POV-Ray : Newsgroups : povray.off-topic : Where is the world going? Server Time
12 Oct 2026 05:39:25 EDT (-0400)
  Where is the world going? (Message 101 to 150 of 199)
<<< Previous 50 Messages Goto Latest 50 Messages Next 49 Messages >>>
Subject: Re: Where is the world going?
Date: 13 Sep 2013 00:43:05
Message: <523297d9$1@news.povray.org>
On Thu, 12 Sep 2013 16:22:42 -0700, Patrick Elliott wrote:
> True, some people, like a certain niece of mine, can't even figure out
> that, "You need to change the oil once in a while."
> But, cars you at least "can" do maintenance on, or have other people do
> so, and you don't generally, on having them do that, find that 90% of
> the "experts" you might want to take them to are going to either a) be
> unable to fix a broken taillight wire, or b) do so without stealing
> every single things you had in the trunk, and throwing it in a dumpster,
> because it was "unfixable" with all your shit still in the vehicle. PCs,
> especially, tend to exhibit both traits....
No, those who want to learn how stuff works can, even with PCs.
But a microchip is just a tad more complex than a combustion engine,
too.  The same holds true for magnetic recording media, storage devices,
etc.
Jim
Date: 13 Sep 2013 01:20:50
Message: <5232a0b2@news.povray.org>
> too.
Not any more it's not. ;-)
I used to service my own cars and bikes. Other than check the fluids all
I can do with the engine nowadays is check that it is still there. :-)
Regards
Date: 13 Sep 2013 12:44:25
Message: <523340e9$1@news.povray.org>
>> too.
Well, some cars have computers in them now, that's true.  But the
mechanical parts are still basically the same.  Patrick's analogy is
flawed because he's comparing physical items in the boot to data on a
hard drive.  The two are so /not/ comparable it's not even funny.
Jim
Date: 13 Sep 2013 19:17:49
Message: <52339d1d$1@news.povray.org>
>>> too.
> Jim
Give me a break. It was supposed to be a bit of a joke. But, it is never
the less true anyway. "Reinstall" is practically a #1 solution in
Windows, when things break bad enough, and, even if you don't throw out
everything in the trunk when you do that (instead of the equivalent of
taking it out, then putting it all back in again), the process of
"fixing" a problem by doing such a thing goes a bit beyond replacing the
air freshener. Its more like stripping the car down to the body shell,
then having to "reinstall" every single part, from the ground up, just
to fix a loose wire, at least.. under Windows anyway. Linux is a bit
less stupid about it. But, if you want a better example, how about a
motor home, instead of a car? Those things are, from what I brother
says, built with no clear plan, beyond the chassis, everything tacked on
where ever it fits, and damn near no intention/design-considerations,
with respect to, "How the fuck is someone supposed to get at this part
of the vehicle, to fix it, when it break, without literally removing
half of the entire vehicle, and everything installed in it?"
So, yeah, there can be some valid comparisons you can make.
Date: 13 Sep 2013 19:39:15
Message: <5233a223@news.povray.org>
On Fri, 13 Sep 2013 16:17:48 -0700, Patrick Elliott wrote:
> Give me a break.
OK, done. :)
Jim
Date: 14 Sep 2013 02:50:19
Message: <5234072b$1@news.povray.org>
>>> too.
Would you not consider a car's fuel control system a computer?
> But the mechanical parts are still basically the same.
Yes the bits that go roundy round are basically similar as is the
structural nits. But how do you set up the spark plug timing on your car?
All analogies break down at some point, eh?
The real problem is that computers are domestic appliances now. They are
not just for geeks.
Here is another analogy or parable, whatever.
Rule number one when working with electrical equipment is disconnect it
from the mains before opening it up. Yes?
So you can understand in a way why my boss's boss gave me a bollocking
for working on exposed live equipment. (H&S to the forefront)
He had no answer to my question "How do I trouble shoot if it is dead?"
He went away, I powered it up, found the fault and all was well.
Mixing techie and non-techie is a very hard thing to do.
I've run out of steam, now.
Regards
Date: 14 Sep 2013 13:32:41
Message: <52349db9$1@news.povray.org>
>>>> too.
>>> all I can do with the engine nowadays is check that it is still there.
Depends on the car.  Not if it's just a throttle cable.
> car?
I have no idea - but I could ask my father-in-law or brother-in-law.
IIRC, there's a timing belt/chain in older cars that don't use electronic
fuel injection.
>> Patrick's analogy is flawed because he's comparing physical items in
>> the boot to data on a hard drive.  The two are so /not/ comparable it's
>> not even funny.
> not just for geeks.
Not necessarily.  First, unplugging it isn't going to protect you from a
charged capacitor - any first year electronics student knows that.
Well, sure.
Date: 14 Sep 2013 15:52:35
Message: <5234be83@news.povray.org>
Maybe it is just me but I've not had a car that had a direct throttle
drive for 20 years or so and I don't buy new cars. Current one is almost
10 years old and the one before that was 13 years old when it died on me.
>> car?
> fuel injection.
It is the distributor that you adjust. Using a timing light connected to
the #1 spark plug. The strobe effect makes a timing mark on the fan belt
drive wheel appear stationary. The distributor is adjusted to that the
dynamic timing mark is at TDC. IIRC
>>> not even funny.
>> not just for geeks.
That why I missed that out so not to take up more bandwidth and to
respect you savy-ness.
> Well, sure.
So that is where the problem lies. Manufacturers don't make a lot of
money if they can't sell a product to lots of non technical people.
And if you try to make a computer idiot proof, techies rail at the
restrictions imposed.
I want to buy a new laptop but I don't want Win 8 with "even your 5 year
old can operate it" OS. Nor do I want Linux where I'll have to learn a
new OS or not be able to run M$ office, for work compatibility.
I might as well ask here. Does anyone have any recommendations for a
light weight laptop that has a reasonable spec to run PovRay and Blender
and weighs a lot less the the 3kg (6.6 lb) DTR I have to lug around?
Regards
Date: 14 Sep 2013 16:33:07
Message: <5234c803@news.povray.org>
> me.
Well, yeah, like I said, if it's not an EFI system, but those have been
around for a while.
>>> car?
>> electronic fuel injection.
See how much I know about cars?  I changed the battery once and was shown
how to change the brake pads once, but I'm no expert.  Amy knows a lot
more about that sort of stuff - which makes sense, since she grew up in a
family that works on cars (her brother teaches auto body repair at the
local vocational/technical school where she grew up).
>> a charged capacitor - any first year electronics student knows that.
>>> dead?" He went away, I powered it up, found the fault and all was
>>> well.
>> Well, sure.
Yep.  And that's the problem Patrick has.  The system is idiot-proof, but
he's no idiot, and wants to do what he wants to do.  You can't mass-
market something like that, though, because the non-technical people who
make up the "masses" are going to be idiots when it comes to technology,
because they just want to drive to work, they don't want to fine-tune the
fuel injection system.
So you have to compromise and get the mass-market option.
I've been happy with my Dell laptop, but I'm not sure how much it
weighs.  It's a couple years old - the 17R (N7110 is another number I see
associated with it), but is pretty speedy (i7 processor) and has plenty
of memory (8GB, max for this model).
Jim
Date: 15 Sep 2013 06:42:19
Message: <52358f0b$1@news.povray.org>
It was necessity that taught me. Not a love of getting my hands dirty.
I was going to say, not quite idiot proof, but then I thought of one of
my brothers-in-law. Who is handless but only knackers his computer
because he downloads every free game he can. So I suppose it is.
Maybe it is age that makes me feel that I can't be bothered keeping up
with the times but want to stay with something that works the way I know
it works. And since I don't want all the touch screen junk. I might buy
an ultra laptop (what a name) and buy a copy of Win7 and install that
over Win 8.
Yes. Doesn't make me a happy bunny, though.
It looks good, similar spec to my Toshiba but with a bigger HDD. Still
it is hefty at > 3 kg. I want something lighter even if it has a lower
spec. All the travelling that I'm doing atm means my tennis elbow is
playing up.
Regards
Date: 15 Sep 2013 14:08:11
Message: <5235f78b@news.povray.org>
>> shown how to change the brake pads once, but I'm no expert.  Amy knows
>> a lot more about that sort of stuff - which makes sense, since she grew
>> up in a family that works on cars (her brother teaches auto body repair
>> at the local vocational/technical school where she grew up).
I think that was the case for Amy as well.  Family business, everyone
chips in.
> over Win 8.
Well, you just want to use it as a tool - you don't want to be a
mechanic. :)
>>> Blender and weighs a lot less the the 3kg (6.6 lb) DTR I have to lug
>>> around?
>> see associated with it), but is pretty speedy (i7 processor) and has
>> plenty of memory (8GB, max for this model).
> playing up.
Some of the ultras are supposed to be pretty good - ISTR that Dell has
something like the Macbook Air now.  I'm actually a little surprised that
Apple hasn't sued them yet.
Jim
Date: 15 Sep 2013 17:09:35
Message: <5236220f$1@news.povray.org>
> mechanic. :)
But the sad thing is, I did want to be a mechanic. Well an electronic,
mechanic. And I was for many years.
When I started working with computers. You had to enter about a dozen
instructions in binary (or BCD) into switch registers just to tell it
that you wanted it to read from a paper tape reader. Then you would load
an operating system then load the program. Then wind the tape back into
rolls.
Now it is a washing machine. That does (or mostly not) what I want it to do.
Why is that a standard?
Anyway I will look into it, I don't want to spend a fortune for
something that will run Blender, I can't see me seriously using Pov on
it for a while.
They have probably got enough on their plate atm.
Regards
Date: 15 Sep 2013 17:13:50
Message: <5236230e@news.povray.org>
>> mechanic. :)
People change over time, though - obviously.  I may well get to that
point myself.
> rolls.
> do.
I don't remember those days, but I do remember entering BASIC programs
from Dragon magazine to generate characters for D&D.  We didn't have a
cassette drive or disk drive at first, so if I wanted to run the program,
I had to enter it by hand.  That meant the computer stayed on more than
it probably needed to be, and on more than one occasion, my parents
turned it off without realizing that they'd caused a day's worth of data
entry to be lost.
Because it's small and lightweight, and generally (I hear) has good
battery life.
> it for a while.
That's part of the tradeoff these days, I think - you can have small and
lightweight, or you can have power.  Granted, the power in the smaller
systems is increasing. :)
>> I'm actually a little surprised that Apple hasn't sued them yet.
*snortlaugh* like that ever stopped them. ;)
Jim
Date: 17 Sep 2013 05:51:15
Message: <52382613@news.povray.org>
>> too.
Especially given that most engines have needed several microchips even
to start for at least a decade or two.
All cars have a diagnostic port, there is pretty cheap equipment you can
buy to attach to this and do lots of useful things. I was able to
diagnose a faulty fuel pressure sensor, replace it and reset the fault
codes. It cost me almost nothing, whereas the garage wanted it for 3
days to diagnose (surely $$$).
Engines have got a lot more complicated, but now we have the internet so
unless you have a *really* exotic car, there is always going to be
someone somewhere who has done/fixed what you want and documented it.
Date: 17 Sep 2013 14:27:23
Message: <52389f0b$1@news.povray.org>
>>> too.
There's usually also a sequence with your car key that you can do to get
the "service engine" light to blink error codes.  If you don't have an
R2 unit handy to interface with the onboard computers.
Yep.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 18 Sep 2013 11:34:56
Message: <5239c820$1@news.povray.org>
>> I don't see how it's any different to any other modern GUI in terms of
>> graphical capabilities. The icons are much bigger because it's meant for
>> much higher dpi screens and using your fingers rather than a mouse.
> And the reduced colour set and the all-caps sans serif text and the
> square button edges?
The buttons seem to me to be full resolution 24bit colour, and I don't
see how all-caps and square edges are anything to do with graphical
capability - that's just design decisions.
If you want to see what it would look like with 30-year-old graphics
capability then take any of the screen-grabs of Win8 from Google image
search, and convert it to 160x256x3bpp or 640x256x1bpp (the modes the
BBC had at the time). Then scroll it across your screen at 1fps :-)
Date: 21 Sep 2013 04:11:48
Message: <523d54c4$1@news.povray.org>
> point myself.
You may indeed when new challenges arrive.
> entry to be lost.
Groan!
> battery life.
That makes sense.
>> it for a while.
I know that but I don't want it to be so. :-)
If I keep wishing then maybe...
Lawsuit ping pong.
Regards
Date: 21 Sep 2013 15:10:04
Message: <523def0c$1@news.povray.org>
>> point myself.
Indeed.  Douglas Adams had a theory about that:
"Anything that is in the world when you're born is normal and ordinary
and is just a natural part of the way the world works. Anything that's
invented between when you're fifteen and thirty-five is new and exciting
and revolutionary and you can probably get a career in it. Anything
invented after you're thirty-five is against the natural order of things."
I'm now 43 (as of a couple weeks ago) - I think the ages aren't
necessarily set in stone, but in principle, this makes sense.  You
eventually get to the point where keeping up is too much of a bother, and
things were "always" better "back in the old days". :)
>> data entry to be lost.
> Groan!
One of a couple things my parents did when I was a kid that drove me
crazy. Another was deciding when the one TV programme I wanted to watch
that day was on that *that* was the time I needed to be told to go clean
my room/take out the trash/whatever. 30 or 60 minutes later wasn't good
enough, it had to be done *right then*.
Before we had a VCR, it was even worse.
>>> it for a while.
>> and lightweight, or you can have power.  Granted, the power in the
>> smaller systems is increasing. :)
LOL
> Lawsuit ping pong.
Indeed.
Jim
Date: 22 Sep 2013 06:18:22
Message: <523ec3ee@news.povray.org>
Pity, he did not have a theory about keeping deadlines.
It sounds like a good theory but I don't really think that it cuts the
mustard.
Belated happy birthday.
Yes, but at midlife?
I've reached the stage where keeping up with domestic computer tech is
too much bother. I don't think that it is because I'm nearing retirement
age but that the effort is not worth the return. Especially, when
changes are done more in the spirit of selling new products rather than
for innovative functionality.
I see the smiley. And I hear it often.
It falls into two categories, IMO.
Life was better when I was young, people were better educated, more
polite and had time for others. Better quality of life etc.
And: Technology is too complicated, things were better when you could
understand how they worked. Such as a baud rate of 9600, RAM memory 640
kB. Cars that did not have ABS, seat belts, crumple zones. I cold go on.
I've heard it since I was a kid and if you extrapolate backwards...
As long as you didn't repeat their mistakes.
Regards
Date: 22 Sep 2013 14:56:46
Message: <523f3d6e$1@news.povray.org>
Well, he sort of did, but it had to do more with the noise they made as
they went past. :)
>> exciting and revolutionary and you can probably get a career in it.
>> Anything invented after you're thirty-five is against the natural order
>> of things."
> mustard.
Well, like I said, the ages involved perhaps aren't accurate for
everyone, but for a large number of people, I think this makes a lot of
sense.
Thanks!
>> - I think the ages aren't necessarily set in stone, but in principle,
>> this makes sense.  You eventually get to the point where keeping up is
Well, like I said, it depends on the person.  I know some people who hit
that "35" point much earlier, and some who hit it much later.  I think
the point isn't so much the specific values, but that this happens to
pretty much everyone at some point.
Another Adams quote applies:
"We are stuck with technology when what we really want is just stuff that
works."
Yup.
Both situations are true - but I think it also is a trick the mind plays
by idealizing the past as well.  I hear this sort of thing, for example,
said by pundits here talking about how much better things were back when
they were kids.  But the average American kid back in the 70s (or
earlier) wasn't exposed to all the world's problems unless they were on a
very huge scale.  So memories of the time tend to be far more idyllic
than the actual time.
>> clean my room/take out the trash/whatever. 30 or 60 minutes later
>> wasn't good enough, it had to be done *right then*.
I made a conscious effort not to.  I'm happy to say that our kid is
pretty well adjusted, too. ;)
Date: 22 Sep 2013 15:30:45
Message: <523f4565@news.povray.org>
> they went past. :)
Woosh! ;-)
>> mustard.
> sense.
Very few of the people I know are like that.
But I won't argue, for once. :-)
I am a fairy and my name is Nuff.
Fairy Nuff. ;-)
> works."
True.
I think that is the crux of the matter.
> they were kids.
Somehow some people think that most people want to hear that. I could be
wrong and I was, once before. ;-)
> very huge scale.
For a start most kids don't pay attention to what is going on outside
their own environment. And I get the feeling that most Americans are
quite insular, happy to live in their own world. (No offence intended.)
Indeed, it is only looking back on my childhood, with the eyes of an
adult who has travelled. That I see I was brought up in a deprived area
and time. Then The sixties and seventies were upon us. And swinging
Britain made everything groovy.
:-D
Regards
Date: 22 Sep 2013 16:58:32
Message: <523f59f8@news.povray.org>
>> they went past. :)
> Woosh! ;-)
Yup.  The quote is actually etched into the glass of the returns desk at
our local library. :)
>>> mustard.
>> sense.
Awww, that's no fun. ;)
>> hit that "35" point much earlier, and some who hit it much later.  I
>> think the point isn't so much the specific values, but that this
>> happens to pretty much everyone at some point.
> Fairy Nuff. ;-)
>> that works."
> True.
Based on that, I can respect (even if I don't agree with) his decision to
use Macs. ;)
>> when they were kids.
LOL
>> But the average American kid back in the 70s (or earlier) wasn't
>> exposed to all the world's problems unless they were on a very huge
>> scale.
Exactly.  And yeah, no offense taken - I see this with a lot of people I
interact with over here - the only thing that matters is them, not the
other people around them.
It's less common amongst liberals, I think, than conservatives.  The
irony is that many conservatives claim to be Christian, but then do
things like cut foot stamp programs because they help those "freeloading
poor people".  Yeah, because living high on the hog when you're poor is
*so* great.
>> So memories of the time tend to be far more idyllic than the actual
>> time.
One of the most eye-opening experiences I had was going to Moscow when I
was 17.  Seeing that people there were essentially the same as people
here really colored my worldview about the difference between people and
politicians/politics.
> :-D
I know, a shock. :)
Jim
Date: 22 Sep 2013 17:09:56
Message: <523f5ca4$1@news.povray.org>
>>> they went past. :)
>> Woosh! ;-)
>>>> mustard.
>>> sense.
For you maybe. :-)
>> Fairy Nuff. ;-)
Up yer chuff.
Oops! did I say that out loud?
>>> that works."
>> True.
> use Macs. ;)
A techy he was not.
(A worker he was not either.)
> LOL
I'm quoting from Peanuts.
> *so* great.
Grrr!
We have the likes here too. :-(
Yeah, people are people. It's the bloody politicians and religion, in
fact leaders in general that give us a bad name.
>> :-D
> I know, a shock. :)
No, a delight.
This is radio free Stephen, signing off until next weekend. :-)
Regards
Date: 23 Sep 2013 02:21:29
Message: <523fdde9$1@news.povray.org>
> For you maybe. :-)
Well, from my point of view, that's the one that matters. ;)
>>> Fairy Nuff. ;-)
> Up yer chuff.
I believe you did. :)
>> to use Macs. ;)
> A techy he was not.
Certainly true, though he was a fan of technology.
>>> be wrong and I was, once before. ;-)
>> LOL
Interesting, I don't recognise it as Peanuts myself.
>> I interact with over here - the only thing that matters is them, not
>> the other people around them.
Black Friday is about the best example.
>> "freeloading poor people".  Yeah, because living high on the hog when
>> you're poor is *so* great.
> Grrr!
As someone who actually tried to collect unemployment (and someone who is
reportedly pretty smart), I couldn't see how the system could be "gamed"
the way that is claimed.
Maybe I'm just not devious enough.
>> I was 17.  Seeing that people there were essentially the same as people
>> and politicians/politics.
Yup.
>>> :-D
>> I know, a shock. :)
> No, a delight.
I'll take that, too. :)
LOL
Jim
Date: 30 Sep 2013 13:18:56
Message: <5249b280$1@news.povray.org>
"Jim Henderson"  wrote in message news:523def0c$1@news.povray.org...
I agree with the timeline (40 next week), but I have a different
interpretation. I feel differently about "new" things as my perspective
increases. I remember being believing in gradeschool that we'd be
millionaires if we "learned computers." I remember believing in Junior High
that we'd all be replaced by robots. I remember believing in my early 20s
that we'd all be working at home by now. I remember feeling that history was
made up of "before the Internet" and "after the Internet."
... and I hear young people now talking the same way about social networking
and crowd sourcing. To me, it's the young who feel these things are "against
the natural order." As a middle-aged person, I see them as very much part of
the natural order, just more of the same.
I remember asking my 100-year-old great-grandmother, who crossed Texas on a
covered wagon, what she thought of modern automobiles and flying a spaceship
to the moon. She shrugged. "People still get up, put on their shoes, and go
out to work."
-Shay
Date: 30 Sep 2013 13:29:58
Message: <5249b516$1@news.povray.org>
"Jim Henderson"  wrote in message news:523f3d6e$1@news.povray.org...
> they were kids.
BS. mindless phone games, unedited youtube media, obesity, re-blogging
Things _were_ better in the (recent) past.
Date: 30 Sep 2013 16:19:36
Message: <5249dcd8@news.povray.org>
>> plays by idealizing the past as well.  I hear this sort of thing, for
>> example,
That's not the type of "better" I (or the pundits) am talking about.
Nor, really, is the "recent" past what's being compared to.  The pundits
in question (mostly on Fox news, but not exclusively there) are referring
to the 50's and 60's, when they were kids.
One might also argue that obesity has long been around - in fact, food
related health issues were somewhat worse back "in the old days".
But the topic the pundits in particular are talking about are things they
claim are going on today that weren't back then (but they were, they just
weren't aware of them because, as a kid, you don't notice international
events so much - even when they're covered in school).
Jim
Date: 30 Sep 2013 16:24:00
Message: <5249dde0@news.povray.org>
>> of things."
> High that we'd all be replaced by robots. I remember believing in my
> early 20s that we'd all be working at home by now. I remember feeling
> that history was made up of "before the Internet" and "after the
> Internet."
Yep.
> networking and crowd sourcing. To me, it's the young who feel these
> things are "against the natural order." As a middle-aged person, I see
> them as very much part of the natural order, just more of the same.
Well, yes, but these "new" things aren't really that new.  The way I look
at technology is that the same ideas get rehashed over and over again.
"Social media" today is what the BBS was when we were kids.  The numbers
of people are much larger (and the various systems were more diverse/
separate back then, excluding FidoNET), but conceptually, it's not that
much different.
> on a covered wagon, what she thought of modern automobiles and flying a
> spaceship to the moon. She shrugged. "People still get up, put on their
> shoes, and go out to work."
That's an interesting take - I usually apply it to so-called "hero
worship" that's popular today.  I have all the respect in the world for,
let's say, people like Mike Massimino, but at the end of the day, he
still takes his pants off just like anyone else.  (Well, OK, it's maybe a
little different in zero-G environments, but you know what I mean)
Jim
Date: 30 Sep 2013 16:36:41
Message: <5249e0d9$1@news.povray.org>
"Jim Henderson"  wrote in message news:5249dcd8@news.povray.org...
Any evidence to for that opinion (excluding famine) would surprise me. I
went to a seven-year-old's birthday party a few weeks ago. Every child there
would have been considered overweight when we were kids.
I'll take your word for it. I don't watch television or listen to talk
radio.
-Shay
Date: 30 Sep 2013 16:40:29
Message: <5249e1bd$1@news.povray.org>
"Jim Henderson"  wrote in message news:5249dde0@news.povray.org...
Puzzled by the 'but'. I think we agree completely.
Date: 30 Sep 2013 18:44:31
Message: <5249fecf@news.povray.org>
> there would have been considered overweight when we were kids.
That seems pretty anecdotal to me.  I'd want to see some real data.
But food-related health issues certainly have been around.  Logically, we
now know things about (for example) fat content, sodium consumption,
sugars, and so on that we didn't know 30 years ago.
Though arguably the best food advice was to be had 30 years ago, too -
"moderation".  We've certainly gone through "eggs are bad for you," "eggs
are good for you," back and forths over the last 10-15 years that have
led me to not really trust any of it beyond moderating intake of
everything.  Fast food once in a while is OK.  Fast food as a steady
diet?  Not so much.
> radio.
That's probably a better way to stay sane, certainly. ;)
Jim
Date: 30 Sep 2013 18:45:53
Message: <5249ff21@news.povray.org>
I do as well.  And I am maybe a little puzzled by my "but" too (quiet,
Stephen M. ;) ) - it's been a weird day today with the work I'm trying to
do being superceded by MS Office problems.  Again.
Jim
Date: 1 Oct 2013 06:32:59
Message: <524aa4db$1@news.povray.org>
I just did an image search for "obesity timeline." I don't have time to
examine any individual studies, but there seems to be a consensus.
> "moderation".
I hear that often, but the obesity trend demonstrates that our idea of
moderate isn't.
Date: 1 Oct 2013 06:40:01
Message: <web.524aa614cafa64a77d8c6e9c0@news.povray.org>
> Stephen M. ;) )
Butt, you know I'm thinking it. ;-)
Date: 1 Oct 2013 06:45:00
Message: <web.524aa68bcafa64a77d8c6e9c0@news.povray.org>
> > they were kids.
That is called growing up and putting aside childish things.
Date: 1 Oct 2013 07:49:19
Message: <524ab6bf@news.povray.org>
"Stephen"  wrote in message
news:web.524aa68bcafa64a77d8c6e9c0@news.povray.org...
No, *collectively* we were less-childish in the recent past. My growing up
has little to do with it. My 16-year-old self would have been "too old for
this shit."
Date: 1 Oct 2013 08:20:01
Message: <web.524aabb7cafa64a77d8c6e9c0@news.povray.org>
Have a look at films from the 60's and 70's. There is very seldom a fat child
unless it is to laugh at. And even then you would not think of them as fat
nowadays. :-(
"moderation".
That is my maxim too. Moderation in everything, including moderation.
It is okay (IMO) to go off the rails, once in a while.
> everything.
"Eggs" have two problems. Dairy food is good for you and dairy food is bad for
you, arguments. And salmonella in the food chain.
> diet?  Not so much.
Master of the understatement, you are.
> > radio.
Talk radio turns your brain to mush and television caters for those with an
attention span not much above that of a goldfish.
All IMO, of course.
Date: 1 Oct 2013 11:57:25
Message: <524af0e5@news.povray.org>
>> Stephen M. ;) )
Of course I did, that's why I warned you off. ;)
Jim
Date: 1 Oct 2013 12:00:17
Message: <524af191@news.povray.org>
>> >> food related health issues were somewhat worse back "in the old
>> >> days".
>> > me. I went to a seven-year-old's birthday party a few weeks ago.
>> > Every child there would have been considered overweight when we were
>> > kids.
> child unless it is to laugh at. And even then you would not think of
> them as fat nowadays. :-(
"Fat Albert" is a counterexample.  OK, it was a cartoon, but still.
That still doesn't strike me as "data" though.  Hollywood makes
intentional choices (most of the time) for reasons.  That they didn't
show any overweight people (or rarely did) just means that they made that
choice, not that overweight people didn't exist.
>> we now know things about (for example) fat content, sodium consumption,
>> "moderation".
Yep. :)
>> We've certainly gone through "eggs are bad for you," "eggs are good for
>> you," back and forths over the last 10-15 years that have led me to not
>> really trust any of it beyond moderating intake of everything.
> bad for you, arguments. And salmonella in the food chain.
And better ways of dealing with those problems now than in the past.
>> Fast food once in a while is OK.  Fast food as a steady diet?  Not so
>> much.
I was looking for an obvious example. ;)
>> > talk radio.
> an attention span not much above that of a goldfish.
> All IMO, of course.
The Internet does a lot of that as well, unfortunately.
Jim
Date: 1 Oct 2013 12:01:34
Message: <524af1de$1@news.povray.org>
>>>> days".
>>> I went to a seven-year-old's birthday party a few weeks ago. Every
>>> child there would have been considered overweight when we were kids.
I'd have to see how those studies were conducted.  But with the increase
of things like high fructose corn syrup in everything now as a sweetner
it wouldn't surprise me.
>> "moderation".
> moderate isn't.
True.
Jim
Date: 5 Oct 2013 06:19:04
Message: <524fe798$1@news.povray.org>
>>> Stephen M. ;) )
Or gave me a challenge. :-)
Regards
Date: 5 Oct 2013 06:20:39
Message: <524fe7f7@news.povray.org>
> up has little to do with it. My 16-year-old self would have been "too
> old for this shit."
Yes, I think that you are right. We grew up earlier then, more
responsibilities.
Regards
Date: 5 Oct 2013 06:37:20
Message: <524febe0$1@news.povray.org>
This may be a cultural thing. In the UK about that time, fat or over
weight was seen to be a sign of greed, gluttany or self/over indulgence.
When I reached 210 lb at 5' 10" I was shocked into going on a crash diet.
It is not, be a climate change denier, if you will. :-P
> Hollywood makes intentional choices (most of the time) for reasons.  That they
didn't
The choice being that it was not acceptable to show fat (or unattractive
people) as being normal.
It is often said that we are about 30 to 50 years behind the states.
That gap is closing rapidly.
Regards
Date: 5 Oct 2013 12:54:11
Message: <52504433$1@news.povray.org>
>>>> (quiet,
>>>> Stephen M. ;) )
Would I do that? :)
Jim
Date: 5 Oct 2013 12:58:58
Message: <52504552$1@news.povray.org>
> diet.
Well, yeah - but we also have causes that aren't due to overeating, but
the stigma is still applied to those who have other issues.
The result is that there are lots of people here who don't know enough to
mind their own business.  Many people feel the need to comment - directly
- to people they don't know about their weight.
LOL
>> That they didn't show any overweight people (or rarely did) just means
>> that they made that choice, not that overweight people didn't exist.
Except that in many cases, they /are/ normal.  It's not really for others
to judge - just like people who get angry at those who have no *apparent*
disability parking in handicapped spaces.  We don't get to ask them for
their whole health history to determine if they meet our expectations for
someone who should or shouldn't have one of the mirror hangers that lets
them park there.
As much as we here in America want health care decisions to be between
doctor and patient, our current system has insurance companies there, and
a large proportion want to stick their noses in others' medical business.
Perhaps so.
Jim
Date: 5 Oct 2013 16:23:26
Message: <5250753e$1@news.povray.org>
>> diet.
Indeed it is. I had an uncle who had something wrong with him. He was
small, even for Glasgow, and rotund. Which is the nicest way I can say
it. It made his life a misery. He did live to a ripe old age, though.
And my mother and brother were/are on constant diets.
I hope that you don't think I was being personal.
> LOL
I win. :-P
> to judge -
Yes and yes.
> them park there.
A couple of years ago, we had a spate of forged disability stickers,
going around. And there was a lot of hard stares going on. It would only
be a very boorish person that would ask. Having said that, there has
been an increase in road rage. And a man was killed, recently over a
parking space at a supermarket. But then when things like that make the
headlines. It must be rare.
I am reading the news stories about obamacare and I'm thinking that
there must be a lot of evil selfish people over there.
But I know what happens when a socialist says anything on the internet. ;-)
> Perhaps so.
I think so. Kids and much older are aping American youth culture. Just
like in the 50's but not James Dean or Marlon Brando.
Regards
Date: 5 Oct 2013 16:25:46
Message: <525075ca$1@news.povray.org>
On 05/10/2013 5:54 PM, Jim Henderson wrote:
>> >Or gave me a challenge.:-)
> Would I do that?:)
I could give you one at TC-RTC when I get my act together after this month.
Regards
Date: 5 Oct 2013 19:18:37
Message: <52509e4d$1@news.povray.org>
>> Would I do that?:)
> month.
Jim
Date: 5 Oct 2013 19:24:01
Message: <52509f91@news.povray.org>
>>> indulgence.
>>> diet.
Oh, no, I didn't think you were being personal at all
>> to mind their own business.  Many people feel the need to comment -
>> directly - to people they don't know about their weight.
>> LOL
> I win. :-P
D*mn you, I'll get you next time. ;)
>> for someone who should or shouldn't have one of the mirror hangers that
>> lets them park there.
It probably is - headlines are intended to be sensational, not to inform.
When I broke my leg in the mid 90's, I was given a handicapped tag (a
temporary one).  It amazed me how many people parked in the spaces who
didn't appear to have a need - but there are, of course, plenty of hidden
causes, to - extreme asthma comes to mind, and that's sadly all too
common here in Utah - because we often have such poor air quality, and
the altitude doesn't help.
>> and a large proportion want to stick their noses in others' medical
>> business.
It really seems there *are* a lot of selfish people here.  The really odd
thing (to me, anyways) is that the most selfish claim to be following a
guy allegedly from about 2,000 years ago who taught such things as caring
for the sick and the poor.  That was, in fact, one of the core lessons
taught.
>> Perhaps so.
Arguably, we don't have "football hooligans" over here, nor have we (yet)
had riots like the one in London a year or two ago.  Well, at least not
*recently*.
Jim
Date: 6 Oct 2013 05:54:42
Message: <52513362$1@news.povray.org>
Good.
>>> LOL
>> I win. :-P
I am sure that you will get your chance. :-)
True.
AFAIK we only give disabled stickers (handicapped has dropped out of
use) to permanently disabled people. My wife qualifies because of her
sight and I could use it to drive her places. But she has never applied
for one because she is mobile and and can walk. (It seems strange to
think of a partially sighted who cannot drive, getting a parking sticker.)
Well here is another "no data" opinion. :-)
I think that the increase in allergies, hay fever, asthma etc. Could be
due to the amount of processed food, we eat.
Discus. ;-)
I did not know about the air quality, the altitude, yes.
> taught.
Taught but not learnt.
It is funny how they pick and chose which parts of the bible they want
to believe. And how it is mostly the old testament, they chose.
It would make you boak. Funny how the Scots have a lot of words for
unpleasant things. :-)
> *recently*.
Tradition, really.
The riots are sometimes the only way to get the politician's attention.
Hell mend the lot of them!
Regards
