On 2022-01-23 21:01 (-4), Tor Olav Kristensen wrote:
> What operating system are you using ?
openSUSE Leap 15.5 GNU/Linux
> Are you able to log into to your account via the GitHub web interface ? Here:
> https://github.com/your-account-name
Yes.
> If so, then you can go to this page to administrate the SSH and GPG keys
> associated with your GitHub account:
> https://github.com/settings/keys
Yes. Strangely, is says there are no keys associated with my account.
So where are all those keys I had been setting up through the link that
GitHub emailed to me every month?
> You can try to add another key. If you are using Linux or Windows 10/11 or
> MacOS, then I suggest that you add a new SSH key to your GitHub account.
I was using GPG because that's what was in the instructions I got from
GitHub after they discontinued password pushing. Are there advantages
or disadvantages to one system over the other?
Thanks for your attention.
On 2022-01-24 04:20 (-4), jr wrote:
> I trust you've solved your problem by now,
Of course not! Whatever gave you that idea? I was just taking a break
from the frustration.
> if not:
> $ gpg --list-keys
----------[BEGIN SCREEN OUTPUT]----------
/home/ricky/.gnupg/pubring.kbx
pub rsa2048 2021-10-06 [SCEA]
SomeBigNumberIDontThinkIShouldPostHere
uid [ultimate] Ricky <my### [at] email address>
sub rsa2048 2021-10-06 [SEA]
-----------[END SCREEN OUTPUT]-----------
> you should see which key you're after by looking at the 3rd (space-separated)
> field, the date of creation.
The date I'm seeing is for the long-expired key from last October. I
see no sign of the keys that GitHub had me set up since.
> its first field should read 'pub'(lic). the
> second field is a slash separated compound, use the number after the slash to:
> $ gpg --export theNumber > the_file_to_use_on_github
I see no slash anywhere in the output.
> fwiw, TOK's ""SSH keypair setup for GitHub" link looks v good. had not known
> you can use ssh keys too, recommend you switch from 'gpg' to 'ssh' at some point
> (easier to use + manage).
I guess I'll look into it... I guess. If I switch over, will it confuse
GitHub?
Thanks for trying to help out.
hi,
I have no use for 'gpg' apart from s/ware downloads/installs. but this is what
I see, for the distribution's key:
root@crow:~# gpg --version
gpg (GnuPG) 1.4.21
root@crow:~# gpg --list-keys
/root/.gnupg/pubring.gpg
pub 1024D/40102233 2003-02-26 [expires: 2038-01-19]
uid Slackware Linux Project <sec### [at] slackware com>
sub 1024g/4E523569 2003-02-26 [expires: 2038-01-19]
not sure why the format of the second field differs. sorry.
regards, jr.
> gpg (GnuPG) 1.4.21
> [snip]
My version of gpg is 2.2.27.
Do you normally work as root?
hi,
> > gpg (GnuPG) 1.4.21
still, I'd have expected a comparable output.
no. I had to log in because root is the only account with a '~/.gnupg/' (for OS
updates), it's 'ssh' for everything (and everyone) else.
regards, jr.
hi,
(sorry, just occurred to me)
have you checked whether there are other 'pubring.{kbx,gpg}' files anywhere?
thinking KDE might store stuff in places other than just your user's home. I'd
use 'locate(1)' though 'find(1)' will do.
regards, jr.
> A private and a public ssh key can be created e.g. like this both in Linux,
> MacOS and a recent Windows 10 (and perhaps in Windows 11):
> [snip]
OK, I created an SSH key and followed GitHub's instructions for adding
it to my ssh-agent, re-created the remote origin reference on my local
repo, and tried to push again. Git-Cola *still* asked for the damn
expired GPG key.
I guess I'll have to dig out the instructions on how to push from the
CLI, and see if that works. But like I said before, I cannot remember
these commands from one moment to the next; but I do remember that if I
forget a step, or if I omit or get one of the myriad command line
switches wrong, none of it will work.
Is my workflow getting easier yet?
> expired GPG key.
> CLI, and see if that works. [snip]
The push worked from the CLI. Next is to find out why Git-Cola is still stuck
in the past.
> > expired GPG key.
> in the past.
Good.
Do you know what key (GPG or SSH) was being used when it worked from the command
line ?
If it was not the SSH key; did you paste the contents of the id_rsa.pub file
into the key field at this page:
https://github.com/settings/ssh/new
Btw.: I had to google Git-Cola to find out what it is. I wasn't aware that you
use it. I haven't used such GUI tools myself, just the git tools on the command
line and the web interface at github.com.
Tor Olav
http://subcube.com
https://github.com/t-o-k
>>> expired GPG key.
>> in the past.
> Good.
> line ?
It was SSH.
Fortunately, Git-Cola and the CLI work well together. I can switch back
and forth at any time, and the Git repos maintain their integrity.
