![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Required XKCD reference: http://xkcd.com/558/
To most people, "million", "billion" and "trillion" are almost
interchangeable terms. Which is worrying, because those are /very
different/ quantities. They're not even remotely similar. But it seems
that when talking about large numbers, people get a kind of "numbness"
where the quantities are so vast that they seemingly might as well be
non-finite.
But you know what? As far as I can tell, almost nobody mixes up a
kilowatt and a megawatt. Nobody confuses centimetres with millimetres.
No one has trouble with a gram and a kilogram being very different
quantities. And when was the last time you saw somebody [who has a clue]
mix up a gigabyte and a terabyte?
So, perhaps what we need to do is start measuring money using SI
prefixes. For surely 165 megadollars is clearly smaller than 170
gigadollars.
Sadly, I fear that for some, 20 millicents /will/ equal 20 millidollars.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Names and addresses of at least three people who use them
interchangeably? (Your mother does not count.)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, if she uses them interchangeably, she definitely does not count
very well!
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> very well!
LOL
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In Finnish we have "miljoona" (equals "million"), "miljardi" (equals
"billion") and "biljoona" (equals "trillion", not "billion"). Now when
someone translates a news article from some USA news service that
contains billion, it gets sometimes translated as "biljoona", which is
actually 1000 times more.
Actually, checking Wikipedia, it's not just us:
http://en.wikipedia.org/wiki/Names_of_large_numbers .
-- Arttu Voutilainen
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No wonder MS Word has been advising people to just avoid the word
"billion" altogether. It's too ambiguous...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I think I'd want a cite specifically for non-hyperbolic usages (some
people 'interchange' the terms when used as hyperbole, that doesn't
really count as interchanging them.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In the same way as nobody mixes up a thousand and a million.
In the same way as nobody confuses a hundred with a thousand.
> quantities.
In the same way as no one having trouble distinguishing between 1 and
a thousand.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> non-finite.
> gigadollars.
It's even worst when you speak French. We have an additional step
between million, billion, trillion...
million = 1000000 = 10^6
milliard = 1000000000 or 1000 millions = 10^9
billion = 1000000000000 or 1 millions millions = 10^12
billiard = 10^15
trillion = 1 million billions = 10^18
trilliard = 10^21
quatrillion = 1 millions trillions = 10^24
quatrilliard = 10^27
quintillion = 10^30
quintilliard = 10^33
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Echoes my thoughts exactly; a thousand-fold difference "mentally"
matters much more for smaller numbers. I'd imagine that mix-ups
between, say, megabytes, gigabytes, and terabytes are as common as
those between million, billion, and trillion. It's also a bit rare that
I see either of these errors, so I don't know where Invisible got the
"to most people" aspect, although surveys testing the general public's
math knowledge tend to be scary enough that I suppose it's possible.
One error I *do* see all the time though, is a misuse of the term
"exponential" to mean anything superlinear (or just "a lot"). In
informal conversation it's a little grating, but sort of ok since it's a
relatively standard use of the word. When grading physics labs,
however, I saw parabolas called "exponential" more often than I saw them
called anything correct, and it drove my absolutely bonkers.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
