POV-Ray : Newsgroups : povray.off-topic : Logic programming Server Time
16 Jun 2026 11:46:30 EDT (-0400)
  Logic programming (Message 9 to 18 of 28)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Logic Box v2 release #1
Date: 31 May 2012 09:25:10
Message: <4fc77136@news.povray.org>
On 31/05/2012 02:20 PM, Francois Labreque wrote:
> Yeah, I know. Cool story bro.
The way I heard it, Prolog caused quite a stir when people first saw it
back in the 1970s. A few simple lines of Prolog gives you a system with
approximately the apparent logical deductive skills of a 2 year old
child. And it's really quite a simple piece of programming. The computer
scientists of the day must surely have thought that in just a few years'
time, they would have human or super-human intelligence at their
fingertips...
...and then it didn't actually happen like that, and the "AI winter"
came along. The scientists promised everybody the Earth, and then
couldn't deliver, so their funding was slashed.
Date: 31 May 2012 09:26:25
Message: <4fc77181$1@news.povray.org>
On 31/05/2012 02:22 PM, Stephen wrote:
> Your talents are wasted in your job.
What? SERIOUSLY??? :-O
>>> Having written something like this is also very good for CVs and job
>>> interviews :-)
>> ....and you think I'm doing this because...? ;-)
> You have too much time on your hands and the job that you get paid for
> does not stretch you.
Well, right now - oh, wait, legally I can't tell you about that. Maybe
in a few weeks' time...
Date: 31 May 2012 09:32:21
Message: <4fc772e5$1@news.povray.org>
On 31/05/2012 01:27 PM, scott wrote:
>>> Runs fine here, opened it up and was thinking what it could be useful
>>> for ... could it be used to solve Sudoku puzzles?
>> It... could. Perhaps. With some serious modifications.
> You would need a permutation predicate, eg LPerm. It would be solved
> when the first list is a permutation of the second list.
Challenge accepted. ;-)
Actually, there is /already/ an SEqual{} predicate, which is solved if
two lists are "set-equal". That is, X is a subset of Y and Y is a subset
of X. More simply, every element of X is also an element of Y and vice
versa.
Notice that this does not imply that X is a /permutation/ of Y, since
elements can appear more than once. (Remember, sets do not have
multiplicity.) If I could fix that, it might work.
> LPerm{ List[1,2,3] , List[3,1,x] }
> Would tell you that x := 2
That doesn't quite work for SEqual{}, because every set can be
represented by infinity distinct lists. But it ought to be fixable.
> I'm guessing that it wouldn't be simple to implement...
I'm guessing that it would. ;-)
The trick appears to be either to get the loop to terminate reliably, or
else to somehow add a constraint that both lists are the same size.
> If you had that, then you could expand it easily to a sudoku grid. You'd
> need an LPerm for each row, each column and each 3x3 box all ANDed
> together.
> Now that would be a very cool solution, as in you wouldn't need to tell
> the computer *how* to solve it (as you have to when writing a
> "traditional" sudoku solver), just what the rules are.
I'll see what I can come up with...
Date: 31 May 2012 09:57:01
Message: <4fc778ad@news.povray.org>
> versa.
Ha! Yes, SEqual{} is already defined. It also doesn't /work/. o_O
The mistake is simple. SEqual{} calls SSubset{}, and SSubset{} has a
bug. Its definition is
SSubset{sub, super}:
   (sub = End[]) | (~item ((SMember{item, sub}) & (SMember{item, super})))
In other words,
   "S is a subset of T if S is the empty set OR _there exists_ an X
which is a member of S and a member of T."
What it /should/ of course say is
   "S is a subset of T if S is the empty set OR _for all_ X which is a
member of S, X is a member of T."
In short, I've mixed up "exists" and "for all". Kind of an important
distinction, that one.
Logic Box of course doesn't /have/ an explicit for-all construct. At
this point I am uncertain whether I can work around that...
Date: 31 May 2012 10:12:18
Message: <4fc77c42$1@news.povray.org>
> bug.
A /correct/ definition for SSubset{} is
SSubset{subset, superset}:
   (subset = End[]) |
   (~head ~tail
     subset = Node[head, tail] &
     SMember{head, superset} &
     SSubset{tail, superset}
Before SSubset{} would accept any pair of sets where just one element is
common to both sets. Now it only works if /all/ of the elements of the
subset are elements of the superset. (I.e., it works correctly now.)
This in turn causes SEqual{} to function correctly.
It's quite slow, but
   SEqual{List[1, 2, 3], List[3, 1, x]}
does eventually yield x := 2.
QED.
Date: 31 May 2012 10:17:58
Message: <4fc77d96$1@news.povray.org>
I am all agog.
Regards
Date: 31 May 2012 10:56:51
Message: <4fc786b3$1@news.povray.org>
So for the first row in a sudoku I'd expect something like this:
SEqual{List[1..9], List[3,a,b,c,1,d,e,f,8]}
That should work, as both lists are the same length (so the 2nd list
must contain the each of the elements 1-9 once).
But I'm guessing it's going to be very slow, especially when you add in
the other 26 SEqual statements all ANDed together...
Shame, as I think it's a really neat way to write a solver.
Date: 31 May 2012 11:31:41
Message: <4fc78edd$1@news.povray.org>
When I removed the run time constraint, it took Logic Box about 22
seconds and 90 MB of RAM to come up with the first 10 solutions to the
predicate above. Of course, it's going to sit there and search for all
6! permutations of 6 items.
Think about what's happening under the covers: Logic Box is merely
searching through all possible combinations, trying to find one for
which all the constraints apply. I should imagine that for Sudoku, the
search space is /astronomical/, so it's likely to take a while. If it
takes 22 seconds to partially process one row, then processing 9 rows, 9
columns and 9 squares searching for a simultaneous solution to all of
them is going to take... a while.
I agree, however, that it would be very cool if this actually worked. :-D
Date: 31 May 2012 16:05:01
Message: <web.4fc7cdf1865a668e773c9a3e0@news.povray.org>
scott <sco### [at] scottcom> wrote:
> Also how hard would it be to add support for arithmetic operators?
yes, first thing I tried was changing x=y to x=2*y
hmm, didn't actually tried x=2y...
> interviews :-)
yes, at least if he's willing to change "written by Orphi the AweKid"... :p
On AI, perhaps we don't have bad and mean counscious AI, but OTOH, we have far
more believable game characters than we've ever dreamed for back then... IBM
also got Watson... a few more years and we may get Sherlock level... :)
Subject: Logic Box v2 release #2
Date: 1 Jun 2012 04:02:47
Message: <4fc87727@news.povray.org>
Attached is release #2.
Only a few things have changed. The laughable bug in SSubset{} is gone,
and the file requester doesn't keep resetting itself to your home folder
every single time you open it. I've also adjusted it so that temporary
variables are labelled with their original names as subscripts, which
makes things slightly easier to follow. (But only slightly.)
There's a couple of other ideas I have for what could be done with this
program. (E.g., improving the output, refactoring the code, adding new
features.) But honestly, I think I'm bored with it now. I don't suppose
I'll be making any further releases soon. It's time for a different
project...
Download 'logicbox-02 release2.jar.zip' (197 KB)
