POV-Ray : Newsgroups : povray.off-topic : Wireless connection issue Server Time
15 Jun 2026 21:09:06 EDT (-0400)
  Wireless connection issue (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Wireless connection issue
Date: 19 Jun 2014 10:41:06
Message: <53a2f682@news.povray.org>
On 19-6-2014 15:27, scott wrote:
> - Reinstall your wireless hardware driver (find it in device manager,
> right click on it and choose "uninstall" then restart the machine). That
> should make it reinstall the drivers and then create a new connection
> from scratch.
I assume you mean this (see image) in Win7?
Download 'wireless lan card properties_drivers.jpg' (73 KB)
Preview of image 'wireless lan card properties_drivers.jpg'
Date: 19 Jun 2014 10:51:10
Message: <53a2f8de$1@news.povray.org>
>> from scratch.
Yep - I'd just hit uninstall and then restart the machine, it should
then find the "new" hardware and install the driver for it when it
restarts. Make sure you have a copy of the driver handy just in case
Windows has lost it... (maybe a good opportunity to check you have the
latest one anyway).
Date: 19 Jun 2014 10:59:53
Message: <53a2fae9$1@news.povray.org>
> latest one anyway).
Right.
I checked the drivers and they are up to date.
I did something else then (had found that on the web): in the 'Device
Manager' I (1) /uninstalled/ the wireless LAN, then (2) from 'Action' I
did 'Scan for hardware changes'.
Worked but unfortunately, that did not solve the issue.
I am going further tomorrow...
Date: 20 Jun 2014 13:02:44
Message: <53a46934$1@news.povray.org>
>> Has this setup (modem, wireless card, PC, software) ever worked
>> correctly, or did it just suddenly stop working one day?
> Yes, it did work perfectly for several years but gives trouble since a
> router's reset.
Maybe your neighbor put MAC address filters to make you stop from
stealing his bandwidth!  ;)
Seriously though, check your router's encryption settings (Did the WPA
key get reset, etc...)
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 23 Jun 2014 03:42:44
Message: <53a7da74$1@news.povray.org>
I assumed Thomas had other devices working ok with the modem via
wireless, but maybe that was an incorrect assumption (I'm used to having
half a dozen devices on wireless) - good call.
I once had a modem/router that would not persist settings after a power
cycle unless you specifically went to the "save changes" page and told
it to save them. Caught me out.
Date: 23 Jun 2014 03:57:32
Message: <53a7ddec$1@news.povray.org>
I addressed him sternly and he promised to make amends :-)
As far as I can tell, That went ok.
Date: 23 Jun 2014 04:01:31
Message: <53a7dedb$1@news.povray.org>
I only have one device indeed. So, strictly speaking, I not even do need
wifi, but I like things to work properly of course.
True. I certainly need to 'save' all changes before changing pages on
the modem/router.
Date: 23 Jun 2014 06:55:40
Message: <53a807ac$1@news.povray.org>
Ah ok - well if all you did was reset the router and it stopped working,
then it seems likely there is nothing wrong with your PC at all, and the
problem is with the router.
You could try logging in to your router (with a cable) and turning off
all wifi encryption just to see if the PC can connect at all (of course
turn it back on straight after). While you're in there also have a look
through to make sure there's nothing else preventing the connection.
I don't know if windows remembers the access point by name or not, but
you could try changing the SSID of the router to see if that makes
windows "forget" the old connection and make a new one.
Date: 23 Jun 2014 07:51:33
Message: <53a814c5$1@news.povray.org>
I seem to remember to have deleted also some wireless networks that
seemed redundant to me and probably generated in the past... Just kept
the most 'familiar' one. Can I delete that too, and try to make a brand
new network? because all changes to the network now just change the
existing network without connecting.
I do not seem to be able to turn off all encryption. It is either TKIP
or AES or both. However, disabling the Authentication Type (from
WPA-PSK/WPA2-PSK normally) did not either make a connection possible.
No, this does not make any difference.
Running the Maintenance Diagnostics of the modem/router, I get two
failures: one at "Testing ATM OAM segment ping" and the other at
"Testing ATM OAM end to end ping".
At the ATM VC section I see nothing strange, and equal to when
everything worked:
Virtual Circuit: PVC0
Status: activated
VPI: 8
VCI: 48
ATM QoS: UBR
PCR: 0
Date: 23 Jun 2014 11:05:09
Message: <53a84225@news.povray.org>
There's no harm in deleting all the stored wireless networks, the worst
that will happen is that you need to re-enter the encryption key.
That's strange - it would really help to get another device (even just a
smartphone) to try and connect to the router via wifi. That would tell
you if the problem was with the router or the PC.
