POV-Ray : Newsgroups : povray.off-topic : I'm in the mood for monads Server Time
22 Jun 2026 13:12:48 EDT (-0400)
  I'm in the mood for monads (Message 11 to 20 of 93)
Subject: Re: Living in a box
Date: 21 Apr 2012 17:53:13
Message: <4f932c49$1@news.povray.org>
Le 21/04/2012 23:37, Orchid Win7 v1 nous fit lire :
> "override operator;".
are you sure you do not want "operator," instead ?
For once, I'm glad C++ does not allow such!
The overloading (?) of << and >> is already enough trauma when dealing
with streams... or not.
c = ceo << eke ;
d = kaz << ekk ;
one is a shift operation, the other is write in a stream... can you say
which one ? (and either c is an integer or a stream...)
in fact, monade seems to be the << with polymorphic type added.
(for streams, << returns a reference to updated stream (sort of), so
  cout << "hello " << "world" << endl;
is in fact ((cout << "hello") << "world ) << endl;
Now, if << is specified to return not the same reference type as the one
on the left, it can become "interesting".
But of course, then, we need a template to declare the << for the part
on right... or a lot of overloading.
I wonder if there is a deep difference between haskell & forth... or a
bit of lisp. Just that haskell dropped all ()...
Subject: Re: I'm in the mood for monads
Date: 21 Apr 2012 18:14:48
Message: <4f933158@news.povray.org>
On 21/04/2012 10:17 PM, Orchid Win7 v1 wrote:
> On 21/04/2012 09:56 PM, Stephen wrote:
>> On 21/04/2012 9:01 PM, Orchid Win7 v1 wrote:
>>> And that's basically /it/.
>> Well it tells me nothing.
> Heh, man... I thought "it inserts user-defined code between each pair of
> statements" would a pretty simple idea. I guess not... ;-)
I should have said that I am none the wiser. I still do not know what a
monad is.
Regards
Date: 22 Apr 2012 00:33:34
Message: <op.wc5gaxkjmdfjsk@localhost.localdomain>
On Sat, 21 Apr 2012 16:18:46 -0500, Orchid Win7 v1 <voi### [at] devnull> wrote
> 1. You can take a 5-argument function, pass it 2 argument, and get a
> 3-argument function as the result.
> Examples:
> - (+1) takes a number and adds one to it.
> - (5 ==) takes a number and returns True if it's 5.
> - "map" takes a function and a list. "map abs" takes a list of numbers
> and returns a list of positive numbers.
I think I understand monads—I'll likely never try Haskell to fin
d out for
sure.
I'm pretty sure I understand currying—at least as far as it goes
 in Python.
But I don't understand how any of these are taking a 5 argument function
passing it 2 arguments, and getting a 3 argument function as a result.
  -Shay
Date: 22 Apr 2012 06:40:01
Message: <4f93e001@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> > For instance,
> > I still don't understand what currying *really* is about, and every time
> > I try to suggest "is like this?" the answer is "not really".
  But that's the thing: It sounds so trivial as to defy sense. Why give
a particular name to such a trivial thing? It's like calling the act of
taking a 3-dimensional vector and expanding it to a 4-dimensional one
"potatoing", or taking two integers and adding them together "bananaing",
or taking a class and adding another class as its member "orangeing".
Why give an obscure name to such a trivial operation?
  But then when one starts asking questions like "so it's like giving
default values to function parameters?" or "so it's like writing another
function with less parameters that calls the first function by giving it
some default values as the rest of the parameters?", the answer is something
like "not really".
Date: 22 Apr 2012 06:53:56
Message: <4f93e344@news.povray.org>
> c = ceo << eke ;
> d = kaz << ekk ;
> which one ?
  People keep repeating that, and there's never any substance to the claim.
  I have been programming in C++ both as a hobby and professionally for
over 15 years now, and I have yet to encounter a piece of code where it's
confusing which operation is being performed.
  That's an especially dishonest example because it won't actually compile
if c is a stream because streams are not assignable.
Date: 22 Apr 2012 06:59:45
Message: <4f93e4a1@news.povray.org>
> Further, let's pretend that you can create an anonymous function just by
> writing
>    int function(int x) {return 2*x;}
  You can create anonymous functions. The syntax is:
    [](int x) { return 2*x; }
  (Of course that alone won't do anything because you can't call it, as
it has no name. However, you can eg. create a variable that represents
the function, like: "auto func = [](int x) { return 2*x; };". If you need
to eg. return that function from another function, you'll have to use the
std::function wrapper. Likewise if you need to give one as parameter to
a non-templated or anonymous function.)
Date: 22 Apr 2012 07:18:04
Message: <4f93e8ec@news.povray.org>
> Listing #1:
>    Type1 x = foo();
>    Type2 y = bar(x);
>    Type3 z = baz(y);
>    return z;
  Btw, I don't know if this is exactly what you are looking for, but I think
it achieves at least close to what you are attempting:
    auto x = [](int i) { return i*2; };
    auto y = [x](int i) { return x(i*3); };
    auto z = [y](int i) { return y(i*5); };
    std::cout << z(3) << std::endl;
  (Capturing the other functions by value is far easier than taking them
as function parameters because this way you don't have to care about the
type of the anonymous function. Unfortunately lambda functions cannot yet
be templated, which is a bummer.)
  If you wanted to return that 'z' from a function, it's slightly less
intuitive (because function return values cannot be 'auto'). You have
to do it like this:
#include <iostream>
#include <functional>
std::function<int(int)> gimmeTheFunction()
    return z;
int main()
    auto func = gimmeTheFunction();
    std::cout << func(3) << std::endl;
Date: 22 Apr 2012 08:38:32
Message: <4f93fbc8@news.povray.org>
> monad is.
Oh that's easy ... it's just the singular form of gonad ... THUD ...
couldn't resist ;-)
Date: 22 Apr 2012 08:43:07
Message: <4f93fcda@news.povray.org>
  Would this be currying in C++?
    std::function<int(int)> multiplierFunction(int multiplier)
        return [multiplier](int value) { return value * multiplier; };
  The above function returns a function that takes an integral as parameter
and returns it multiplied by the specified multiplier. To better understand
it, it's used eg. like this:
    auto doubler = multiplierFunction(2);
    auto tripler = multiplierFunction(3);
    auto nMultiplier = multiplierFunction(n);
    std::cout << doubler(5); // Will print "10"
    std::cout << tripler(5); // Will print "15"
    std::cout << nMultiplier(5); // Will print the result of 5*n
Date: 22 Apr 2012 09:06:40
Message: <4f940260@news.povray.org>
>> monad is.
> couldn't resist ;-)
That calls for a kick in both monads. :-P
Regards
