On 4/20/2012 1:38, Invisible wrote:
>>> In other words, yet again, "now you know how this works, you don't
>>> need to actually use it".
>> Right. Except in very limited circumstances when you know how deeply
>> you'll recurse, because there's no guarantee it'll work and no way to
>> check.
> ...what?
You have no way of knowing how much stack space you have. Nobody writing
reliable code wants to recurse for each level of a tree without knowing how
deep the tree is.
>>> "Registers are a special area of memory built right into the CPU."
>>> Erm...
>> What's questionable about that? Heck, on the Sigma 9, the registers 0
>> thru 15 were actually addressed as memory locations 0 thru 15, to the
>> point where you could store program code in the registers and branch to it.
> Nobody designs hardware like that any more. Haven't done for decades. :-P
So? They're still special areas of memory built into the CPU. Just because
you can't address them using normal addressing modes any more doesn't mean
they're not memory.
>>> "They take care of internal housekeeping."
>>> ...actually...
>> Program Status Word.
> The /registers/ do not take care of anything. The /processor/ does.
Oh come on. :-) The TLB registers take care of internal housekeeping
certainly. As do watchdog timer counters, interrupt mask levels, etc.
>>> So I'm guessing an architecture exists where the instruction pointer
>>> /isn't/ a single register then? :-P
>> Yep. Anything with memory mapping hardware, segment registers, etc.
> None of which are relevant in the current day and age, unless you're writing
> an OS. Certainly this technicality has no place in an introductory
> programming text.
You asked. The IP address isn't a single register even on a 8086, and that
isn't *that* long ago.
>>> Still, it does answer something I've always wondered about: What *is*
>>> the C calling convention?
>> Undefined, generally speaking. Or rather, implementation-specific. And
>> depends on pragmas, sometimes.
> So you're telling me that the de facto calling convention that all software
> always uses is "undefined"?
Implementation-specific, yes. How could you define it in a standard when
you don't even know what architecture you're compiling for?
"Oh no! We're out of code juice!"
"Don't panic. There's beans and filters
in the cabinet."
On 4/20/2012 0:51, Invisible wrote:
>>>> The integral part of the value is assigned to the int.
>>> So... it always rounds towards zero?
>> As long as they're both positive.
> Does it round towards zero, or towards negative infinity?
I don't remember. I never use it under those circumstances, probably because
it's implementation-defined.
> Oh good. The book /insists/ that left-to-right order is guaranteed.
There are a handful of operators for which that's true. The rest, not so much.
> A better way might be to think of true and false as 1 and 0. (Although of
> course C allows true to be /anything/ that isn't 0, not just 1.)
The real way to think of it is "BZ" and "BNZ" - branch on zero, and branch
on not zero. Of course, if you don't know common modern assembler, that
might not be any easier to remember.
> I'm currently trying to work out how I can compile a program where module 1
> refers to module 2, but module 2 also refers to module 1. As far as I can
> figure out, this is impossible...
Neither can actually refer to the other, so you're good to go there. Just
use the normal header file stuff.
Everything you refer to has to be compiled in the same compilation unit, so
C and C++ really don't have any trouble with circular references. A benefit
I never really realized before.
in the cabinet."
On 4/20/2012 5:18, Warp wrote:
> Darren New<dne### [at] san rr com> wrote:
>> If you could #include<abc.o> you'd get rid of all the silliness of
>> declaring inline functions multiple times, function prototypes, and all that
>> kind of BS.
> So you would be simply changing the dependency to a .h file to dependency
> to a .o file. What would be the relevant difference?
You'd be getting rid of function prototypes, declaring inline functions
multiple times, mismatched declarations between compilation units,
compatible compiler flags between separately-compiled modules, and etc. That
would be the relevant difference.
(Of course, if you *want* to have header files, you can still depend on the
.o file instead of the .h file, and let people write the .c file even though
you can still compile against the .h file.)
> Also, I assume you understand that templated code cannot be precompiled
> into an object file? They need to be recompiled each time they are used...
> which is kind of the whole idea.
Of course. It's basically macro expansion. That's why I didn't say depending
on a .h file would get rid of template functions.
in the cabinet."
On 4/20/2012 0:20, Le_Forgeron wrote:
> Le 20/04/2012 03:56, Darren New a écrit :
>> On 4/19/2012 18:38, Alain wrote:
>>> Le 2012/04/17 09:40, Warp a écrit :
>>>>> is a perfectly valid statement in C++. On the other hand, it also
>>>>> means that
>>>>> while (x[i] = y[i--]) ;
>>>>> is perfectly valid. You sick, sick people.
>>>> I think that's Undefined Behavior because the same variable is being
>>>> modified and referenced more than once in the same expression.
>>> Nothing undefined here.
>> Does it compare x[i] to y[i] or to y[i-1]? Why do you answer that way
> You missed the point: let's name k the initial value of i;
I don't think I missed the point. I just got the possible answers wrong.
The
*point* was that there *were* multiple possible answers. :-)
in the cabinet."
>> Does it compare x[i] to y[i] or to y[i-1]? Why do you answer that way?
> Last time I checked, the /comparison/ operator is ==.
> The = operator performs *assignment*. :-P
Yah yah. Still missing the point. It's still undefined, whether it's an
assignment or a comparison.
in the cabinet."
Subject: Re: Teach yourself C++ in 21 strange malfunctions
Date: 21 Apr 2012 00:02:43
Message: <4f923163$1@news.povray.org>
On 4/20/2012 0:57, Invisible wrote:
>>> When will we see the Haskell# language?
>> I'm pretty sure the whole .NET bit is too OO to make that useful.There's
>> way too much stateful stuff (like I/O) that you'd want to use from .NET
>> to make it reasonable to have a purely function .net language.
> Haskell already supports a wide range of I/O operations. That's pretty
> stateful, and it's not a problem.
> Yeah, if you wanted to talk to the .NET libraries, it would all end up being
> monadic. (Even the .NET stuff that's actually pure - since it isn't /marked/
> as pure.) But it would still work fine.
> I think it's probably vacuous to try to estimate how "useful" it would be
> without actually trying it...
Well, they tried making STM work on .NET and gave up because of all the
state, if you remember.
in the cabinet."
Date: 21 Apr 2012 00:04:47
Message: <4f9231df$1@news.povray.org>
On 4/20/2012 10:02, Orchid Win7 v1 wrote:
> On 20/04/2012 02:41 AM, Darren New wrote:
>> Plus, the IDE for Smalltalk doesn't really deal too much with the fact
>> that it's OO. It didn't do any of the sorts of completion you're talking
>> about.
> Well, to be fair, since Smalltalk isn't statically typed, you'd be
> hard-pressed to figure out what messages are applicable to a given variable.
You'd be surprised. People write code that looks at javascript, for example,
and comes up with something like 70% of the variables being statically typed
in ways that it's even easy to tell. Even when you *could* figure it out,
indeed even when the variable had a value already, you didn't get the sorts
of completion you're talking about.
in the cabinet."
Date: 21 Apr 2012 00:05:47
Message: <4f92321b@news.povray.org>
On 4/20/2012 1:07, Invisible wrote:
>>> (And besides, any kind of detection of this cannot be 100% accurate,
>>> as the problem "will this line of code ever be reached?" is unsolvable
>>> in the general case.)
>> But detecting type errors isn't 100% accurate either.
>> int x = 1 ? 5 : "hello";
>> That's not legal, but it's not a type violation either.
> The general problem of determining whether every possible code path is
> well-typed is undecidable. Type systems insert artificial restrictions to
> /make/ the problem decidable. Hence, there are expressions and statements
> which are well-typed, but do not type-check.
Which is the point I'm making. We put up with saying "that'll never be the
wrong type, but it's still illegal", so the argument that "whether this code
is reachable is unsolvable, so we shouldn't even try" is equally bogus.)
in the cabinet."
> because it's implementation-defined.
No wonder so many programs don't compile if you (say) change from a
32-bit OS to a 64-bit OS...
Sure, that's obviously how it's implemented (and why it works that way).
Still doesn't help me remember which is which. ;-)
Date: 21 Apr 2012 14:18:50
Message: <4f92fa0a$1@news.povray.org>
And I'm agreeing. ;-) [Although I'm not sure I got the technical terms
right...]
> the wrong type, but it's still illegal", so the argument that "whether
> this code is reachable is unsolvable, so we shouldn't even try" is
> equally bogus.)
Well, to be fair, the code you worked is well-typed, but /very stupid/.
The fact that it gets rejected is no big deal, really.
(OTOH, all the advocates of dynamically-typed languages seem to think
that this is /the primary reason/ that statically-typed languages suck -
because you /can't/ just do whatever the hell you want, no matter how
incoherent.)
> how deep the tree is.
Nobody writes recursive code? IN WHICH UNIVERSE??
I'm also loving the way you say "you don't know how big the stack is",
and immediately follow that with "you should check how deep the tree
is". But if you don't know how big the stack is, you STILL don't know if
you can do it. :-P
Besides, it's not like there's an /alternative/ to recursion.
> because you can't address them using normal addressing modes any more
> doesn't mean they're not memory.
Well, to be /technical/ about it, the entire concept of "memory" is a
fiction. It would be more accurate to say that there is a large topology
of transistors connected together - but that's not a very useful way to
think about it.
>> software
Amazing. So the one calling convention that every piece of software
supports isn't actually defined at all. That's impressive, right there.
> At least on machines designed to be programmed in assembler, one can
> generally put a useful and informative comment on pretty much every line.
I haven't yet seen an assembler where you /can't/ stick comments
anywhere you want to. That /still/ doesn't mean I want the comments to
out-number the actual code.
>> You'd expect part of the language's basic syntax to be, you know...
>> part of
>> the language's basic syntax. But it isn't. It's just a regular operator,
>> which means you can use it in places where you shouldn't be putting
>> random
>> commas, and that makes it do strange stuff. (And, being C, this isn't
>> checked in any way.)
> Why would you put randomg *anything* in? This isn't a sonnet. It's
> computer code. Why would you put random commas in any more than you put
> random quote marks in?
Ever heard of something called a "mistake"? Perhaps you don't make
those, but I do sometimes. And it's worrying to know that if I do, the
compiler isn't going to say "oh, you made a mistake", it's just going to
generate code that does something bizarre.
> Plus, "void" is a relatively recent development.
This is The Real WTF.
> I haven't yet seen an assembler where you /can't/ stick comments anywhere
> you want to. That /still/ doesn't mean I want the comments to out-number the
> actual code.
I said "useful."
> Ever heard of something called a "mistake"? Perhaps you don't make those,
> but I do sometimes. And it's worrying to know that if I do, the compiler
> isn't going to say "oh, you made a mistake", it's just going to generate
Sure. And if you randomly change * to / and + to -, you'll get similar
errors. In practice, it's not a mistake people make.
in the cabinet."
I have written very very little recursive code in my entire career. Of that,
90% of my recursive code is of the form
Try to X, 10 times.
if X failed,
Try to X one fewer times
Yes, my current project has a tree structure that's at most 3 levels deep,
and parsing that into flat structures is recursive, once. Before that, it
was iterative over a queue. (Actually, it might still be, I don't remember.)
> I'm also loving the way you say "you don't know how big the stack is", and
> immediately follow that with "you should check how deep the tree is". But if
> you don't know how big the stack is, you STILL don't know if you can do it. :-P
Well, I know the stack is deep enough to hold 3 levels of tree. The point is
you can't take an *arbitrary* tree and parse it recursively.
Of course there is. I'm pretty sure every recursive algorithm can be made
explicitly iterative. The advantage of doing so is that you can handle
failures of running out of resources, before you ask.
> fiction. It would be more accurate to say that there is a large topology of
> transistors connected together - but that's not a very useful way to think
> about it.
But in some cases, those transistors are wired together in a way that
retains state arbitrarily long, which we call memory. ;-)
>>> software
> Amazing. So the one calling convention that every piece of software supports
Which calling convention do you think every piece of software supports? It's
defined by the implementation. Have you tried invoking Java code from C?
Have you tried invoking C# code from C++? Have you invoked C++ objects from
Haskell?
http://www.scribd.com/doc/20689745/Calling-Conventions
Not sure if you're trying to be sarcastic, incredulous, or simply ignorant here.
in the cabinet."
Date: 23 Apr 2012 03:58:16
Message: <4f950b98@news.povray.org>
They gave up because they tried to make all the existing state mutation
stuff still work in the presence of transactions, which is /obviously/
impossible.
If you're in the middle of writing an expression, and the phone rings or
something, and then you got back and hit "compile", it says "hey dude,
this * operator only has one argument. Shouldn't there be two?"
But, apparently, if you're half way through writing a function call and
the same thing happens, the compiler doesn't say anything, because comma
is just a valid operator that you can put anywhere you want...
Damn... I'm trying to think of something you can code without actually
using recursion. Hmm. Well, I guess there must be /something/...
> made explicitly iterative. The advantage of doing so is that you can
> handle failures of running out of resources, before you ask.
So if you want to count how many nodes there are in a binary tree, how
do you do that non-recursively?
>> supports
> ignorant here.
If a programming language supports calling /any/ foreign language, that
language will always be C. It will know about standard C types, it will
usually know about C structs, and it will let you call arbitrary C
functions.
And yet, the way that you call a C function is, apparently, undefined.
That's pretty bizarre.
It also makes me wonder how the heck it's possible to take object code
from multiple C compilers and link it all together, if each of them is
potentially using a completely different calling convention. It sounds
like it shouldn't work.
Date: 23 Apr 2012 08:28:14
Message: <4f954ade$1@news.povray.org>
Le 2012-04-20 10:47, Invisible a écrit :
>> Not to mention a lot cheaper than a dozen
>> occupational therapy sessions due to tendinitis or carpal tunnel
>> syndrome.
> Nobody gets tendinitis just from using a mouse.
I have two weeks off work, 10 physiotherapy sessions and a visit from an
occupational therapist at home to redesign my work space that disagree
with you.
When you need to use the mouse with your right hand, you need to lift
your arm over the numeric keypad and off to the side to grab the mouse,
then move the arm back to the keyboard so that your can continue typing.
In most cases, this means lifting your entire arm from the shoulder on
down, whereas if you were using your mouse left-handed, you'd only need
to move your wrist, with your elbow still resting on the chair's arm rest.
Repeated sporadic use of the mouse over the course of two long mights
and days of work did cause me to have tendinitis bad enough that I had
to be driven to the hospital since I could no longer lift my right arm
at the shoulder, and it would have been too dangerous to try to drive in
those conditions.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
> with you.
OK. So maybe you had the desk at the wrong height or something? IDK.
I've been using a mouse since I was 12, sometimes staying up to program
until 2 in the morning, and it hasn't caused my any trouble.
FWIW, I also play keyboard, where you have to constantly support the
entire weight of your arm all the time. And I played violin for years...
I usually have an arm rest set up so I only have to lift my forearm, not
my entire arm, but hey.
> those conditions.
Damn. And to think that I have to lift 14 stone of my dance partner...
That said, my shoulder *does* hurt now! >_<
Date: 23 Apr 2012 19:47:47
Message: <4f95ea23$1@news.povray.org>
>> with you.
It wasn't a problem for me either until I had to do it 40 hours straight...
That's probably it, your shoulder muscles are trained.
>> rest.
>> those conditions.
Not for 40 hrs straight...;)
Le 21/04/2012 05:43, Darren New a écrit :
> I don't think mis-matched declarations were ever something that C
> worried about. Does C++ actually check that sort of thing now?
The mangling pattern/scheme of C++ for function's name uses a lot of the
signature: the namespace, the name itself and the description of the
arguments' types. A bit more than C with its double underscores.
As we are talking of template, I would think the code would be
duplicated anyway in the many files: templates are most probably inline
(if you use 1 of 13 templates, your code only get the one you used).
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Christ, 40 *seconds* straight is enough to wipe me out. o_O
I'm such a weed...
On 20/04/2012 02:03 PM, Invisible wrote:
> On 20/04/2012 01:36 PM, Warp wrote:
>> Orchid Win7 v1<voi### [at] dev null> wrote:
>>> On the other hand, it appears to be aimed at people who already know the
>>> C++ language. That isn't really me, yet. I know some of the syntax, but
>>> certainly not all of it, or what all of it actually does.
>> I think you'll learn on the fly (at least if you have the right
>> attitude).
> Given that I already some some clue about C++, that might actually work...
You know what? I'm just going to /buy/ the book. In the unlikely event
that it actually helps me to get a better job, it will have easily paid
for itself multiple times over.
It has to be between two other arguments, and you can't write a naked comma
operator in the middle of a function's arguments, because commas separate
function arguments. So you'd still get a compiler error.
in the cabinet."
Ah yes. I had forgotten about that.
in the cabinet."
On 4/23/2012 1:31, Invisible wrote:
> Damn... I'm trying to think of something you can code without actually using
Almost all business logic. I don't remember seeing any recursion in any
operating system kernels I've read. I can't think of any recursive SQL code
I've written at all.
> So if you want to count how many nodes there are in a binary tree, how do
You use a queue. Each node you visit, you tack on to the end of the queue to
be counted, and you go until the queue is empty.
Alternately, manually maintain the stack. Which is not "recursion" in the C
sense, because you can actually tell without just blasting memory in unknown
ways when you run out of room for the stack.
> usually know about C structs, and it will let you call arbitrary C functions.
OK. Yes, as long as you link to the proper C calling convention.
It's implementation-defined. You have to read the compiler manual (or source
code) to know what the sequence is. And different functions in the same code
can have different calling conventions.
Unless you have a CPU that actually enforces calling conventions.
> It also makes me wonder how the heck it's possible to take object code from
> potentially using a completely different calling convention. It sounds like
> it shouldn't work.
And indeed it doesn't. Try compiling one library with gcc and another with
visual C and see if they link cleanly. Take a library off the mac and link
it to a Windows-compiled main().
For that matter, try compiling one program for x86 and the other for x64.
in the cabinet."
Date: 25 Apr 2012 01:23:47
Message: <4f978a63$1@news.povray.org>
> impossible.
That's my point. How useful would it be if you couldn't actually use any of
the other .NET libraries, including even I/O, reflection, etc.?
in the cabinet."
>> impossible.
> of the other .NET libraries, including even I/O, reflection, etc.?
You do all of that stuff from /outside/ your transactions, that's all.
Remember, transactions are only for thread communication. You start a
transaction, fetch the next work item from the shared work queue, and
the transaction. Then you process the work item, calling whatever
libraries you need. Simples.
I suppose I should consider myself lucky that I'm never going to be
writing anything like that.
Really? That's surprising. No recursive sorting algorithms for balancing
the B*-trees that the directory nodes use, or for sorting the ready
thread list by priority?
> I can't think of any recursive SQL code I've written at all.
SQL is a rather special-purpose language. I'm not sure it even
/supports/ recursion...
> queue to be counted, and you go until the queue is empty.
In other words, you manually implement the stack.
Tell me, in what way does this prevent you running out of stack?
> source code) to know what the sequence is. And different functions in
> the same code can have different calling conventions.
So... how is it ever possible to statically link software?
>> It sounds like it shouldn't work.
> with visual C and see if they link cleanly.
It's news to me that this /doesn't/ work.
I mean, if every compiler uses its own random calling convention, then
how /the hell/ is it possible to write some C, link it against GMP,
wxWidgets and the OS header files, and get a usable binary? You know,
given that you have no idea which compiler these libraries are compiled
with...
> Take a library off the mac and link it to a Windows-compiled main().
Yeah, well, one is going to be an ELF object, and the other will be a PE
module. You won't even be able to find a linker program that understands
both file formats. :-P That has nothing to do with whether the machine
code within those files would work if you linked it together.
There's absolutely no reason to expect binaries for different
architectures to work together.
I would, however, expect that on any given architecture, the C calling
convention is always the same.
I'd recommend getting both of them. (Of course you could buy the
"Effective C++" first, and if you like it, buy "More Effective C++"
later.)
Why not? Didn't you rewrite the code to compile your danse tournament
rankings? I know you only did it for yourself, but that was business
logic, even if you weren't using WebSphere, J2EE, Weblogic or some big
platform like that.
You have to take extra steps to make sure it works. For example, back
in the days of Windows 3.1, you had to use the Pascal calling convention
for your functions in order to make sure that they could interact with
other modules. (Maybe it's still that way, I haven't touched a C
program in 15 years.)
> later.)
I think I can actually buy the pair for a lower price... (Amazon likes
to do that.)
Gotta love how Amazon screwed me over, and I was all pissed about it,
and now here I am giving them my money again.
> rankings?
I did not "rewrite" anything. I merely wrote a program that downloads
some web pages and attempts to extract the raw data from them. And that
is all.
(The organiser's website is obnoxiously difficult to navigate.
Fortunately I was able to reverse-engineer how the URLs are generated...)
> platform like that.
OK.
Really?
> For example, back in
> other modules. (Maybe it's still that way, I haven't touched a C program
> in 15 years.)
So what you're saying is "the C calling convention is undefined, but the
OS calling convention is not"?
> Really?
Yes. For example: Miocrsoft dictating that all Windows applications and
DLLs must use the Pascal calling convention.
(I know DLLs are not statically linked... but you get my drift. If you
want to use library XYZ, you need to use the same calling convention as
library X uses.
>> in 15 years.)
No. I'm saying - as Darren pointed out - that the C calling convention
is not undefined, but implementation-defined. There's a difference.
Division by zero = undefined.
Number of bits in an integer = implementation-defined.
On 4/25/2012 1:22, Invisible wrote:
> Really? That's surprising. No recursive sorting algorithms for balancing the
> B*-trees that the directory nodes use, or for sorting the ready thread list
> by priority?
If you can limit the recursion a priori, then sure. If you know you'll only
have at most 4 levels of tree, or only 128 entries in the list to sort, or
something like that, recursion is fine. I wouldn't write production code to
manipulate an arbitrary data structure with actual machine-stack-based
recursion in C.
> SQL is a rather special-purpose language. I'm not sure it even /supports/
> recursion...
That's kind of my point.
Yes.
It doesn't. It just keeps you from running out of stack without knowing it.
If your language runtime already supplies that service (e.g., C# throwing an
exception when it runs out of stack or something) then recursive algorithms
are fine.
You appear to be having a hard time distinguishing "it's
implemention-defined and not specified in the standard' from "we don't know
what it is, ever."
It doesn't.
> then how
> /the hell/ is it possible to write some C, link it against GMP, wxWidgets
> and the OS header files, and get a usable binary? You know, given that you
> have no idea which compiler these libraries are compiled with...
Because sometimes the OS defines the calling convention to be used.
In spite of the page I pointed you to showing all the different calling
conventions used by the x86 line, right?
in the cabinet."
Date: 25 Apr 2012 23:36:36
Message: <4f98c2c4$1@news.povray.org>
Except that .NET is about components, so that doesn't work out too well.
And if you're talking about putting Haskell on .NET, then your entire
program becomes one "transaction". (Note we've moved to talking about STM
from talking about Haskell, which was not my intention. It was an analogy.)
> transaction, fetch the next work item from the shared work queue, and the
> transaction. Then you process the work item, calling whatever libraries you
> need. Simples.
And if the work item is in a class written that does I/O to obtain it, or to
log a message, or etc etc etc?
in the cabinet."
How so?
> STM from talking about Haskell, which was not my intention. It was an
> analogy.)
OK. And I was just saying that Haskell /already/ lets you use libraries
written in C, which aren't functional at all. I don't see why using the
.NET libraries would be any harder. [Assuming you solve the problem of
how to make your program run on the CLR in the first place, obviously.]
>> libraries you need.
> or to log a message, or etc etc etc?
I am really bad at typing, aren't I? :-S
What I /meant/ to write was that you start a transaction, fetch the next
work item, and then end the transaction. Once the transaction is over,
you can do as much I/O as you like.
The problem (I assume) that you're talking about is that all the
existing .NET stuff is structured under the assumption that you can do
I/O whenever you feel like it. I can see a few ways to approach that.
(Perhaps the simplest possibility being "only Haskell is allows to use
STM". :-P )
> recursion in C.
Very usually the recursion depth of a typical recursive algorithm is
O(log n). This means that the computer wouldn't be able to hold as much
data as to make you run out of stack space when running the recursive
algorithm on it. (For example, if the recursion depth is 50, that means
that there's about 10^15 elements of data. Even if each element took just
one single byte, that would be like 1024 terabytes of RAM.)
> algorithm on it.
Assuming that you're not writing a library that might invoke you 40 levels down.
That said, I've found I rarely need it, and that the undefined behavior
isn't worth the risks. YMMV. If you can handle the program crashing when you
give it too much data in a way that generates bogus results, then sure, feel
free. :-) (I'm not being sarcastic - there are lots of programs like that.)
in the cabinet."
Date: 27 Apr 2012 20:40:58
Message: <4f9b3c9a@news.povray.org>
And can the C call back into the Haskell? And if so, are all the Haskell
invariants and such maintained? And can you do that without telling the
caller whether they're calling C or compiled Haskell?
> work item, and then end the transaction. Once the transaction is over, you
Right. But if "fetch the transaction" means "obtain it from the server over
there using TCP/IP", then you're kind of screwed, aren't you?
Heck, even a regular expression match isn't functional in .NET.
> The problem (I assume) that you're talking about is that all the existing
> .NET stuff is structured under the assumption that you can do I/O whenever
> you feel like it. I can see a few ways to approach that. (Perhaps the
> simplest possibility being "only Haskell is allows to use STM". :-P )
And that's the kind of incompatibility I'm saying makes .NET much less useful.
in the cabinet."
It's not usual to need it, but sometimes it can be quite useful.
Almost anything involving things like permutations and combinations
are significantly easier to express recursively than iteratively.
> free. :-)
As I said, if the recursion depth is O(log n), then you *can't* give it
so much data as for the stack space to run out. It's physically impossible.
If your recursion level is O(n), then it sounds a lot like an iterative
algorithm that has been expressed recursively for no good reason. (Of
course exceptions probably exist, but are rare.)
Date: 28 Apr 2012 05:56:16
Message: <4f9bbec0$1@news.povray.org>
Yes. I demonstrated using the C sort() function to sort Haskell data,
remember?
> And if so, are all the Haskell invariants and such maintained?
You have to tell the compiler whether or not you consider the C function
to be "pure" or not. Obviously, you can lie. Don't do that.
Does sort() know what it's calling?
> over there using TCP/IP", then you're kind of screwed, aren't you?
Yeah. STM only works for stuff local to one machine.
Or rather, the implementations I've seen only work local to one machine.
It's quite plausible you could extend it so that the transactional data
you're mutating might be remote - but them it would be the STM engine
sending network traffic, not you.
Probably. In fact, I doubt much of the .NET libraries are. So you would
probably end up using existing Haskell libraries for anything except
actual I/O - the thing that .NET is good at.
>> whenever
> useful.
Certainly it makes it less useful, yes. Whether it makes it "not worth
it at all" is more open to debate.
Fair enough. That said, you can usually tell by looking at the input
structure how deeply you'll likely need to recurse for something like that.
>> free. :-)
Oh? How deep is your stack? Are you sure your on-the-heap data structure
hasn't used up all your potential stack space?
The point is not that if the algorithm is all you're doing, you won't run
out of stack space. The point is that you don't know how much stack depth
you have, what's on the stack above you, or how big your data structure is,
even assuming you're recursing due to a data structure.
Or how much stack space the thing you're calling during the recursion takes,
if your recursion is part of a more generic data structure. If you say
"process each node of the DOM with this lambda", you don't know what that
lambda is going to do.
Why does C++ limit the depth of template instantiation required to 17
levels, or whatever it is? Clearly, it's possible to run out of stack doing
recursion.
in the cabinet."
Date: 28 Apr 2012 12:43:47
Message: <4f9c1e43$1@news.povray.org>
On 4/28/2012 2:56, Orchid Win7 v1 wrote:
> You have to tell the compiler whether or not you consider the C function to
Fair enough.
I don't know. That's why I'm asking. :-)
> probably end up using existing Haskell libraries for anything except actual
I think .NET is good at more than just I/O. :-) Actually, I don't think .NET
is any better at I/O that anything else on Windows is.
>> useful.
> Certainly it makes it less useful, yes. Whether it makes it "not worth it at
It breaks a fundamental tenet of .NET, which is that it doesn't matter what
language the caller is written in vs the callee. MS saying that "yes, this
.NET library works, but only if you call it from Haskell and not C# or VB or
F#" would not fly well.
in the cabinet."
As I said, if your recursion depth is O(log n), then you would need a
ridiculous amount of data in order to run out of stack space even with
a very stack-hungry recursive function. (For example, if your recursion
level were 50, then the input data, even if it took just 1 byte per element,
would require something like 1024 terabytes of RAM. How likely are you going
to run out of stack space with that few recursion levels? You could easily
have that many function calls on the stack even without recursion.)
It's highly unusual to require enormous amounts of stack on one single
function call, especially if you are implementing a recursive algorithm.
If each function call takes exponentially more stack space than there's
input, you are doing something wrong. (And even if you did, your algorithm
would be quite slow, as each function call would be operating on a rather
large amount of local data.)
Never heard of such a limit.
On 4/28/2012 9:52, Warp wrote:
> level were 50,
I understand your argument. I'm unconvinced that you're (a) not already 40
levels of stack deep when you get invoked, and (b) know what your stack
recursion depth can be.
Maybe I'm just used to working on machines with actual limited address space
and RAM. 50 levels of recursion sounds like a lot of stack space used, to me.
function call,
I would think that depends on the program. If you're making an image of your
input data for each level, you're screwed, which is why people tend not to
do that sort of thing. If (maybe) you're parsing a programming language, I
can see each level having a fairly large amount of data associated with it.
That's my point! :-)
IIRC, template function nesting is only required to be supported to some
realtively small depth.
in the cabinet."
> > level were 50,
My point is that you are not going to get even close to 50. Perhaps
something like 20.
If your stack can't hold hundreds of recursive function calls, then
you should upgrade your computer to the new millenium.
What? Even if each function call took like a kilobyte of space (which is
quite a lot for one single function call), it would still be just 50 kB.
I think stack sizes are counted in megabytes in modern systems.
> function call,
doing it wrong. (If for nothing else, then because it increases the
computational complexity of your algorithm by a factor of n, which is quite
a lot. Eg. a fast O(n log n) algorithm becomes a crawling O(n^2 log n).
Not to talk about if the original algorithm was eg. O(n^2) to begin with...)
I suppose the standard probably as a minimum recommended amount (like
it has for many other things, like the length of variable names). However,
if you surpass that limit your program won't even compile, so it's not
a question of running out of memory when running the program. (And most
C++ compilers have an option to increase the space dedicated to type
names.)
Consider that some projects use template metaprogramming quite
extensively, and the internal type names that result from it can be
quite large (we are talking about thousands and thousands of characters).
Most C++ programs don't use type names that long.
Well, that's what I said. If I have a machine with enough power to support
that sort of thing, I'm probably not going to be using C. :-)
PS: Pro-tip. I work for google. Don't try to spider the web recursively. ;-)
As the machines get bigger, so do the problems people throw at them.
But you have a database with a B-Tree index? Sure, chances are you're not
going to blow the stack walking down that tree.
I'm not saying recursion isn't useful. I'm saying that one must keep in mind
the possible depth of recursion, because C doesn't tell you when you overrun
the stack. You just get the same random errors you get when you run off the
end of an array, except you haven't actually violated the spec, as far as I
know.
Depends on the system. Credit card terminal? No. Last card terminal I worked
on had 14K of space free for code and data and stack. :-)
In any case, would you call malloc() inside each level of recursion as you
go without checking whether malloc() returned NULL? I wouldn't think so. So
if malloc() can fail and you want to check, why not recursion? Why not just
use the returned value from malloc() and let it crash out when you try to
write to offset 0?
> doing it wrong.
Yep. As I said, that's why people don't do it that way.
Note, however, that we're also comparing to things like Haskell, where the
"naive recursive algorithm" *is* the iterative algorithm.
> names.)
Yep. All to get around problems with naive recursive algorithms.
In any case, that's the sort of thing I'm talking about. If you add a level
of template indirection and your compiler crashes, that's one thing. If you
add another web page to the list of web sites you're selling ads on and your
revenue stream collapses, that's another thing.
Hope that you don't wind up adding another level to your templates and your
compiler finishes but generates the incorrect code.
in the cabinet."
> .NET is any better at I/O that anything else on Windows is.
Well, I haven't ever used .NET, so I couldn't say.
>>> useful.
>> it at
> what language the caller is written in vs the callee. MS saying that
> "yes, this .NET library works, but only if you call it from Haskell and
> not C# or VB or F#" would not fly well.
Well, another possibility would be "you can use this library, but it's
up to you to not do any I/O within transactions. If you do, anything
could happen, and it will be Your Fault."
I've been thinking for years that it would be cool to write a Haskell to
Java compiler.
Yesterday night, I discovered that somebody has actually done this.
Specifically, there is a compiler which translates a language called
"Frege" into Java. Frege is basically the same as Haskell, with a few
tiny syntax changes. The compiler takes your Frege source code and turns
it into Java source code, which the standard Java compiler then compiles
as normal.
At the moment, it's all quite experimental. There's basically one person
maintaining it, and it's still brand new. Documentation is nearly
non-existent. The compiler is fairly slow, and error reporting leaves a
lot to be desired. But it /works/.
I wrote 2KB of Frege code. The Frege compiler translated this into 47KB
of Java code. The Java compiler then translated this into 12 class files
totalling 30KB. The compilation process took just under 6 seconds.
Of course, the program I wrote is only a simple CLI thing for test
purposes. The interesting question is "how easily can I use the features
of Java?"
It looks like it only takes 1 line of code to turn an existing Java
class into a valid Frege data type. (A data type which Frege then knows
nothing about.) It takes a further 1 line of code to turn any Java
method into a valid Frege function. I haven't actually attempted to use
this yet, but there's some example code showing the creation of a Swing
GUI from Frege. The example is only 50 lines long.
Clearly I'm going to have to play with this for much, much longer before
I can say how truly /useful/ it is. It's pretty damned exciting though! :-D
