POV-Ray : Newsgroups : povray.unix : automated splicing of images after faking SMP Server Time
2 Jul 2025 07:21:41 EDT (-0400)
  automated splicing of images after faking SMP (Message 1 to 10 of 13)
Subject: automated splicing of images after faking SMP
Date: 8 Sep 2000 10:55:29
Message: <39B8FD9F.203F77B3@esupportnow.com>
Does anybody know of a command line util that will cat together two
images? I want to create a script that will render my image with two
povray processes and put them together without having to open up the
gimp and kludge them together by hand.
OR, even better, is there an image format (bmp, tga, whatever) that
would cat together?
Thanks,
Derek
Subject: Re: automated splicing of images after faking SMP
Date: 8 Sep 2000 11:01:07
Message: <slrn8ri0i7.19f.ron.parker@fwi.com>
>would cat together?
Try "man pnmcat"
If you don't have the netpbm utilities, look around on Freshmeat; you're
bound to find them.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 8 Sep 2000 12:53:06
Message: <39B91972.B28498DF@rap.ucar.edu>
Just use pvmpov and spawn two instances - one for each CPU and you won't
have to paste them together at all.
- Steve
> would cat together?
> Thanks,
> Derek
EMAIL: (h) ste### [at] badcheesecom  WEB: http://badcheese.com/~steve
       (w) swe### [at] rapucaredu
           ste### [at] mailcom
Date: 8 Sep 2000 13:26:16
Message: <39B920F7.937174CE@esupportnow.com>
That'd be an option, but I'm using UniMegaPov,  so I think I'll stick with
Ron's suggested pnm utilities.
Derek
Date: 8 Sep 2000 17:17:49
Message: <39B95776.1AB7A0E8@club-internet.fr>
If MegaPov 0.5a is enough for your needs, could you please check:
http://www.wozzeck.net/images/pmp
... and report bugs!
I am currently fighting against some remaining radiosity problems, and
hust added a new error reporting mechanism to avoid having master task
waiting for slaves which already have exited on error.
I will release a new build as soon as I'm feeling better with radiosity.
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
\/\/ \__/ /_ /_ |__ \_ |\
Date: 9 Sep 2000 11:11:33
Message: <39BA52E9.BD8EED47@esupportnow.com>
How does this compare to the RAM use of running 2 instances of POV? 2 instances
of POV seem a little wasteful, but at least a few megs of that ram is shared.
My SMP box only has 128 right now.  : )
Derek
>       __  __ __  __  _
> |  | /  \  /  / |_  /  |/
Date: 9 Sep 2000 16:39:59
Message: <39BAA014.5EC1CBC8@club-internet.fr>
I just upgraded to 256 because my IRTC entry features a lot of
objects...
To be more precise, there is a little overhead as long as you do not use
radiosity. If you do, be aware that there are not 2, but 3 octrees,
because the master process builds its own one as part of the sharing
mechanism. So, except if you have several tens megabytes in your octree
(which is not very likely), you won't see a big difference.
The main overhead concerns rendering time, which is higher than what you
would get with an accurately split rendering across your processors. On
my latest IRTC entry, rendering speed with 2 processors was about 185%
of the speed with one processor. But OTOH you will not have to worry
about load balancing, PVM will do it for you.
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
Date: 9 Sep 2000 18:09:36
Message: <39bab520@news.povray.org>
D. Stark <dms### [at] esupportnowcom> wrote:
: Does anybody know of a command line util that will cat together two
: images? I want to create a script that will render my image with two
: povray processes and put them together without having to open up the
: gimp and kludge them together by hand.
  I used this kind of unioning image parts in my distribution script. It
requires that the image parts are in uncompressed targa format.
mv ImagePart00000.tga $IMAGE
for FILE in ImagePart?????.tga
do
    tail +19c $FILE >> $IMAGE
done
Date: 12 Sep 2000 13:26:38
Message: <39BE6723.E0AEEC8C@esupportnow.com>
So that's a 19-byte offset on a targa? hrm, learned something new today. can
I have a peek at your whole script? I haven't finished mine, and I'm not
opposed to better ideas.
Thanks,
Derek
> do
> done
Date: 13 Sep 2000 04:04:55
Message: <39bf3527@news.povray.org>
Note: All the computers must have a common file system (that is, they all
see the same directory where you are starting the rendering) and you should
be able to rsh to all of them without password prompting. These usually
occur only in local networks (so this script cannot be used, at least not
unmodified, to distribute the rendering over the world).
  Put the names of the machines in the HOSTS variable at the beginning and
the correct number of them in the HOSTSCNT (I know that it may be possible
to automatically count the number of words in HOSTS but I was lazy and didn't
search for info about how to do it).
#!/bin/zsh
POVEXEC=$HOME/povray/xmegapov
ROWSPERHOST=17
HOSTSCNT=3
HOSTS=(machine1 machine2 machine3)
### If this is a child process
if [ "$1" = "__SubProc__" ]
then
    echo "### Subprocess at `uname -n` starting rendering. (`uptime | sed
's/^.*average: //'`)"
    PART=$2
    FILE=$3
    WIDTH=$4
    HEIGHT=$5
    shift 5
    let STARTROW=PART*ROWSPERHOST
    while [ $STARTROW -le $HEIGHT ]
    do
	let ENDROW=STARTROW+ROWSPERHOST-1
	echo `uname -n` rendering lines $STARTROW to $ENDROW
	$POVEXEC -i $FILE $* -w$WIDTH -h$HEIGHT +sr$STARTROW +er$ENDROW -d -p -v +ft -o
ImagePart`printf "%05i" $STARTROW` >&/dev/null
	let STARTROW+=ROWSPERHOST*HOSTSCNT
    done
    echo "### `uname -n` done."
    exit
fi
### Else this is the main process
if [ "$3" = "" ]
then
    echo "Usage: $0 <pov-file> <width> <height> [<additional pov options>]"
    exit
fi
PART=0
for HOST in $HOSTS
do
    rsh $HOST "cd `pwd`; $0 __SubProc__ $PART $*" &
    PART=$[PART+1]
done
wait
echo "Joining image parts..."
if [ `echo $1 | grep -c '\.pov$'` = 1 ]
then
    IMAGE=`echo $1 | sed 's/\.pov$/.tga/'`
else
    IMAGE="$1".tga
fi
do
done
rm ImagePart?????.tga
echo "Done."
