Am 04.08.2015 um 22:32 schrieb Stephen:
>> And then there was the keyboard of my first own PC. One of the things I
>> did pretty early after unboxing was to install some Norton Commander
>> clone which, as you may recall, made heavy use of the function keys as
>> hotkeys for important stuff; I knew most of them by heart.
> That passed me by. Norton became a resource hog and I stopped using it
> early on.
You should have tried Volkov Commander. Same functionality as NC plus
some more, yet still magnitudes smaller. Good old Russian assembler
coding. I made sure to put it on all my boot disks.
> On 8/2/2015 6:13 PM, clipka wrote:
> > The good news was that yes, the second F5 key behaved exactly like the
> > good old F7 key. Phew! :)
NOOOOOOOOOOOOOO! Not [F7] !!!!! It's a trap!
Download '4aac119f70d3db918476492cb93bf19a_650x.jpg' (81 KB)
Preview of image '4aac119f70d3db918476492cb93bf19a_650x.jpg'
>> early on.
I've used AVG for years and when that started to slow down my machine. I
swapped to MS Essentials.
Regards
Am 05.08.2015 um 11:29 schrieb Stephen:
>>> early on.
Wait... you're talking about anti-virus software, right?
That's not what Norton Commander was.
NC was a file manager for good old DOS, which allowed scrollable
side-by-side viewing of two directories, copying stuff between both
sides, and doing other fancy stuff, while at the same time always giving
you a command prompt; it also came with integrated text and hex editors
(or at least that's how I remember it; the hex editor might have been a
Volkov Commander extension).
Total Commander still keeps up the tradition of Norton Commander clones.
Norton Commander was part of a package called Norton Utilities, which
also included tools for disk defragmenting, data rescue (Norton Disk
Doctor), and some such.
IIRC Norton Antivirus was a later invention.
Your right I was thinking about Norton Antivirus.
And what a coincidence. Yesterday I downloaded the evaluation version of
Total Commander.
As I said to another Cmdr. It reminds me of Windows 1.0
It also hangs when I try to look at my network. I don't have the time to
look at it just now. I am getting ready for a big appointment next week.
Regards
Am 05.08.2015 um 19:17 schrieb Stephen:
> Total Commander.
Depending on what you intend to do with it, you might want to have a
look at BeyondCompare. If you need to compare or synchronize two
folders, BC is all the tool you'll ever need. (And if you need to
compare file contents, you get that for free on top ;))
It also does a tremendously good job at moving or copying huge numbers
of files (or large files) from A to B, and plays pretty nice with
network folders. (It even supports FTP.)
>> Total Commander.
I don't intend to do anything with it. It was a recommendation from
someone else. I installed it out of politeness so I could talk to him
about it.
And the network works better if there is another machine switched on.
<whistles tunelessly>
I'll bear that in mind. Thanks.
Regards
