POV-Ray : Newsgroups : povray.pov4.discussion.general : Gamma correction of input colours/image files Server Time
18 May 2024 05:56:44 EDT (-0400)
  Gamma correction of input colours/image files (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Gamma correction of input colours/image files
Date: 10 Oct 2008 10:17:02
Message: <48ef63de$1@news.povray.org>
> I'm going to jump in here and hopefully I won't look too foolish ....
> however I think the top row looks more like what I'd expect.
Because you are used to how POV handles colours :-)  But seriously, in the
top row, the *colours* (not brightness) are actually different from what you
specified in the SDL.  It is easiest to see this with the orange ball,
anybody trying to make some promotional material where the colours need to
be accurate for a certain brand (eg the Sony Ericsson "orange") would likely
get the top row thrown back at them for being the wrong colour.  The bottom
row preserves the correct colour.
The reason is that for "colours" (where RGB are not equal), gamma will
modify the brightness of each channel a different amount, so you are
actually changing the colour that you see, not just the brightness.  Your
eye is very sensitive to changes in colour, even when the brightness is
different.
> brightness looks to low to me. contrast compares with top row.
The brightness is easily controlled by the diffuse value in the finish
statement, or by cranking up the light colour.  Maybe I should have rendered
with more brightness to avoid the confusion between change in brightness and
change of colour?
Date: 10 Oct 2008 10:56:41
Message: <48ef6d29@news.povray.org>
> I think I eluded to brightness & contrast  differences .... not color.
Try all you want to modify the brightness and contrast of the top row,
you'll never be able to get a match with the middle row because the actual
*colours* are different.  The only way to get the match will be do undo the
gamma correction, but then by doing that you're screwing with the physical
correctness of the lighting on the spheres (ie the brightness won't be
proportional to normal of the surface in the correct way anymore).
Date: 10 Oct 2008 11:12:09
Message: <qdrue4p555v8qjoi9503k39lf44g2ucja4@4ax.com>
>different.
This can be demonstrated in your favorite image editor, GIMP in my case.  Open up two
copies of the image, then adjust the gamma of one copy by 0.45, which is 1/2.2 gamma.
The colors of the top row
of the gamma adjusted image will closely match the center row of the original image.
>change of colour?
You can do the same experiment above, but instead try and adjust the brightness and
contrast.  The colors will never match.
The issue is definitely related to how POV-Ray handles gamma in pigments.  For solid
pigments, the gamma-adjusted levels can be easily calculated manually.  For image
pigments, a macro can be used...
// Macro to adjust APGPig pigment by APGGam gamma value
// Adapted from the CIE_Imagemap macro by Jaime Vives Piqueres
#macro AdjustPigmentGamma(APGPig, APGGam)
  #local APGfn = function { pigment { APGPig } }
    average
    pigment_map {
      [function { pow(APGfn(x,y,z).red, APGGam) }   color_map { [0 rgb 0][1 rgb
<3,0,0>] } ]
      [function { pow(APGfn(x,y,z).green, APGGam) } color_map { [0 rgb 0][1 rgb
<0,3,0>] } ]
      [function { pow(APGfn(x,y,z).blue, APGGam) }  color_map { [0 rgb 0][1 rgb
<0,0,3>] } ]
Date: 10 Oct 2008 11:43:05
Message: <48ef7809@news.povray.org>
>> Why on earth would you expect the colors to be off?
> I reread my post and I don't believe I said that .....
I stand corrected, but that is how I interpreted it as you preferred the
top row. Anyway, inverse gamma correction is the thing to do in order to
get what you ask for.
(This is the same issue I was pondering with my own ray tracer a while ago.)
In addition, it would be nice if POV4 supported some other tone mapping
methods besides this linear one. I guess Megapov has "exposure" keyword
for this.
Date: 10 Oct 2008 11:55:54
Message: <48ef7b0a@news.povray.org>
scott wrote:
> Currently however, POV assumes all RGB values in the SDL and any RGB
> values from textures are in linear colour space, and uses them
> directly in the rendering core.  This often leads to output not being
>  as expected (see numerous posts about "washed out" effect when using
>  image files).
I fully agree with you, but things are even more complicated:
POV "assumes" for all image files to be in linear color space except for
PNG if they contain a gamma chunk. (But POV recognizes *only* PNG gamma
chunks, other colorimetric chunks like the sRGB chunk are ignored.)
This is why I have converted most of my texture image files to PNG by
using a program that does add this gamma chunk, (e.g. some older
versions of Photoshop did not).
I have also used this macro to use JPEG images as textures:
#declare sRGB_Inv = function(C) {
   select(C-0.04045, C/12.92, pow((C+0.055)/1.055,2.4))
#macro sRGB_JpgMap(ImageName)
#local fn = function {
   pigment {image_map {jpeg ImageName interpolate 2}}
   average
   pigment_map {
    [function {sRGB_Inv(fn(x,y,z).red)}
      color_map {[0 rgb<0,0,0>][1 rgb<3,0,0>]}]
    [function {sRGB_Inv(fn(x,y,z).green)}
      color_map {[0 rgb<0,0,0>][1 rgb<0,3,0>]}]
    [function {sRGB_Inv(fn(x,y,z).blue)}
      color_map {[0 rgb<0,0,0>][1 rgb<0,0,3>]}]
// used like:
   sRGB_JpgMap("MyTexture.jpg")
works well but the sad thing is: it slows things down because the colors
are transformed at render time.
About the use of assumed_gamma (and @Warp who seems to advocate this):
The major problem when using assumed_gamma with any value not equal to
1.0 is that antialiasing is no longer done in linear color space and so
results in quite poor quality. I will post an illustration to p.b.i.
It is removed from POV 3.7 - and IMO this is a VERY good idea.
And finally quite frankly: this gamma and assumed_gamma issues have been
discussed so many times and still the same old misconceptions reappear -
this makes me think it is meanwhile a kind of urban legend where some
people just insist to *believe* in something.
-Ive
Date: 10 Oct 2008 12:38:37
Message: <48ef850c@news.povray.org>
  The only thing I know for sure about gamma correction is that whenever
it makes an appearance, it only causes problems and nothing else.
  Take, for example, the GIF and JPEG image formats: No gamma correction
values anywhere, never any problems with gamma correction. They are two
of the most popular image formats ever, yet I don't remember reading
anybody complaining about gamma correction issues with them. Why? Because
they don't have any gamma correction info.
  Now take PNG: As a more modern image file format they decided to add
gamma correction information to it, as well as some recommendations and
specifications about how sofware should interpret it (as well as interpret
what happens if the info is missing). The result? The PNG format is
burdened with endless problems related to gamma correction issues. No two
programs seem to agree on how a PNG should be shown, regardless of whether
it has gamma correction info embedded or not.
  This is a huge problem for example with web browsers, which is one of
the reasons why PNG has been so unpopular in web design. And why wouldn't
it be: The exact same PNG can look completely different in different
browsers (for example with regards to the background color of the webpage),
while GIF and JPEG images look the same regardless of the browser.
  One big problem precisely related to web design is that you might
specify, for example, a background color for your web page, let's say
for example #808080, and you use *the exact same color* in a PNG expecting
it to match precisely the background color of the web page so that its
color scheme will nicely blend with the background. However, in one browser
the colors may match, while in another they might not. And this completely
regardless of whether you embed any gamma correction info into the PNG or
not. (This is because some web browsers *assume* some gamma value if none
is present in the PNG file, as per the specs recommendation, while others
just take the pixels unmodified, like they do with other image formats.)
  So what can a web developer do when he encounters this problem? The only
solution is to switch to either GIF (if 256 colors are enough) or JPEG.
Those do not present the problem because they do not have any gamma info.
A pixel value of #808080 will be #808080, like the page background, and
nothing else. No browser will make a *different* gamma correction to the
image and the background color, like they often do with PNG images.
  If PNG had never included the gamma correction information in its format,
this problem would not happen, and it would be exactly as usable as GIF and
JPEG. But no. Gamma correction = problems.
  It's no wonder why POV-Ray is also riddled with all kinds of problems
related to gamma correction. Whenever you are dealing with gamma correction
you are going to encounter big problems.
  I suppose that gamma correction is a bit like text character encodings:
Nice ideas in theory, but the world is completely riddled with endless
problems related to them, and every software has its own ideas about how
it should implement them.
Date: 10 Oct 2008 15:10:45
Message: <48efa8b5@news.povray.org>
the W3C, HP and Microsoft have agreed (since 1996 IIRC) that the www is
in sRGB color space. So GIF and JPEG have - so to say - a build in gamma
tag that reads 2.2 - close to the sRGB gamma curve.
But in the early 90ies, when I worked with a SGI graphics workstation
things where horrible because JPEG & GIF images always looked completely
different when viewed on a Mac, PC or a SGI IRIS.
Photoshop used to include ICC profiles into JPEG images and store the
image data in an internal working color space. As most viewers and all
web browsers do ignore color profiles in jpeg images the result was
sometimes quite strange. Photoshop CS3 doesn't do this anymore. (well
Adobe never cared much about being compatible to the rest of the world,
seems to be part of their business model, and sadly enough this is even
working)
POV assumes JPEG and GIF files to be in linear color space (and they
usually are not). This results in the well known washed out colors and
was the whole point of this thread.
Poser assumes that JPEG images used for bump, transparency or specular
maps are in linear color space but textures are gamma 2.2. So when
converting Poser figures to POV either the textures or the bump etc.
maps are wrong. With assumed_gamma 2.2 the textures are correct but the
other maps are not, with assumed_gamma 1.0 the textures are washed out
but the other maps are right - so to render poser stuff in POV,
assumed_gamma 1.0 and texture files converted to PNG are needed.
DAZ Studio uses some different assumptions about texture, bump and so on
maps. So professional vendors do meanwhile provide two different sets of
maps for Poser and DAZ Studio. (And I bet when it comes to Lightwave,
Maja, Cinema4D and what not we have similar problems!)
I can continue this list but this should be enough. Now tell me again
that there was never any problem with gamma correction  and JPEG/GIF images.
This is the point I really do not understand. The use of the png gamma
chunk is well documented in the png specs, the reference library libpng
(used by almost everybody) already includes all the code needed and the
usage is even as example code available. A programmer can just copy and
paste it. Still, the programmers of a lot of browser and other image
applications managed it to do it wrong (wrong as in programming a
calculator that says 1 + 1 = 3). And as a result the PNG format is
blamed for that.
The POV programmer (whoever this was) did it right, at least.
Well, ok, do not get me wrong, I really do see your point but my
conclusion is different. I would never say gamma correction = problem.
Gamma correction is a necessary (and in fact quite simple) concept that
has to been known in digital image processing. People who do not know or
understand it should not work there as a programmer. But they did and
this is the source for most irritation about the gamma subject.
-Ive
Date: 11 Oct 2008 04:04:36
Message: <48f05e13@news.povray.org>
> blamed for that.
  The problem is that some software out there apply the gamma correction
info properly, other software ignore it, and there is even some software
which apply the gamma correction incorrectly.
  The biggest and most usual problems happen when the PNG does *not*
have any gamma correction info. Some software out there will *assume*
some gamma (eg. 2.2), others will assume linear color space (or whatever
they are using for GIF and JPEG). You can easily have four or more
different programs, none of which show all PNG images in the same way,
because of gamma correction issues. Yet all the programs will usually
show GIF and JPEG images identically to each other.
  Yet you can still suffer from gamma correction issues. For example,
specify a surface color like <.5, .5, .5> to an object and apply a PNG
as an image map to another object, expecting a color value of 128, 128, 128
in the PNG to look exactly the same as the <.5, .5, .5>, and that might
just not be the case.
  Sometimes gamma correction is applied when you don't want it to be
applied, sometimes it's not applied when you want it to be applied, and
sometimes it is applied when you want, but incorrectly.
  I think that the underlying problem is that gamma correction is applied
improperly, and different programs and systems use different approaches
at applying it, many of them erroneous. Or perhaps not erroneous per se.
Perhaps there is *no* way of taking gamma into account in a way which
would work in all possible situations. The whole thing is a mess.
  I believe that the problem could be solved (or at least greatly
alleviated) if there was a unified universal standard which stated that
*all* image formats must use a strictly linear color space for *everything*,
and that the *only* place where gamma correction is applied is when showing
the image *on screen* (or printed on paper, or whatever visual media).
  This way you don't need to add any gamma correction information to any
image because every single software out there would assume that it's
already in a strictly linear color space, and every system knows how
it should convert that linear color space when it sends it to the monitor
(in other words, the only place where you fine-tune gamma correction is
in the the OS).
  Saving gamma correction information on the image file is not needed
because when eg. the image manipulation program uses the strict linear
color space but the OS *shows* the window of the image manipulation
program gamma-corrected for that specific system, it automatically means
that the created image will look the same in other systems as well (as long
as the gamma correction has been set up correctly in those systems).
  In other words, every single program out there would use the exact same
color space, and it's only up to the OS/display driver to show the colors
properly gamma-corrected *on screen* (and no "correction" is performed
anywhere else).
  However, things have got completely messed up because different programs
use *different* color spaces and do not agree on a single common one. Some
programs (I'm looking at you, Photoshop) want to gamma-correct the pixel
values being edited, rather than leaving the gamma correction to the the
OS/display drivers. Then they want to store the gamma value they used in
the file, and expect every other program to read this info and perform the
conversion to the pixel values.
  This is a bad idea, and only causes problems. It may work fine when you
simply want to *show* the image: First you apply the gamma correction
specified in the file to the pixels, after which the OS/display hardware
applies whatever gamma correction is necessary for the current hardware.
If this is done properly, the image will look the same as in the original
hardware.
  Problems start happening when you want to mix these images together and
with other color settings, eg. in a web page or a rendering software.
Should the gamma correction specified in the image be applied to the
image while reading it or not? If the web page or whatever uses its own
gamma correction, should it *also* be applied to the image or not? If
you want a color value of <.5, .5, .5> to exactly match the equivalent
color in the image, how can you do it? Should the color be gamma-corrected
to match the image? Or should the image be gamma-corrected to match the
color space where the <.5, .5, .5> was specified? How can you even know
which pixel value in the image corresponds visually to <.5, .5, .5>?
  It's a huge mess. Maybe there is no solution to all these problems
because it all has become an unfixable mess.
Date: 11 Oct 2008 12:32:48
Message: <48f0d530$1@news.povray.org>
IIRC there was indeed a fault in the first draft of the PNG
specification saying if no gamma chunk is present the application should
not assume any gamma correction (meaning the image is in linear color
space). But this was soon revised and happened more than 10 years ago.
well, I never had any problem doing exactly this with PNG files - with
the PNG files I do use and do know they include a correct gamma chunk.
But this does NOT work with GIF/JPEG/TGA files and assumed_gamma = 1.0
(what I always do - and if you have forgotten why reread my post about
bump/specular/transparency maps and look at the antialiasing pictures in
p.b.i). Changing the default behavior of POV (by assuming these files
to be in sRGB color space instead of linear) would break the usage of
them as bump etc. maps - something that does currently work as expected.
Agreed.
When you search this newsgroups for "gamma" and read all the posts (what
I just did) the whole thing obviously IS a mess. But I guess I mean it
for a different reason you did ;)
> in the the OS).
This is no solution at all and another common misconception. There is a
good reason that 8bit/sample image formats are not linear because the
human visual system is more sensitive in the dark areas and to avoid
"color bands" it makes sense to use more bits in the dark area -> no
linear color space -> gamma correction. In times of low computer power
it was merely a lucky coincidence that a common CRT also had a similar
non linear response curve and we could send the image data directly to
the display controller - without processing the data through lookup tables.
To avoid this you'll have to switch to 16bit/sample. But this means a
much worse compression ratio (because the "noise" introduced into the
low bits) and (just an educated guess) about 5x the filesize for a DCT
or DWT compressed file format only to achieve the same visual quality
for an average photographic image.
What is the point in doing this?
B.T.W. with contemporary computer power nowadays EVERY image
manipulation program should internal use a linear color space. This is
one of the reasons I use Photoshop (and Windows for that matter - even
if I dislike the business attitude of both companies behind them). Do
not get me wrong, I'm not trolling about Gimp, if you like it, fine, but
it simply does not do what I expect. (And I do not know about the
current development status of CinePaint, last time I tried it on a linux
box it just crashed unpredictable.)
> anywhere else).
Just because I feel a little picky. A color space does also define what
colors red, green and blue *are*. And there are good reasons to use
different color spaces and embed colorimetric information into an image
file (like e.g. using ICC profiles). But I do not want to open another
can of worms ;)
Ok. So finally we have the point again I meanwhile tend to agree ;)
-Ive
Date: 13 Oct 2008 05:02:32
Message: <48f30ea8$1@news.povray.org>
So let's simplify things for POV4:
Facts:
* A raytracer needs to work internally in linear colour space
* A monitor is a non-linear device (usually requiring a gamma correction of
1.8-2.2)
Assumptions:
* Most outputs from a raytracer will be in monitor colour space, not linear
space
  --> raw output from the raytracer needs to be converted from linear space
* Most inputs to a raytracer will be in monitor colour space
  --> User input needs to be converted to linear space
Default solution:
* One single system-defined Gamma value (default 2.2 for Windows, editable
by user)
* Gamma applied to all output from raytracer engine
* Inverse-gamma applied to all input to raytracer engine
* For #version <4.0 the old behaviour is set (ie no conversion for input
colours)
Options:
* User can change Gamma value for their system (in .ini file?)
* User can use SDL keywords to set if input values in that file are
specifically in linear space
eg: color rgb <1.0,0.5,0.25> will be the same colour as RGB 255,128,64 when
viewed on your monitor, no matter what gamma setting you have.
linear_color rgb <1.0,0,0> will be twice as bright as linear_rgb <0.5,0,0>.
Can be used when you want a linear mapping for physical reasons (eg one box
twice as bright as the other).
There could also be a linear_image_map keyword to work with texture files in
the same way.
