POV-Ray : Newsgroups : povray.off-topic : SPAAAAACCCEEEE Server Time
16 Jun 2026 12:10:40 EDT (-0400)
  SPAAAAACCCEEEE (Message 11 to 17 of 17)
Subject: Re: SPAAAAACCCEEEE
Date: 22 Mar 2012 14:58:08
Message: <4f6b7640$1@news.povray.org>
On 22/03/2012 5:41 PM, clipka wrote:
> Am 22.03.2012 09:55, schrieb Stephen:
>> Also a Mollweide projection (I think)
>> http://www.nasa.gov/mission_pages/WISE/multimedia/pia15481.html
> They call it Aitoff.
Thanks and I take my ait off to you. :-)
Regards
Date: 23 Mar 2012 12:12:21
Message: <4f6ca0e5$1@news.povray.org>
Am 22.03.2012 19:11, schrieb Le_Forgeron:
> the difference might be subtle. And is it Aitoff or Hammer-Aitoff ?
They call it Aitoff, so I guess it's Aitoff.
We definitely need custom-projection warps and cameras. You know, with
functions defining the projection.
Date: 23 Mar 2012 12:14:18
Message: <4f6ca15a$1@news.povray.org>
Am 22.03.2012 19:58, schrieb Stephen:
Why? Because I read the text? I had never heard of this Aitoff thing
before myself ;-)
Date: 23 Mar 2012 13:05:45
Message: <4f6cad69$1@news.povray.org>
> before myself ;-)
It was a joke, albeit a poor one.
Regards
Date: 23 Mar 2012 14:22:51
Message: <4f6cbf7b$1@news.povray.org>
Le 23/03/2012 17:12, clipka nous fit lire :
The true formula for Aitoff is painfull to generate a map (camera); at
least, I get confused by sinc-function enhanced formula (see english
wikipedia), as of course to make a camera, we are going from x,y to
spherical coordinate (and of course, that is not provided by the
documentation, and I did not intend to use a solver)
For custom-camera, you would need a way to output 2 vectors (origin,
direction) from the inputs of 4 vectors (location, up, right,
direction), 2 doubles between 0 and 1, and whatever you do with them as
hard-coded/SDL-coded formulas (including other SDL data and hard-coded
values).(you might see it as a function of 2 doubles which must provides
2 3D-vectors)
Some formula are easy in one direction and nightmare/impossible in
opposite (camera vs projection).
Did you say projection warps ? I would have thought about projection
map_type.  (from a 3D point, some others data (assume origin & other ?),
provide a couple of doubles : integer part can be used to isolate the
"once" (0.x,0.y) and the part after the dot is the coordinate on
map/picture (scale to 0 to 1 in both direction)
Date: 23 Mar 2012 21:45:27
Message: <4f6d2737$1@news.povray.org>
Am 23.03.2012 19:22, schrieb Le_Forgeron:
> 2 3D-vectors)
Not really.
The location, up, right & direction vectors just orient the camera;
that's a simple matrix operation that is independent of the projection
formula.
For a truly generic projection we'd need six funcions, each taking two
numbers (X and Y coordinate in resulting image): Ray origin X,Y,Z and
ray direction X,Y,Z.
For any cartographic projection, two functions would suffice: From two
screen coordinates (X,Y) we'd have to compute two spherical coordinates
(phi and theta).
> map_type.  (from a 3D point, some others data (assume origin&  other ?),
Map types can only be used with input images; implementing the stuff as
a custom warp instead would allow to do the same operations on other
patterns as well.
Date: 24 Mar 2012 07:53:11
Message: <4f6db5a7@news.povray.org>
Le 24/03/2012 02:45, clipka nous fit lire :
>> 2 3D-vectors)
> Not really.
> formula.
> (phi and theta).
Unless you are always mapping from below (center of the planet), I
prefer for an absolute custom camera to be able to set the origin and
direction of each ray (well, each pixel ray, as well as AA sub-rays).
It seems more natural to thing of the camera as a flying satellite
(well, rather a parallel set of raster satellites using their own single
"laser beam"). Probably something along a mathematical-function(s) based
"mesh camera" (without a mesh)
[so far, I have no intent to implement that fully custom camera. yet ?]
It could also allow for easy (easier ?) setting for stereographic render
(half left-picture for left eye, half right-part for right eye)
(not sure about naming that stereographic)
Simulating the eye(s ?) of bee or fly could also be done (once someone
found the formula)
> patterns as well.
Oh, nice thought. I would never have added a warp in a pigment/image_map
to change its type. Nor using a classical pattern.
maybe it would be "safer" to drop map_type and push the usage of warp
(doing it one way) for image_map.
About using other pattern, it might be more troublesome, as some are
really 3D and cannot be limited to a plane. (and other are using more
than just the position).
