POV-Ray : Newsgroups : povray.off-topic : Haskell vs Java: Building a ray tracer Server Time
16 Jun 2026 08:25:01 EDT (-0400)
  Haskell vs Java: Building a ray tracer (Message 11 to 18 of 18)
Subject: Re: Haskell vs Java: Building a ray tracer
Date: 29 Jun 2012 02:25:15
Message: <4fed4a4b$1@news.povray.org>
>> Heh. So standard Haskell obviously sucks as much as Java without generics.
> Why exactly would you need generics in order to make a list of different
> shapes? (Being able to do such a thing is kind of the very definition of
> object-oriented programming.)
No, I think he means that I said Java sucks because of X, so he's saying
Haskell sucks because of Y. There isn't any particular relationship
between these things...
[At least, I /think/ that's what he meant...]
Date: 29 Jun 2012 03:53:22
Message: <4fed5ef2$1@news.povray.org>
On 28/06/2012 11:28 PM, nemesis wrote:
> [tldr]
That's the story of my life.
>> Notice, however, that it is impossible to write an
>> "unwrap" function. Because once you "wrap" something, its original type
>> information is lost forever, so there's no way in hell to know what type
>> to cast it back to.
> what about in heaven?  In Lisp there's no such hellish troubles. :)
No. In Lisp, there are no types at all. :-P
> So your solution to get away from the complaints of the compiler is to have all
> types be the same single type?  Yes, sounds like the Lisp solution too. ;)
Not all types, just all /shape/ types. There's the difference. In Lisp,
you can put any value anywhere. Haskell (and Java) allow you to require
that all the elements of the list have specific properties.
>> Not exactly a revelation, is it? I think
>> I'm going to go outside for a while...
> you do good. :)
Hmm.
Date: 29 Jun 2012 17:41:36
Message: <4fee2110$1@news.povray.org>
>>>> You already do it for AllIsect(). There's no additional work necessary.
>>> In Java, calling AllIsect() causes all intersections to be computed. In
>>> Haskell, calling the isect function does /not/ necessarily cause all
>>> intersections to be computed. Only the ones you actually "look at".
>>> That's the point I'm making.
>> As Clipka pointed out, you need to calculate all intersections anyway to
>> find the nearest one.
> And as I pointed out, this is not the case for many objects. E.g., a
> sphere has two points of intersection. These are the solutions to a
> quadratic equation. And we all know that the way to solve that is
> x = -b +/- Sqrt(b^2 - 4ac) / 2a
> To find the "nearest" intersection, you merely pick the "-" rather than
> the "+". Done.
Assuming your sphere is to the "right" of your ray starting point.
>> I was just pulling your leg. You can call your variables Fred, Pebbles
>> and Bambam if you want to. Just don't go about making readability
>> claims, if you do, though. :)
> Is it wrong that I actually know who those people are? o_O
No.  It's not like the Flintstones is an obscure reference.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 29 Jun 2012 17:58:54
Message: <4fee251e$1@news.povray.org>
>> the "+". Done.
No assumption.
The result of this equation is the distance along the ray that you need
to travel to get to the intersection. Therefore, the lowest solution is
guaranteed to be the one you want. (Unless the camera is /inside/ the
sphere, which won't work for several other reasons besides this one.)
Date: 3 Jul 2012 09:35:03
Message: <4ff2f507@news.povray.org>
> No assumption.
No assumption, except for this one, that one, and these other ones, too...
:P
Date: 3 Jul 2012 10:29:38
Message: <4ff301d2$1@news.povray.org>
>> No assumption.
> :P
No assumption, assuming the camera isn't inside a solid object.
If the camera /is/ inside a solid object, you need to adjust several
things beyond just the ray intersection tests.
Date: 3 Jul 2012 14:24:03
Message: <4ff338c3$1@news.povray.org>
>>> No assumption.
>> too...
>> :P
Huh...
Ok, and even though you're building this just for your own amusement, is
this limitation of the software fully documented?  Will you remember it
when you get to version 13 and you decide to add CSG support or POV SDL
parsing?  What if you mess up a rotation or translation and your camera
inadvertantly ends up inside an object?
Call me paranoid, but I'd prefer to expect the unexpected and program
for it right away, instead of simply assuming it won't ever happen.  At
the very least, you should test for it and bail out gracefully rather
than invoke undefined behaviour.
Agreed.  But that does not negate our original point that in order to
find the nearest intersection, you need to find them all.
Date: 3 Jul 2012 15:53:53
Message: <4ff34dd1$1@news.povray.org>
Sure. Who says I didn't write a test for that?
No, you just need to detect when the camera is inside a solid object and
emit an error message rather than rendering the scene.
(If you /want/ the camera there, you sound turn the object in question
inside-out, which takes care of /all/ of the necessary adjustments so
the scene will render correctly. In that case, no error message.)
