POV-Ray : Newsgroups : povray.unix : Compiling 3.5 source on Linux also fails Server Time
28 Jul 2024 08:20:42 EDT (-0400)
  Compiling 3.5 source on Linux also fails (Message 1 to 10 of 19)
Subject: Compiling 3.5 source on Linux also fails
Date: 1 Aug 2002 13:01:41
Message: <3D496974.4060507@free.fr>
PovRay-3.50a (as of 2002-08-01)
gcc-3.1
Just like the message reported before, I also have compiling trouble,
but here as soon as the first .cpp file:
atmosph.cpp: In function `void do_rainbow(RAY*, INTERSECTION*, float*)':
atmosph.cpp:502: `max' undeclared (first use this function)
atmosph.cpp:502: (Each undeclared identifier is reported only once for each
    function it appears in.)
atmosph.cpp: In function `double constant_fog(RAY*, double, double, FOG*,
    float*)':
atmosph.cpp:688: `min' undeclared (first use this function)
make[1]: *** [atmosph.o] Error 1
I suspect many other problems  ;op
BTW, compilation obviously is made _without any_ optimization
(even no -O2 or -O3). It would be nice to add tests for compiler
flags into configure.in. I can provide a macro for that (which works
with the newer autoconf-2.53). If the binary distributed was compiled
in similar conditions, of course it will be MUCH SLOWER than anything
else (e.g. windows binary)
Thanx for releasing the sources anyway !!
- N.C.
Subject: Re: Compiling 3.5 source on Linux also fails
Date: 1 Aug 2002 13:34:08
Message: <3d49710f@news.povray.org>
> gcc-3.1
It works with gcc-2.x. To get it compiled with 3.1 you need to add
something like
template<class T> const T& max(const T&a, const T&b)
return (a<b) ? b: a;
template<class T> const T& min(const T&a, const T&b)
return (a<b) ? a: b;
to an appropriate place. I chose frame.h.
I think the official binary had -O2 or -O3 because my first recompilation
resulted slower.
- Micha
http://objects.povworld.org - the POV-Ray Objects Collection
Date: 1 Aug 2002 15:32:04
Message: <3d498cb3@news.povray.org>
No, no! Don't kludge it. You can never know whether the STL implementations
are faster than that.
  The correct answer is to put 'using namespace std;' in config.h. (I don't
know why this hasn't be done already.)
Date: 1 Aug 2002 16:13:14
Message: <3d499659@news.povray.org>
>   implementations
>   don't
Yep, of course you are right. I just could not find a reference to min/max
in STL in my documentation. To get it working it is already enough to add
using std::max;
using std::min;
into config.h. I even wondered why this wasn't in STL :D
- Micha
Date: 1 Aug 2002 20:11:37
Message: <3d49ce39@news.povray.org>
Micha Riser inspired the electrons to say:
>>   implementations
>>   don't
Oh no! No! please, don't....... Okay, importing the whole std namespace
globally is ugly and was never recommented in any documentation I read,
also I personally never do that too. I just import either locally or import
explicitely.
> using std::max;
> using std::min;
Exactly ;)
Take a closer look.
I did it and found it in /usr/include/g++-v31/stl_algobase.h beginning at
line 130. Look there, the Standard C directives min and max gets removed,
and then replaced by its template functions and some specializations.
Cheers,
Christian Parpart.
p.s.: I also posted that in the .general feed. Hugh? I just looked here
later ;)
Date: 1 Aug 2002 21:53:52
Message: <3d49e630@news.povray.org>
> explicitely.
  I know all this (haven't you read my whinings in povray.off-topic about
the issue?-) ).
  Of course the most correct way of using it would be std::min and
std::max. However, I only suggested a quick fix which requires a minimum
amount of modification of the source code without modifying the result
in any way.
  Since POV-Ray is not well-structured C++, it doesn't really matter if
you dump everything to global visibility... :)
Date: 2 Aug 2002 09:01:22
Message: <3D4B2B40.5000206@chesapeake.net>
> using std::max;
> using std::min;
> - Micha
Is there any special place in config.h that those two lines go?
I don't understand the structure of the file's contents and could
use a few pointers on this :)
Thanks
Date: 2 Aug 2002 10:19:12
Message: <3d4a94e0@news.povray.org>
Mr Art inspired the electrons to say:
>> min/max in STL in my documentation. To get it working it is already
>> enough to add
>> using std::max;
>> using std::min;
>> - Micha
just put it below #include <algorithm>. That's okay ;)
Date: 2 Aug 2002 12:37:04
Message: <3D4AB5D1.40404@web.de>
Yes thanks, too.
But I got an other problem here.
When compiling without any optimization (just ./configure, make)
I got:
g++  `if [ "Xgcc" = "Xgcc" ]; then echo "-Wno-multichar"; fi ` -static
-I/usr/X11R6/include -o povray  atmosph.o bbox.o bcyl.o benchmark.o
bezier.o blob.o boxes.o bsphere.o camera.o chi2.o colour.o colutils.o
cones.o csg.o discs.o express.o file_pov.o fncode.o fnintern.o
fnpovfpu.o fnsyntax.o fpmetric.o fractal.o function.o gif.o gifdecod.o
hcmplx.o hfield.o histogra.o iff.o image.o interior.o isosurf.o
jpeg_pov.o lathe.o lbuffer.o lightgrp.o lighting.o matrices.o media.o
mesh.o normal.o objects.o octree.o optin.o optout.o parse.o parsestr.o
parstxtr.o pattern.o pgm.o photons.o pigment.o planes.o png_pov.o
point.o poly.o polygon.o polysolv.o pov_mem.o povms.o povmscpp.o
povmsend.o povmsrec.o povray.o pov_util.o ppm.o prism.o quadrics.o
quatern.o rad_data.o radiosit.o ray.o render.o renderio.o sor.o
spheres.o sphsweep.o splines.o statspov.o super.o targa.o texture.o
tiff_pov.o tokenize.o torus.o triangle.o truetype.o txttest.o userdisp.o
userio.o vbuffer.o vlbuffer.o warps.o unix.o povxlib.o -L/usr/X11R6/lib
-ltiff -ljpeg -lpng -lz -lm  -lX11
/usr/X11R6/lib/libX11.a(XlcDL.o): In function `try_both_dlsym':
XlcDL.o(.text+0x111): undefined reference to `dlsym'
XlcDL.o(.text+0x136): undefined reference to `dlsym'
/usr/X11R6/lib/libX11.a(XlcDL.o): In function `open_object':
XlcDL.o(.text+0x60e): undefined reference to `dlopen'
/usr/X11R6/lib/libX11.a(XlcDL.o): In function `close_object':
XlcDL.o(.text+0x684): undefined reference to `dlclose'
collect2: ld returned 1 exit status
make[1]: *** [povray] Fehler 1
Please don't kill me I'am no programmer but can anyone give me a hint?
(When using --without-x I get even more errors...)
Sebastian H.
Date: 2 Aug 2002 13:32:54
Message: <3d4ac246$1@news.povray.org>
Open up src/Makefile and find this line:
LDFLAGS = -static -I/usr/X11R6/include
(could be a bit different but the LDFLAGS is the important line)
change it to:
LDFLAGS = -static -I/usr/X11R6/include -ldl
(note: added -ldl)
Try that and see if it works.
--josh
"Sebastian H." <seb### [at] webde> wrote in message
news:3D4### [at] webde...
> Yes thanks, too.
> I got:
> Sebastian H.
