POV-Ray : Newsgroups : povray.off-topic : Memory-mapped I/O Server Time
18 Mar 2026 20:18:01 EDT (-0400)
  Memory-mapped I/O (Message 1 to 10 of 16)
Subject: Memory-mapped I/O
Date: 2 Feb 2015 13:16:26
Message: <54cfbefa$1@news.povray.org>
OK, so I don't know if anybody here will actually know the answer to
this, but I'll ask anyway...
Back in the good old days (i.e., about 30 years ago), you could program
any hardware device connected to your computer by just poking the right
codes into the correct memory addresses. I'm curious about to what
extent that's still the case.
For example, if you have a C64, you can poke some codes into the VIC-II
chip that generates the TV signal, thus convincing it to switch from
text mode to graphics mode. (And losing the ability to see your BASIC
listings or the command prompt, by the way. BASIC has no idea you just
did this!) With that done, you can *literally* change the colours of
individual pixels by just writing codes into the region of RAM occupied
by the framebuffer.
As I sit here with my very expensive "IBM PC-compatible", I'm
wondering... Is it even still *possible* to map the graphics card's
framebuffer into the CPU's address space? Or do you have to do something
more elaborate? Do you "talk to" the graphics card directly, or you to
talk to the PCI-Express chipset and explicitly ask it to deliver your
message packets? Clearly the data all passes through the PCIe chipset;
what I'm asking is whether that's transparent to the CPU or not.
Similarly, if I want to ask the harddisk to do something, do I need to
explicitly construct ATAPI commands, or does the chipset do that for me?
I'm not trying to actually *write* a device driver, I'm just curious as
to how this stuff works these days.
Subject: Re: Memory-mapped I/O
Date: 2 Feb 2015 16:47:52
Message: <54cff088$1@news.povray.org>
Am 02.02.2015 um 19:16 schrieb Orchid Win7 v1:
You're actually wrong there. Partially, that is.
It actually depended on the CPU architecture. While some - like the
C64's 6510 - had only one single address space to mess around in, others
- like Intel's 8080 or the related Zilog Z80 - had another dedicated
address space for I/O controllers.
With Intel's 8086 being closely related to the 8080, it might come as no
big surprise that PCs also have a dedicated I/O address space, and
indeed external hardware is traditionally residing there.
That said, the I/O address space of the 8086 is as large as that of the
8080: just 64k. Thus, stuff that required a big address window - most
notably indeed the display adaptor's framebuffer - was made to reside in
the memory address space. You still had to mess with I/O address space
to access the actual display controller though, in order to e.g. switch
the display into a different resolution, or switch from text to graphics
mode.
The 8086 family also added DMA to the mix, which allows for serial data
transfer from some memory address range to some I/O address (or vice
versa) at the request of periphery without intervention of the CPU.
Nah, it's still all I/O and memory accesses like in good old days -
thanks to BIOS and OS, who do all the setting-up of the PCIe bus for you
(buzzword plug & play) so that you can talk to the periphery without
having to bother about the bus details.
As for the framebuffer, as a matter of fact nowadays the display memory
sometimes /is/ genuine main memory.
That probably depends on the sophistication of the hard disk controller,
which is the thing you'll be talking to in this case. But the actual
data transfer will take place either via memory-mapped I/O or (more
likely) DMA, so in either case you'll write the data to some memory
address range.
Nothing much has changed since the good old days: It all boils down to
I/O and memory accesses. Except that the C64's CPU happened to not have
the concept of a dedicated I/O address space.
Date: 3 Feb 2015 03:30:39
Message: <54d0872f$1@news.povray.org>
You can see the address ranges if you go to the properties of your
graphics card in device manager (under the "Resources" tab). I suspect
the small IO address ranges are for sending commands to the GPU (which
you can just use CPU store instructions to access), and the larger ones
are a map of the RAM on the card (which you use DMA for).
Typically though I don't think you will find much documentation on *how*
to communicate with a modern desktop GPU. You might find this
interesting though, whilst not the same architecture as a PC it does
give a bit of an insight on a modern GPU architecture (it's the one on
the raspberry PI):
http://www.broadcom.com/docs/support/videocore/VideoCoreIV-AG100-R.pdf
Date: 3 Feb 2015 16:55:03
Message: <54d143b7@news.povray.org>
Ah yes, I/O-mapped I/O. I've read about this, but I've never actually
seen it in action. Presumably it just means that you use a different
op-code to access stuff in the I/O address space? (And that the same
address can exist independently in both address spaces. And presumably
the two addresses can be different widths...)
OK.
> mode.
So I'm imagining for stuff that doesn't have many registers (e.g., the
keyboard controller), the whole thing is I/O-mapped. Whereas for
something like the sound card, you poke a bunch of (main) memory
addresses into I/O-mapped registers and say "have at it!"
As I see it, a DMA controller is just another I/O device - one who's
only job is to copy chunks of RAM around while you're not looking. Given
the previous paragraph of speculation, I'd expect all the stuff for
controlling DMA to be I/O-mapped, but who knows?
But remember, the BIOS and the OS are JUST PROGRAMS. ;-) They have to do
this stuff too, eventually. But yeah, your typical application program
will never, ever have to care; it just passes instructions to the OS,
which then uses a dozen device drivers and protocol stacks...
Fun fact: My PC doesn't *have* a BIOS. It has an EFI. ;-)
The latest Intel Core-i chips have an on-board GPU. I *presume* that if
you utilise this, everything happens in main RAM.
By contrast, my nVidia GeForce GTX 650 has almost *one gigabyte* of RAM
on-board. I presume the vast majority of this is for holding texture
data, which is moot if you're only trying to run MS Word. Even so, I
wonder - does all that RAM ever get mapped into the host address space?
Or do you have to manually pass texture packets across the PCIe bus and
then tell the GPU what shapers to run?
> address range.
So, like I say, you poke some numbers into an I/O register somewhere,
and a little while later you get an interrupt to say your data is now at
the specified memory address. That's how I imagine it working, anyway.
Like I said, I'm just wondering if you talk to (say) the harddisk by
writing a few bytes into some registers telling it to copy LBA #### into
memory address ####. Or whether you have to do something like
* Build an ATA command packet in memory.
* Construct a PCIe bus message frame around it.
* Poke numbers into the PCIe controller telling it to transmit that
chunk of memory.
or similar. I'd imaging talking to USB devices probably gets crazy.
(Given, you know, the arbitrary tree topology...)
Date: 3 Feb 2015 17:27:07
Message: <54d14b3b$1@news.povray.org>
That would be my guess also.
> the raspberry PI):
I'm not sure it answers my question, but it's certainly a very
interesting read...
Sections 8 and 9 in particular seem to be saying that there's about
two-dozen memory-mapped registers that tell the GPU where the control
lists are, and then it sucks those into the GPU and goes away to do it's
thing.
Date: 3 Feb 2015 23:58:18
Message: <54d1a6ea$1@news.povray.org>
Am 03.02.2015 um 22:55 schrieb Orchid Win7 v1:
Exactly.
Examples from the home computer era would be the Amstrad CPC, and
probably the ZX Spectrum, which both feature a Z80 processor. IIRC the
Amstrad CPC's basic even had dedicated commands for I/O access.
Basicaly yes. Though for memory-mapped devices like the graphics card
you traditionally had hard-wired memory addresses so you wouldn't need
to poke the memory addresses to any I/O address anywhere, and with PnP
the job of poking the memory address would have been done by the BIOS or
OS already.
As for the sound card, IIRC traditionally it was not memory-mapped. You
see, the sound card operates sequentially on non-repeating data, which
is exactly the mode of operation the DMA controller was designed for, so
to save memory address space for true memory (including devices' ROMs,
which are always memory-mapped) the card would present only two I/O
addresses for data (one for reading, one for writing). Same for disk I/O.
It is indeed.
The fun fact though is that it cannot only copy RAM around, but also
between RAM and an individual I/O address, at a pace dictated by the I/O
device, which is great for anything involving serial data processing,
because it means you don't necessarily have to sacrifice precious memory
address space.
On the other hand, nowadays memory address space is plenty (even on a 32
bit machine), while DMA channels (i.e. number of concurrent DMA
transfers) are scarce (and increasingly complicated, due to virtual
memory mapping), so I guess today's hardware prefers memory-mapped
buffers over DMA.
If you really want to go down to that level, I'd suggest getting a
Raspberry PI and trying to write some standalone application (i.e. one
that doesn't need an OS) to run on it. The hardware seems to be well
enough documented to pull off that stunt.
... which is a BIOS on steroids.
Indeed, this feature is typical for on-chip GPUs. Though I think there
are also external chips out there that are designed to utilize main memory.
Well, my graphics card (an ASUS R9 280) utilizes the following resources:
I/O range 03B0-03BB (legacy VGA)
I/O range 03C0-03DF (legacy CGA/EGA/VGA)
I/O range A000-A0FF
IRQ -5
Memory range 000A0000-000BFFFF (128k, legacy MDA/CGA/EGA/VGA)
Memory range FBA80000-FBABFFFF (256k)
Memory range D0000000-DFFFFFFF (.25 GB)
Obviously this is not nearly enough to access all 6 GB of the graphics
card at once, but .25 GB is certainly large enough for a "window" to a
portion of the graphics card's RAM; even traditional Super-VGA cards
used such a window to access a much larger actual framebuffer, using I/O
registers to choose which "page" of their RAM was mapped to the window,
so I guess that's exactly the way it's done with today's graphics cards.
And no, you don't need to tell the PCIe controller anything about this -
unless you're an OS developer and want to place the window somewhere
else in the physical CPU address space.
(As for the 256k memory window, from the size of it I'd guess it's some
kind of ROM.)
Absolutely.
> chunk of memory.
My presumption is that you'd indeed build the whole ATA command packet
in memory, but then just tell the HDD controller to transmit it to one
particular drive. The PCIe bus is totally transparent in this respect
(except of course for the initial setting-up at system startup). So are
the peculiarities of the SATA bus.
I'm sure it is. You don't map individual USB devices to memory
addresses, nor even I/O addresses for that matter. All you talk to is
the USB host controller. But again you don't need to worry whether that
host controller is connected via PCIe, PCI, or even classic ISA.
Date: 4 Feb 2015 03:10:43
Message: <54d1d403@news.povray.org>
Just for interest the original ARMs in the Acorn machines split the
logical address space into two. The first 32MB of address space is what
normal user programs had access to ("user space"), and the OS mapped
whatever was needed into this space (including the screen buffer(s)).
Actual physical devices had addresses in the range 32MB to 64MB (the
original ARMs although 32bit only had a 26bit address space, the other 8
bits in the program counter were used as status and mode flags). The
physical RAM was mapped from 32MB to 48MB, all I/O was mapped between
48MB and 52MB, and above that if you *read* you read from the OS ROM
chips, but if you *wrote* you wrote to various other bits of special
hardware (video/sound controllers etc).
One pretty clever result (or reason?) of the above was that the screen
memory was always mapped from 32MB downwards, and the physical screen
memory was at 32MB upwards. This allowed some nifty vertical scrolling;
code could automatically "wrap around" its graphics drawing by just
deliberately going past the 32MB boundary into the start of physical
RAM. Needless to say you could tell the video controller to start
anywhere in memory (including just before the 32MB boundary) to
physically draw the screen.
Obviously the above scheme limited physical RAM to 16MB (which wasn't an
issue at the end of the 80s), I'll have to look up what they changed to
overcome that. I know that somewhere between ARM3 and ARM6 they added a
true 32bit addressing mode (which of course broke everything that
assumed addresses were only 26 bits wide).
Date: 4 Feb 2015 04:42:36
Message: <54d1e98c$1@news.povray.org>
> interesting read...
> thing.
As clipka said the raspberry pi gives a good opportunity to start
tinkering around with the bare hardware without the restrictions of any
OS. This is a good guide, in particular this page introduces
communication with the GPU (just to create and get a pointer to a
framebuffer):
http://www.cl.cam.ac.uk/projects/raspberrypi/tutorials/os/screen01.html
Date: 5 Feb 2015 03:33:32
Message: <54d32adc@news.povray.org>
> Exactly.
Although I've used all of those systems, I only ever did hardware-level
programming with the C64. (The others all had BASIC commands for
graphics and sound; the C64 didn't. The Commodore Plus4, but contrast,
had *excellent* commands for graphics and sound. Weird...)
> OS already.
Right. So by the time the OS is up and running, you just have to know
which chunk of RAM is mapped to each device.
Intriguing... I didn't know you could do that.
> It is indeed.
> address space.
I've never done hardware-level programming on a system that actually
supports DMA. This is a possibility I wasn't aware of. I kinda assumed
that the I/O device itself handles reading data from RAM at the right
speed. But for purely sequential stuff like disk or sound, it makes
perfect sense...
> buffers over DMA.
Don't look at me. ;-)
Or just, you know, the Pi emulator, which doesn't cost money. ;-)
It isn't. It really isn't. That's what everybody told me, but the more I
read about it, the more it becomes vividly clear that it's a totally
new, different system, unrelated to what went before.
(It's actually very cool. Or, the way it's *supposed* to work is very
cool; whether anyone will implement it correctly remains to be seen.
Currently this stuff seem incredibly buggy...)
Yeah, I would think all those motherboard with on-board graphics do
this. (Having said that, those boards are getting rare now all the CPUs
have the GPU on the die...)
So the CPU can only access a limited window at a time. (Mind you, .25 GB
should be easily enough to hold the entire frame buffer. This becomes
more of an issue if you're trying to dump 0.8 GB of texture data into
the card before you start rendering...) And of course, if you're doing
3D drawing, the CPU has almost nothing to do with it, it's all the GPU.
So aside from assigning memory mappings, PCIe is transparent to the CPU. (?)
So, again, the PCIe bus from the CPU to the PATA / SATA / USB / FireWire
/ whatever controller is transparent, but USB itself isn't transparent,
and you still need to know how to build ATA commands or whatever. (?)
Date: 5 Feb 2015 07:25:02
Message: <54d3611e$1@news.povray.org>
Am 05.02.2015 um 09:33 schrieb Orchid Win7 v1:
It's actually a quite simple mechanism, at least in basic theory. The
idea is that the CPU has an input telling it to stall any bus access for
a moment; the DMA asserts this signal to take over the bus for one
memory access and another I/O access, then releases the bus again. The
DMA controller in turn has an input by which the device hardware can
signal that it is ready to transfer the next byte.
This was great stuff especially in the times when memory could go a good
deal faster than the CPU could make use of it.
Well, things have changed: Memory access is the biggest bottleneck of
all now.
Because a Raspberry Pi is soooooo extraordinarily expensive, sure... :P
Drawback of the Pi emulator is that it doesn't come with all those neat
I/O pins ;)
Memory mappings, IRQ mappings, I/O mappings, assignment of number of
PCIe lanes... But yes - that's the gist of it.
Yup.
