POV-Ray : Newsgroups : povray.off-topic : Learning C# Server Time
28 Jul 2026 08:09:56 EDT (-0400)
  Learning C# (Message 21 to 30 of 32)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Learning C#
Date: 29 Sep 2012 19:34:44
Message: <50678594$1@news.povray.org>
On 9/29/2012 14:17, Orchid Win7 v1 wrote:
> In short, writing a correct destructor is a nightmare.
Not really. Writing a complicated class that also has a destructor is a
nightmare. If you have a destructor on a class that has anything more than a
reference to the object you want to destruct, you're probably doing it
wrong. If you're doing more than wrapping the non-GCed resource, you're
doing too much work in that class.
That said, no, destructors aren't especially useful except for logging that
you you forgot to explicitly free your resource. :-)
>> In C++ destructors are useful for more than just freeing memory. For
>> example they are commonly used in things like locks:
Personally, I find that sort of thing terribly confusing. I suppose you get
used to having variable declarations actually being control flow statements,
but I find it rather bizarre.
>> It's handy because you don't need to any special code to
>> make sure that the destructor is called when the function is exited.
I prefer the Sing# method, wherein if you have a variable that needs to be
tracked, and you let it go out of scope without disposing it, the code
doesn't compile. You can still get resource leaks with the C++ method, if
your structures are complicated enough.
   "They're the 1-800-#-GORILA of the telecom business."
Date: 29 Sep 2012 19:40:47
Message: <506786ff@news.povray.org>
On 9/29/2012 12:44, Warp wrote:
> Darren New<dne### [at] sanrrcom>  wrote:
>> Well, C++'s target platforms include things that C# isn't targeted at. If
>> you're trying to fit your code into a credit card terminal, you're going to
>> be worried about C++ template code bloat and the features of C#'s execution
>> model won't even enter the conversation.
> "Template code bloat" is a myth with little to no actual evidence.
I said you'd be worried about it. I didn't necessarily say the worries were
justified. :-)
> If you need the same code to handle more than one type, you have to do that
> somehow. Either you duplicate the code for each type, or you use runtime
> polymorphism, or alternatively you use some really contrived code full of
> conditionals that checks the actual type of the data when it tries to use it.
I think if you have the code for several different pointer types, and you
deal with them all the same way, you might have multiple copies of the same
code getting compiled, right?
I mean, if you instantiate it over int* and float* and MyClass* and
YourClass* and ThisWidget* and ThatWidget*, you're going to wind up with six
copies of that code, right? And if your linker is stupid enough, you're
going to wind up with copies in every place you use that code.
>> The reason C++ makes more code is that it actually does stuff like inline
>> the right calls, doing type-specific generic expansions.
> Inlining can actually *reduce* the size of the binary in some cases (because
> of the subsequent compile-time optimizations).
I'm saying that if you have a collection class instantiated for multiple
types of pointers, C++ has no choice but to expand each, because you don't
declare the type in the template. The compiler and linker would need to be
fairly smart, I'd think, to recognize that myblah.implement(&myBlah) and
yourblah.implement(yourBlah) both generate identical code because the
"implement" function doesn't do anything type-specific with the blahs.
Date: 29 Sep 2012 19:42:46
Message: <50678776$1@news.povray.org>
On 9/29/2012 14:28, Orchid Win7 v1 wrote:
>  From what you're saying, if that code is already compiled to machine code
> but just never /runs/, then it won't increase the working set anyway.
Right. That's what distinguishes "working set" from "code size". Why would
it have a special name?
> And Haskell generates one version of the code, and lets you request specific
> versions if you want them.
Well, all three do that, for some definition of "version" and "request" and
"specific". :-) I think you'd have to be a little more precise if you were
trying to make a point there.
Date: 30 Sep 2012 02:13:39
Message: <5067e313@news.povray.org>
> doesn't compile.
Why? Since the compiler can track when the object goes out of scope, it
can just as easily automatically add the destructor call. Why burden the
programmer with that task? It doesn't make any sense.
Date: 30 Sep 2012 06:06:07
Message: <5068198f$1@news.povray.org>
>> specific versions if you want them.
> and "specific". :-) I think you'd have to be a little more precise if
> you were trying to make a point there.
Java does all polymorphism at run-time.
C++ does polymorphism at compile-time if you implement it with
templates, and at run-time if you implement it with inheritance. (I.e.,
to switch from one to the other, you have to radically restructure your
application.)
I have no idea what C# does.
Haskell does polymorphism at run-time. Unless you add a single compiler
pragma, in which case you can selectively turn on compile-time
polymorphism instead, on a per-function, per-type basis. (Usually only
for types you use heavily, or for primitive types where it's going to
allow lots of other optimisations to fire.)
And really, whether it's done at compile-time or run-time is an
implementation detail. It /ought/ to be trivial to switch from one to
the other...
Date: 30 Sep 2012 14:09:35
Message: <50688adf$1@news.povray.org>
On 9/29/2012 23:13, Warp wrote:
> Why?
Separate compilation combined with actual enforcement of the rules. Sing# is
designed to use the language, in part, to enforce security. You don't get
stack-smash and buffer-overrun viruses because you can't smash the stack or
overrun buffers, as an example.
But C++ can't do this, which is why you wind up with all kinds of smart
pointer types. You can make it work, but you can also get it wrong.
If you take a mutex, and pass it to a subroutine by value, you've just
screwed your lock, because you'll free the lock when you return from the
subroutine, and you'll free the already-disposed lock a second time when you
return from the call that passed it.
> it can just as easily automatically add the destructor call.
It also prevents you from calling the destructor twice.
For example, in one module, you have
void xyz(tracked one, tracked two) {
    destroy one;
In another, separately-compiled module, you have
void pdq() {
    tracked alpha = ...;
    tracked beta = ...;
    xyz(alpha, beta);
    alpha.use();
    beta.use(); // As written, this will crash.
How would you recommend the compiler deal with such a thing, if you don't
have to annotate what's destructed and what isn't?
Singularity does it by making you declare the function like this:
void xyz([claimed] tracked one, tracked two) { destroy one; }
(or some such syntax)
Then, the compiler enforces at compile time that inside the body of xyz, you
destroy item one exactly once, and that you don't destroy item two.
As another example:
void xyz(tracked one, tracked two) { destroy one; }
void abc(tracked three, tracked four) { xyz(three, four); }
void def() {
    tracked five = ...;
    tracked six = ...;
    abc(five, six);
Where does five go out of scope? Where does six go out of scope? Five and
six are still in scope in def, but five is the same as three is the same as
one, which is destroyed in xyz. So after the call to abc, five is no longer
usable. Either that, or you have to say that xyz is incapable of actually
discarding five, which means every tracked value has to be discarded in the
same stack frame where it was created, which seems rather restrictive.
How does C++ do it? You create the file object at one stack frame, and then
you only pass it by reference down thru the stack, right? So the thing
really only gets destructed in the stack frame where you allocated it. Or
you allocate it on the heap and hope that someone eventually cleans it up
again, with smart pointers trying to automate that to some extent?
If "two" in "xyz" is declared as an "out" variable, you have to assign a new
tracked item to it before returning, and the variable can't already have a
value when you invoke xyz. If it's declared an "in out" variable (i.e., a
pass-by-reference), then you can destroy it in the body, but only if you
create a new one and assign it before you return. If it's an "in" variable
and you destroy it, you have to put that in the type signature of the
routine, so the caller knows it's gone.
The general technique is called "typestate", invented in the 80's as a
general method by Robert Strom. :-)
(Sing# does some other cool things like that, too, such as letting you take
pointers to the insides of structures on the stack, but tracking where you
assign such pointers so they never outlast the stack frame they're pointing
to. This lets you do things like handle network packet parsing with zero
copying, while avoiding the possibility of leaking pointers or smashing the
stack. It also tracks the state your communication channel state machine is
in, making sure you don't try to send a message other than the one you
declared you'd send at any given time, which eliminates a whole host of bugs
you have to kludge around in languages like Hermes and Erlang where an
unexpected packet type either gets ignored and accumulates forever in the
buffer or causes the code to do something otherwise unexpected.)
Now, granted, in Singularity, the OS is garbage-collected also, so there are
like 3 types that you actually have to destroy (shared buffers, pointers to
shared buffers, and communication channels to pass those shared buffers
over), so there's generally very little occasion to need to destroy
something. You don't destroy threads, or locks, or memory allocations, or
stuff like that. Just connections to other programs.
Date: 1 Oct 2012 09:29:38
Message: <50699ac2@news.povray.org>
Of course it can. That's the very essence of RAII.
You are confusing tracking the scope of an object with tracking references
that point to a dynamically allocated object. Those are completely different
things.
> screwed your lock
Which is why mutex objects cannot be passed by value (ie. they have their
copy constructors and copy assignment operators disabled).
(If you really need to pass such an object as a function parameter, then
you can do it by using *move* semantics rather than *copy* semantics.)
std::unique_ptr does not reference-count, it contains nothing more than
the pointer to the object (which itself doesn't need to contain anything
at all related to memory management), and you can give std::unique_ptrs
as function parameters (and use them eg. in data containers). You can also
eg. return one as the return value of a function. It it does not delete the
object twice.
(The reason is that it uses move semantics rather than copy semantics.)
What exactly stops the compiler from generating the destructor call
automatically? Why exactly do you have to write it explicitly?
Date: 2 Oct 2012 01:16:14
Message: <506a789e@news.povray.org>
Only for stuff I allocate on the stack and which I don't pass by value.
> things.
I'm not confusing them at all. I'm simply pointing out that scope-tracking
doesn't work for heap-allocated objects.
>> screwed your lock
And you deal with mutex objects in the heap how?
And when you move it back...?
But nothing enforces that.
Because you might want to destruct something somewhere other than when
returning from a block, I suppose. You don't want to destruct some object
like that when you dispose the penultimate reference, but you do want to
destruct it when you dispose the ultimate reference. You need some way of
storing it in the heap, as well as the ability to reliably pass references
to stack objects downward in the call tree but not return them upwards.
Remember that singularity supports multiple languages, too.
Date: 2 Oct 2012 07:32:17
Message: <506ad0c1@news.povray.org>
"Scope" is defined by the stack. An object created inside a scope goes out
of scope when that scope ends, of course. If you create an object
dynamically, it can outlive the scope where it was created.
If you pass the object by value, you are creating a *new* object (with its
own scope). It's not the same object. That's what "copying" means.
That's rather obvious, given that heap-allocated objects are not
scope-based.
You don't "move it back". If you move a resource you relinquish it to
whatever you are moving it to.
The class itself can enforce it.
And have the possibility of dereferencing a destroyed object?
Date: 2 Oct 2012 11:24:04
Message: <506b0714$1@news.povray.org>
Only for auto variables, yes.
Objects (i.e., values) don't have scopes. Variables have scopes. A scope is
the portion of the program code over which the name of a variable is valid.
An object doesn't go out of scope when the scope ends. The variable
referencing the object goes out of scope when the scope ends.
And that's the problem.
And that too is the problem.
> scope-based.
Well, you asked me why the compiler couldn't just add the destructor for
you. This is your answer: it's rather obvious.
So if I want to pass an object into a function as an argument, and then
still use it when that function returns, I can't?
Also, how does the compiler know you've moved it, so you *don't* reference
it upon return?
"Can enforce" is not the same as "enforce".  it's not part of the semantics
of the language.
No. That's exactly the point of the declarations like [claim] that I showed
you. You can't dereference it after it's destroyed because the declarations
prevent you from dereferencing it after someone else has claimed it, and
destroying it claims it.
