POV-Ray : Newsgroups : povray.off-topic : Oculus Rift rules Server Time
16 Jun 2026 00:17:00 EDT (-0400)
  Oculus Rift rules (Message 16 to 25 of 25)
Subject: Re: Oculus Rift rules
Date: 23 Dec 2013 08:23:40
Message: <52b8395c$1@news.povray.org>
On 23/12/2013 09:23 AM, scott wrote:
> If it does take off then there are significant opportunities for further
> development, thinner, lighter headsets, higher resolution/framerate,
> wider FOV, wireless connection etc.
I spent all of last night reading about holographic displays.
[No, I do not mean volumetric displays. I mean a display where you
compute the interference patterns of an optical wavefront, then use some
kind of display device to produce that pattern.]
The big plus with this is that objects at different distances have
different focal depths - exactly like they do in the real world. The
machine basically generates the same light rays that the real object
would, so your eyes can respond to it the way they normally do already.
No weird glasses required. Multiple viewers possible. Etc.
The big downside is... you need an *insane* pixel pitch. And then you
need a small supercomputer if you want to draw this stuff in realtime.
I did see a demo of a commercial offering which is supposed to be coming
to market soon - but it uses eye-tracking to slash the amount of
processing power required. (I.e., it won't actually work in the real
world and so will never be commercially viable.)
Date: 23 Dec 2013 08:58:43
Message: <52b84193$1@news.povray.org>
A friend from university did this:
http://lightblueoptics.com/videos/holographic-laser-projection-technology/
Judging by the (lack of) recent updates it didn't really take off.
FWIW before this, his research project at university was to modify a CD
burner to burn holograms onto a CD. I guess the "pixel pitch" on a CD is
enough for it.
Yes, eye tracking always introduces further issues. One demo I saw,
which I'm surprised hasn't taken off, is to use the video feed from a
camera as an environment map texture. This demo was running on a laptop
using the inbuilt webcam and the way shiny surfaces reflected your face
and what was behind you in the room was very believable.
Date: 23 Dec 2013 09:14:20
Message: <52b8453c$1@news.povray.org>
Indeed.
I also found a website with software for computing interference
patterns. They claim that if you take something like a 600 DPI laser
printer and print the pattern onto a transparency, you can shine a laser
pointer through it and get a very fuzzy, very grainy hologram. (Assuming
your printer doesn't try to interpolate or otherwise alter the precisely
computed pixel patterns!)
> enough for it.
CD? Perhaps not; CDs don't use visible light, they use infra-red, so the
dot pitch might not be small enough. A DVD, on the other hand, uses a
red laser, so it certainly ought to be able to do a red-light hologram
without difficulty. (Provided you can convince the drive to put the dots
where you want them!)
When I was at university, we were told that several companies had 3D TV
technology that was "nearly ready for market". That was ten years ago.
(I suppose they were probably talking about the laughably primitive
lenticular lens technology that you occasionally see in shops and stuff.)
Date: 23 Dec 2013 09:37:44
Message: <52b84ab8$1@news.povray.org>
Oooh that sounds interesting, might have to give that a go. I got one of
those cheap $20 green laser pointers, if you focus it it's enough to
light a match or melt your name into anything plastic :-)
Well if a 600dpi print just about works, then by my rough estimations a
CD should be about 20000 dpi. Maybe not perfect, but it works.
You can't without modifying the drive. IIRC they had to bypass pretty
much the whole signal path and just drive the laser directly (well not
quite, but you get the idea).
10 years ago the company I used to work for was already selling a laptop
and mobile phone with a parallax barrier 3D screen (that could be
switched between 2D and 3D mode). That technology has developed into the
dispay in the Nintendo 3DS and LG Optimus 3D today. That type of 3D is
fine for single-user applications (because no glasses are needed), but
for multi-viewer it obviously doesn't work.
Date: 23 Dec 2013 10:07:00
Message: <52b85194$1@news.povray.org>
Am 23.12.2013 15:14, schrieb Orchid Win7 v1:
There are even people out there who, using nothing but a compass with a
sharp tip, cut patterns into acrylic glass to produce simple
stereographic images (point clouds actually).
And yes, it appears to actually work.
Date: 23 Dec 2013 10:18:15
Message: <52b85437$1@news.povray.org>
You can often see holograms in the paintwork of cars on a sunny day, it
looks like an odd lens flare effect that is hovering some distance above
the paintwork. It is caused by poor washing technique which drags grit
across the paint creating tiny (but nothing like the wavelength of light
tiny) grooves in the paint.
Date: 23 Dec 2013 10:23:27
Message: <52b8556f$1@news.povray.org>
Knock yourself out:
http://corticalcafe.com/software_onlineCGHinstructions.htm
They demo it with a red laser; I don't know if that's crucial. (The
laser wavelength is probably adjustable in the program...)
Yeah, I've been sat here trying to figure out what the actual DPI of one
of these disks is. I guess it requires knowing how many inches per meter
there are. :-P
Doesn't LightScribe help here? Or does that only allow you to specify a
grey level, which the device itself then dithers?
Date: 23 Dec 2013 10:26:25
Message: <52b85621@news.povray.org>
Am 23.12.2013 16:18, schrieb scott:
Yup, that's essentially the method they use for it - except that they do
it on purpose :-P
Date: 23 Dec 2013 10:58:07
Message: <52b85d8f@news.povray.org>
> Knock yourself out:
Bookmarked - will definitely try that. I wonder if an ink-jet will work
just as well...
> of these disks is.
I estimated 7e9 bits of data (probably an underestimate due to error
correction bits etc) and an area of 17 square inches. sqrt(7e9/17) is
about 20000 dpi.
Maybe, but you'd probably still have to hack the hardware significantly
to allow the lightscribe functionality to work on the data side of the
disc at a much higher resolution.
Date: 23 Dec 2013 11:19:33
Message: <52b86295$1@news.povray.org>
>> Knock yourself out:
> just as well...
I suspect you'll find it nearly impossible to convince an inkjet to put
the dots exactly where *you* asked for them.
>> of these disks is.
> about 20000 dpi.
...or you could just look up the pit width figure from the spec sheet,
and work out how many times that fits into an inch. ;-)
That sounds like just a firmware nudge to me...
