POV-Ray : Newsgroups : povray.off-topic : Quake II Server Time
15 Jun 2026 12:13:01 EDT (-0400)
  Quake II (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Quake II
Date: 20 Jan 2016 14:48:54
Message: <569fe4a6$1@news.povray.org>
On 1/20/2016 7:26 PM, Orchid Win7 v1 wrote:
> On 20/01/2016 07:05 PM, Stephen wrote:
>> You both might be interested in this:
>> http://www.bbc.co.uk/news/technology-35343089
>> Wolfenstein 3D was the first 3D game I played.
> You might be interested in this:
> http://hackaday.com/2016/01/15/wolfenstein-in-600-lines-of-code/
> Somebody reimplemented Wolfenstein... AS AN AWK SCRIPT!
> The actual HELL?!
I'm lost for words. Brill!
Regards
Date: 20 Jan 2016 14:56:11
Message: <569fe65b$1@news.povray.org>
>> The actual HELL?!
Yes. Why... WHY would you do this?! You turned a text-processing engine
into a 3D game by way of VT-400 escape codes? Are you nuts?! IN 600 LINES??!
Respect.
Date: 20 Jan 2016 15:09:34
Message: <569fe97e$1@news.povray.org>
Am 20.01.2016 um 20:56 schrieb Orchid Win7 v1:
>>> The actual HELL?!
> LINES??!
That's spelt "nerds", not "nuts" :-P
Date: 21 Jan 2016 02:55:14
Message: <56a08ee2$1@news.povray.org>
> Well, without a 3D card, there's no texture filtering, and no coloured
> lighting. And with a 233 MHz Pentium I with MMX technology, you had to
> turn the resolution down fairly far to get sane frame rates. So running
> at something like 640x480 with a boarder (remember that feature?), the
> display was *very* grainy.
I think I had a P166 with 16MB RAM ... and then I bought a 3Dfx card for it.
> (Remember Glide?)
It's where I learned 3D graphics programming :-) The separate cards for
2D/3D was actually really useful, as it allowed me to have a TWO SCREEN
setup! IIRC if you didn't open a full-screen window in your program, you
could still use the 2D Windows interface at the same time the 3D was
running on the 3Dfx card. Useful for debugging or providing some simple
Windows-based UI for controlling the 3D.
> Quake II is also the only game I've ever made a map for.
I was a Duke Nukem guy rather than Quake II, I used to waste my summer
holidays with my sister over serial link on that. When we got bored we
made maps - mine were usually full of hidden tunnels and secret ambush
points :-) The editor was very buggy though, and would periodically get
completely corrupted and you'd end up with several walls going through
the middle of all your rooms and extending 32km into the distance. That
was a sure sign it was about to crash and you better reload the last
backup (or the one before that...).
Date: 21 Jan 2016 04:34:20
Message: <56a0a61c@news.povray.org>
> it.
Ah, the days when 3D cards cost *money*. I think my step brother paid
Mind you, remember when a graphics card with better than 256 colours
cost money? (There's an expansion card for the Amiga called Picasso,
which gives you true 24-bit video, as opposed to the 256 colour graphics
>> (Remember Glide?)
Heh. I never learned 3D programming. Well, I did read the OpenGL book
almost from cover to cover. But that's an older version; the current one
costs money.
I've never looked at DirectX though. (Or should that be Direct3D?)
The only time I "learned 3D programming" was when I wrote cost in
Borland Turbo Pascal to draw a spinning fireframe cube. And then added
surface illumination, which dropped the framerate to a crawl. And then a
rotating torus, which required me to implement the painter's algorithm
for correct surface occlusion. (Back-face cull is sufficient for a cube,
or any other convex solid I suppose...)
Oh, and that time I built a ray-tracer and thought I was the only person
in human history to have ever achieved such a feat...
> setup!
Interesting...
I didn't have any problems with crashes, just that I suck at level design!
I do recall though that my dad ordered a computer from a local computer
company, and when I tried to play Quake II, the graphics were slightly
messed up. In certain areas of the map, it looked like a paintball fight
went wrong; weird splotches of highly-saturated random colours all over
the walls, like they're glowing. When me dad took it back to the shop,
they told him they "accidentally fitted the graphics card back to
front". Which is so obviously nonsense, you have to wonder... But
anyway, when the PC came back, the graphics worked fine.
One of my graphics cards developed an interesting fault where after a
while, it would start rendering polygons that extent to infinity along
one of the coordinate axies. Makes it very hard to play CS:S when you
can't actually see where you're going!
Date: 21 Jan 2016 05:09:33
Message: <56a0ae5d$1@news.povray.org>
Another thing: I remember it being *hard* to find secrets in Quake II.
But on this playthrough, it seemed really easy. Like, most of them
aren't even all that hidden. A few of them involve pressing a switch
somewhere, and then a door opens on the other side of the map or
something. But most of them, it's just a case of if you look around long
enough, or shoot anything that sparks (or go back and *investigate* that
cupboard the enemies just popped out of), you find a secret. Hell, I
even found a couple of secret *levels*!
I think the only one that's really _hard_ to find is that one where you
have to execute a rocket jump to get here. I'd never have thought of
that on my own, but some magazine pointed it out. And when you get
there, a little message pops up. Instead of "you have found a secret",
it says "you crazy rocket jumpers!"
Of course, the "best" secret is on the final boss map. It *looks like*
you need to escape before the place blows up. But actually, you can hang
around all day if you like. Nothing bad will happen. But in the resupply
area, if you shoot the back wall, a secret tunnel opens up. Walk through
and there's a gallery of all the coders who worked on the game. And at
the very far end... well, you know the rest.
Date: 21 Jan 2016 05:27:42
Message: <56a0b29e$1@news.povray.org>
Thank you very much. :-(
You could have at least put a spoiler alert before it.
I was so bad at playing it, I only walked around in God Mode.
Getting lost and not knowing where I was, was my biggest problem. No
clipping sorted that out.
Regards
Date: 21 Jan 2016 07:40:38
Message: <56a0d1c6$1@news.povray.org>
Dude, the game is, like, 2 decades old. ;-)
Yeah, particularly the later levels have *a lot* of going backwards now
that you get the red key or whatever. I certainly got lost for a while -
and I've played it before!
Date: 21 Jan 2016 07:53:23
Message: <56a0d4c3$1@news.povray.org>
So! I've still not finished it.
Spoilsport! :-P
Yeah, run, run, run. Back at the same spot. Grrr! :-)
Regards
Date: 21 Jan 2016 08:12:31
Message: <56a0d93f$1@news.povray.org>
>>> The actual HELL?!
- Because it's there.
Sir Edmund hillary.
> LINES??!
> Respect.
Indeed.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
