POV-Ray : Newsgroups : povray.off-topic : Introducing the Bue'Harian phonetic writing system Server Time
22 Apr 2026 15:59:19 EDT (-0400)
  Introducing the Bue'Harian phonetic writing system (Message 1 to 5 of 5)
Subject: Introducing the Bue'Harian phonetic writing system
Date: 22 Jun 2016 15:38:11
Message: <576ae923@news.povray.org>
I've been thinking of creating a phonetic writing system that could be
relatively easily understood visually. Basically a featural phonetic
system.
I still need to add tones and more advanced features.
Please let me know if it is understandable to use.
Suggestions are welcome.
https://drive.google.com/folderview?id=0B3kSno0ESYYoTVJSRklEeVhGOHc&usp=sharing
________________________________________
-Nekar Xenos-
Subject: Re: Introducing the Bue'Harian phonetic writing system
Date: 22 Jun 2016 21:12:12
Message: <576b376c$1@news.povray.org>
Am 22.06.2016 um 21:38 schrieb Nekar Xenos:
> system.
It seems to me that your basic concept is to depict the phonemes via the
position of the vocal tract.
While this idea looks neat at first glance, it must inevitably fall
short, for at least two reasons:
1) You still need to introduce somewhat arbitrary notation for any
phonetic features arising from dynamic processes, such as trills,
taps/flaps, implosives, and what-have-you-nots. It is there that all the
ease of visual understanding breaks down at the very next cultural barrier.
2) It does not deal with the phenomenon of allophones, i.e. sounds that
are generated in different ways but perceived as identical.
My suggestion would be to stick with the IPA alphabet. Not only is it
well-established in the expert community, well-supported by Unicode, and
well-equipped for pretty much any human vocal expression you could
possibly imagine -- it also comes with a host of tried and tested best
practices how to actually apply it to various different use cases.
Date: 22 Jun 2016 22:47:05
Message: <576b4da9@news.povray.org>
I do have trills and taps/flaps. The symbol is basically a graph of the
movement of the tongue. I still need to do implosives, tones and the rest.
All allophones should be written phonetically with this system.
This will be mapped to the IPA alphabet in Unicode.
Thanks for the input.
My son is into linguistics and calligraphy and I find the IPA very
confusing, so I thought of creating a more visual representation that
can represent any sound you can make.
I know; if you are going to learn a new language, you can just as well
learn the normal IPA first. I guess I'm a stickler for logical systems.
This one is for a right to left system. It can be mirrored for left to
right. The main reason I did this one right to left is because all the
IPA charts show the vowels with the mouth facing left.
It also makes a nice SF font which will probably be it's main use :)
-Nekar Xenos-
Date: 24 Jun 2016 05:00:25
Message: <576cf6a9$1@news.povray.org>
Am 23.06.2016 um 04:47 schrieb Nekar Xenos:
Phonetically, rather than phonemically? I.e. using the most precise
possible notation? Are you sure that's what you mean? Because then you'd
have to provide a ton of different symbols, for instance both a
velarized and a palatalized variant of the voiced bilabial plosive,
although the difference between the two is only relevant in a very few
languages such as Irish, and virtually no Englishman could even tell
them apart.
You've picked quite a challenge there.
When it comes to that, you are of course free to go wild :)
In that case you also won't need to add more spacing between the
symbols: It would certainly be very helpful in discerning where one
character ends and the next begins, and hence improve readability, but
it might be considered a violation of tradition, an intolerable lack of
respect for the forefathers, by the fictional users of the writing system.
(Personally, I'm more into tengwar-ish fonts, but your results are also
interesting.)
Date: 26 Jun 2016 14:29:45
Message: <57701f19@news.povray.org>
> them apart.
Since I'm thinking in terms of learning languages, I think it should be
phonetic. I aim to have all the possibilities in as simple and logically
as possible.
I am also working on a system to use the normal keys of the keyboard to
make the most common sounds. For instance the "qwerty" row can be used
to indicate the place e.g. labial, dental, etc. while the rest can be
used to indicate the method (fricative, plosive, voiced, etc). I would
then use the capitals in a similar way for creating the vowels. Mapping
to the IPA will come after that.
Indeed, that sounds very much like the Harians :)
I considering scaling it horizontally about 60% so that the characters
don't take up too much space and I can then also have more space between
characters for readability.
> interesting.)
The circles were inspired by the RL Telugu script which I find most
beautiful.
-Nekar Xenos-
