.13DA5D50@caramail.com>
You have to tell Pyvon where is the executable.
Use 'Options / povray location'
This path is from the pyvon.ini file taken from my hard drive.
You have to set your path to the POV location
I definitely have to save that pyvon.ini into ~home, not into the directory
where Pyvon is extracted.
For those who already have pyvon.ini, I advise to back it up and restore it
after the extraction of the tgz archive.
I must have disabled the option that checks whether the executable path found
in pyvon.ini exists on the hard drive.
I'll see to that.
Thanks for the comment
Fabien
> nicht gefunden
>      apply(func, args)
>      fd=open("err.txt")
> Regards,
> Sebastian H.
