POV-Ray : Newsgroups : povray.off-topic : Today's suggestion Server Time
16 Jun 2026 12:08:51 EDT (-0400)
  Today's suggestion (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Today's suggestion
Date: 5 Mar 2012 10:07:52
Message: <4f54d6c8$1@news.povray.org>
On 05/03/12 11:59, Invisible wrote:
> Required XKCD reference: http://xkcd.com/558/
> To most people, "million", "billion" and "trillion" are almost
> interchangeable terms.
In Finnish we have "miljoona" (equals "million"), "miljardi" (equals
"billion") and "biljoona" (equals "trillion", not "billion"). Now when
someone translates a news article from some USA news service that
contains billion, it gets sometimes translated as "biljoona", which is
actually 1000 times more.
Actually, checking Wikipedia, it's not just us:
http://en.wikipedia.org/wiki/Names_of_large_numbers .
-- Arttu Voutilainen
Date: 5 Mar 2012 11:03:18
Message: <4f54e3c6@news.povray.org>
No wonder MS Word has been advising people to just avoid the word
"billion" altogether. It's too ambiguous...
Date: 5 Mar 2012 11:22:02
Message: <4f54e82a$1@news.povray.org>
I think I'd want a cite specifically for non-hyperbolic usages (some
people 'interchange' the terms when used as hyperbole, that doesn't
really count as interchanging them.
Jim
Date: 5 Mar 2012 13:12:50
Message: <4f550221@news.povray.org>
> But you know what? As far as I can tell, almost nobody mixes up a
> kilowatt and a megawatt.
  In the same way as nobody mixes up a thousand and a million.
> Nobody confuses centimetres with millimetres.
  In the same way as nobody confuses a hundred with a thousand.
> No one has trouble with a gram and a kilogram being very different
> quantities.
  In the same way as no one having trouble distinguishing between 1 and
a thousand.
Date: 5 Mar 2012 13:37:27
Message: <4f5507e7@news.povray.org>
> interchangeable terms. Which is worrying, because those are /very
> different/ quantities. They're not even remotely similar. But it seems
> that when talking about large numbers, people get a kind of "numbness"
> where the quantities are so vast that they seemingly might as well be
> non-finite.
> kilowatt and a megawatt. Nobody confuses centimetres with millimetres.
> quantities. And when was the last time you saw somebody [who has a clue]
> mix up a gigabyte and a terabyte?
> So, perhaps what we need to do is start measuring money using SI
> prefixes. For surely 165 megadollars is clearly smaller than 170
> gigadollars.
> Sadly, I fear that for some, 20 millicents /will/ equal 20 millidollars.
It's even worst when you speak French. We have an additional step
between million, billion, trillion...
million = 1000000 = 10^6
milliard = 1000000000 or 1000 millions = 10^9
billion = 1000000000000 or 1 millions millions = 10^12
billiard = 10^15
trillion = 1 million billions = 10^18
trilliard = 10^21
quatrillion = 1 millions trillions = 10^24
quatrilliard = 10^27
quintillion = 10^30
quintilliard = 10^33
Date: 5 Mar 2012 13:52:40
Message: <4f550b78$1@news.povray.org>
Echoes my thoughts exactly; a thousand-fold difference "mentally"
matters much more for smaller numbers.  I'd imagine that mix-ups
between, say,  megabytes, gigabytes, and terabytes are as common as
those between million, billion, and trillion.  It's also a bit rare that
I see either of these errors, so I don't know where Invisible got the
"to most people" aspect, although surveys testing the general public's
math knowledge tend to be scary enough that I suppose it's possible.
One error I *do* see all the time though, is a misuse of the term
"exponential" to mean anything superlinear (or just "a lot").  In
informal conversation it's a little grating, but sort of ok since it's a
relatively standard use of the word.  When grading physics labs,
however, I saw parabolas called "exponential" more often than I saw them
called anything correct, and it drove my absolutely bonkers.
Date: 5 Mar 2012 14:43:22
Message: <4f55175a$1@news.povray.org>
I read a book recently which suggests that the human sense of numbers is
inherently logarithmic, and that humans instinctively use ratios to
assess things. Because, think about it, if you're going to climb tree A
or tree B, it doesn't actually matter precisely how many applies are in
each tree. What matters is what the /ratio/ between them is.
...which would explain why, for really large numbers, people develop
this strange sense of numbness, as if all really big numbers are somehow
"equally huge". (A similar thing happens with really tiny numbers, by
the way.)
> It's also a bit rare that I see either
> of these errors, so I don't know where Invisible got the "to most
> people" aspect, although surveys testing the general public's math
The guy who does XKCD clearly sees this too. Maybe you only meet smart
people? Because where I live, there are many, many dumb people.
This.
Did you know that an exponential curve actually starts out /quite
shallow/? Saying that something is increasing "exponentially" does /not/
just mean it's increasing quite quickly. It means a very specific
mathematical relationship.
Date: 5 Mar 2012 14:54:24
Message: <4f5519f0$1@news.povray.org>
> the way.)
I don't see how a logarithmic sense of numbers explains this, since
under this hypothesis a "thousand-fold difference" should be judged
equally whether between one and a thousand or a billion and a trillion.
  I was actually implicitly pointing out that this "logarithmic
representation" hypothesis fails for very large (or small) numbers
(incidentally, I actually think if fails much more than just then).
It's pretty easy to construct examples where this is the case.
I think he was referring to a slightly different phenomenon where people
tend to assume that the units match when two values are being compared.
  I think the comic would apply equally if the units were meters and
kilometers, and it's not like your average metric-using person people
don't know the difference between the units themselves in that case.
Date: 5 Mar 2012 23:36:41
Message: <4f559459$1@news.povray.org>
> Names and addresses of at least three people who use them
> interchangeably? (Your mother does not count.)
How about Congressmen?
John
Date: 6 Mar 2012 04:02:20
Message: <4f55d29c$1@news.povray.org>
I think actually the comic was referring to the phenomenon where news
producers like to distort reality to make it sound more interesting, but
hey...
