POV-Ray : Newsgroups : povray.unix : Re: Can't run POV on new Debian install. Server Time
31 Oct 2024 21:23:44 EDT (-0400)
  Re: Can't run POV on new Debian install. (Message 1 to 5 of 5)
Subject: Re: Can't run POV on new Debian install.
Date: 16 Jul 1999 20:03:10
Message: <378fc83e@news.povray.org>
I experienced exactly the same behaviour with both s-pov and x-pov on my slack 4.0
install. I have a netscape glibc binary that also seg faults. Any suggestions?
Date: 17 Jul 1999 00:16:27
Message: <37900297.59679806@news.povray.org>
All I can tell you is that when I recompiled x-pov, it worked fine.  I
had to recompile libpng and libz too, even though I had what claimed
to be the right versions (I put the recompiled versions in
/usr/local/lib.  Maybe that is the trick.).  Maybe that is the
problem, somehow.  I was unable to recompile s-pov for lack of vga.h,
but I didn't pursue that because x-pov is sufficient for my needs at
this time.
Jerry Anning
clem "at" dhol "dot" com
Date: 4 Aug 1999 12:52:16
Message: <37A9C262.C477C9C6@sitc.net>
Something is odd here, though, because before I upgraded POV to version 3.1g it worked
fine, but after I did it, then it segfaulted on my as well.....I will try
compiling (maybe I'll get some benefits by doing so) and seeing if that helps...
> this time.
> Jerry Anning
Date: 4 Aug 1999 20:24:02
Message: <37A8DA43.87E473CE@mailbag.com>
worked fine, but after I did it, then it segfaulted on my as well.....I will try
It's probably worth noting that I upgraded from RH5.2 to RH6.0 between
3.1e and 3.1g.
I'd like to get some of these problems with various Linux distributions
worked out, but right now I'm packing to move, after which I'm off to
SIGGRAPH.
Mark Gordon
mtg### [at] povrayorg
Date: 4 Aug 1999 22:48:58
Message: <37AA4E55.5D0042BD@sitc.net>
Hmm...strange stuff....Now I'm having display output problems in Pov-Ray....apparently
I need update libraries? Oh well, best of luck with your moving as well as
SIGGRAPH.
TigerHawk
> 3.1e and 3.1g.
> SIGGRAPH.
> Mark Gordon
