POV-Ray : Newsgroups : povray.off-topic : How do I use a new GPG key? Server Time
7 Apr 2026 05:38:41 EDT (-0400)
  How do I use a new GPG key? (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: How do I use a new GPG key?
Date: 30 Jan 2022 10:47:13
Message: <61f6b301@news.povray.org>
On 2022-01-23 21:01 (-4), Tor Olav Kristensen wrote:
> What operating system are you using ?
openSUSE Leap 15.5 GNU/Linux
> Are you able to log into to your account via the GitHub web interface ? Here:
> https://github.com/your-account-name
Yes.
> If so, then you can go to this page to administrate the SSH and GPG keys
> associated with your GitHub account:
> https://github.com/settings/keys
Yes.  Strangely, is says there are no keys associated with my account.
So where are all those keys I had been setting up through the link that
GitHub emailed to me every month?
> You can try to add another key. If you are using Linux or Windows 10/11 or
> MacOS, then I suggest that you add a new SSH key to your GitHub account.
I was using GPG because that's what was in the instructions I got from
GitHub after they discontinued password pushing.  Are there advantages
or disadvantages to one system over the other?
Thanks for your attention.
Date: 30 Jan 2022 11:02:13
Message: <61f6b685@news.povray.org>
On 2022-01-24 04:20 (-4), jr wrote:
> I trust you've solved your problem by now,
Of course not!  Whatever gave you that idea?  I was just taking a break
from the frustration.
> if not:
>   $ gpg --list-keys
----------[BEGIN SCREEN OUTPUT]----------
/home/ricky/.gnupg/pubring.kbx
pub   rsa2048 2021-10-06 [SCEA]
      SomeBigNumberIDontThinkIShouldPostHere
uid           [ultimate] Ricky <my### [at] emailaddress>
sub   rsa2048 2021-10-06 [SEA]
-----------[END SCREEN OUTPUT]-----------
> you should see which key you're after by looking at the 3rd (space-separated)
> field, the date of creation.
The date I'm seeing is for the long-expired key from last October.  I
see no sign of the keys that GitHub had me set up since.
>  its first field should read 'pub'(lic).  the
> second field is a slash separated compound, use the number after the slash to:
>   $ gpg --export theNumber > the_file_to_use_on_github
I see no slash anywhere in the output.
> fwiw, TOK's ""SSH keypair setup for GitHub" link looks v good.  had not known
> you can use ssh keys too, recommend you switch from 'gpg' to 'ssh' at some point
> (easier to use + manage).
I guess I'll look into it... I guess.  If I switch over, will it confuse
GitHub?
Thanks for trying to help out.
Date: 30 Jan 2022 11:35:00
Message: <web.61f6bd3fb38070f5ea8869266cde94f1@news.povray.org>
hi,
I have no use for 'gpg' apart from s/ware downloads/installs.  but this is what
I see, for the distribution's key:
root@crow:~# gpg --version
gpg (GnuPG) 1.4.21
root@crow:~# gpg --list-keys
/root/.gnupg/pubring.gpg
pub   1024D/40102233 2003-02-26 [expires: 2038-01-19]
uid                  Slackware Linux Project <sec### [at] slackwarecom>
sub   1024g/4E523569 2003-02-26 [expires: 2038-01-19]
not sure why the format of the second field differs.  sorry.
regards, jr.
Date: 30 Jan 2022 12:10:20
Message: <61f6c67c$1@news.povray.org>
> gpg (GnuPG) 1.4.21
> [snip]
My version of gpg is 2.2.27.
Do you normally work as root?
Date: 30 Jan 2022 12:40:00
Message: <web.61f6cc77b38070f5ea8869266cde94f1@news.povray.org>
hi,
> > gpg (GnuPG) 1.4.21
still, I'd have expected a comparable output.
no.  I had to log in because root is the only account with a '~/.gnupg/' (for OS
updates), it's 'ssh' for everything (and everyone) else.
regards, jr.
Date: 30 Jan 2022 15:50:00
Message: <web.61f6f8d7b38070f5ea8869266cde94f1@news.povray.org>
hi,
(sorry, just occurred to me)
have you checked whether there are other 'pubring.{kbx,gpg}' files anywhere?
thinking KDE might store stuff in places other than just your user's home.  I'd
use 'locate(1)' though 'find(1)' will do.
regards, jr.
Date: 31 Jan 2022 15:08:22
Message: <61f841b6$1@news.povray.org>
> A private and a public ssh key can be created e.g. like this both in Linux,
> MacOS and a recent Windows 10 (and perhaps in Windows 11):
>     [snip]
OK, I created an SSH key and followed GitHub's instructions for adding
it to my ssh-agent, re-created the remote origin reference on my local
repo, and tried to push again.  Git-Cola *still* asked for the damn
expired GPG key.
I guess I'll have to dig out the instructions on how to push from the
CLI, and see if that works.  But like I said before, I cannot remember
these commands from one moment to the next; but I do remember that if I
forget a step, or if I omit or get one of the myriad command line
switches wrong, none of it will work.
Is my workflow getting easier yet?
Date: 31 Jan 2022 16:10:00
Message: <web.61f84f5fb38070f560e0cc3d949c357d@news.povray.org>
> expired GPG key.
> CLI, and see if that works.  [snip]
The push worked from the CLI.  Next is to find out why Git-Cola is still stuck
in the past.
Date: 31 Jan 2022 20:05:00
Message: <web.61f886aab38070f5afe6ae3e89db30a9@news.povray.org>
> > expired GPG key.
> in the past.
Good.
Do you know what key (GPG or SSH) was being used when it worked from the command
line ?
If it was not the SSH key; did you paste the contents of the id_rsa.pub file
into the key field at this page:
https://github.com/settings/ssh/new
Btw.: I had to google Git-Cola to find out what it is. I wasn't aware that you
use it. I haven't used such GUI tools myself, just the git tools on the command
line and the web interface at github.com.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 1 Feb 2022 21:01:22
Message: <61f9e5f2$1@news.povray.org>
>>> expired GPG key.
>> in the past.
> Good.
> line ?
It was SSH.
Fortunately, Git-Cola and the CLI work well together.  I can switch back
and forth at any time, and the Git repos maintain their integrity.
