POV-Ray : Newsgroups : povray.off-topic : Twitter API, anyone? Server Time
10 Apr 2026 01:02:27 EDT (-0400)
  Twitter API, anyone? (Message 1 to 7 of 7)
Subject: Twitter API, anyone?
Date: 3 Feb 2015 22:25:00
Message: <web.54d19006246a5125d44a22e40@news.povray.org>
Hi, I started playing with Twitter API.  I have lots of permissions and keys but
no idea how to start using them.
I ultimately want to start using "GET statuses/user_timeline".  I am told to
type in a signature base string, authorization header, and cURL command.  Is
this, um, in Python?  Unfortunately the main page which might explain things
isn't loading.
Can someone recommend a good programming dev environment for the Mac in which I
can use those commands. thanks.
Subject: Re: Twitter API, anyone?
Date: 4 Feb 2015 11:59:24
Message: <54d24fec$1@news.povray.org>
> keys but no idea how to start using them.
> told to type in a signature base string, authorization header, and cURL
> command.  Is this, um, in Python?  Unfortunately the main page which
> might explain things isn't loading.
> which I can use those commands. thanks.
Sounds like a REST API. cURL is sometimes used for that from a bash
prompt.
If you do Python development, have a look at the python-requests package
- I do a little python/REST work myself for work, and I've found that to
be the easiest way to handle this - python-requests will manage the
session, so you only need to perform the authentication once (that's
usually in addition to the authorization header, which I think includes
an API key of some sort).
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 4 Feb 2015 16:50:00
Message: <web.54d29327b541053a7501572f0@news.povray.org>
> prompt.
> Jim
If you want to see the sources of something close to Twitter, maybe a look at
the diaspora project would help.
Date: 8 Feb 2015 07:50:00
Message: <web.54d75b73b541053ab1f543340@news.povray.org>
> prompt.
> Jim
Okay, thanks!  I just want to grab a big slew of tweets, from 600 individuals
I've pre-selected, "one time", not necessarily make a full-blown application.
But it looks like the API may be the only officially approved way to do so.
(Counterevidence?)    Okay, I'll look at python-requests.   The one thing I do
find quite odd is in a world with dozens of programming environments, they
Twitter API team just dumps code out there with no explanation.
Date: 8 Feb 2015 15:38:56
Message: <54d7c960$1@news.povray.org>
>> > and keys but no idea how to start using them.
>> > cURL command.  Is this, um, in Python?  Unfortunately the main page
>> > which might explain things isn't loading.
>> > in which I can use those commands. thanks.
>> prompt.
>> package - I do a little python/REST work myself for work, and I've
>> found that to be the easiest way to handle this - python-requests will
>> manage the session, so you only need to perform the authentication once
>> (that's usually in addition to the authorization header, which I think
>> includes an API key of some sort).
>> Jim
> individuals I've pre-selected, "one time", not necessarily make a
> full-blown application. But it looks like the API may be the only
> officially approved way to do so. (Counterevidence?)    Okay, I'll look
> at python-requests.   The one thing I do find quite odd is in a world
> with dozens of programming environments, they Twitter API team just
That's not an uncommon practice, sadly - SDKs are something that don't
get nearly enough attention when it comes to documentation.
Part of the problem is, I think, that the people documenting APIs have a
significant amount of domain knowledge, and don't consider that their
audience doesn't.
Jim
Date: 8 Feb 2015 15:59:14
Message: <54d7ce22$1@news.povray.org>
> audience doesn't.
This is the problem with all technical product documentation, yes.
Date: 8 Feb 2015 18:25:22
Message: <54d7f062$1@news.povray.org>
>> a significant amount of domain knowledge, and don't consider that their
>> audience doesn't.
Well, no, not *all* technical product documentation - but certainly a lot
of it.
Jim
