POV-Ray : Newsgroups : povray.off-topic : The trouble with XSLT Server Time
18 Oct 2026 01:12:53 EDT (-0400)
  The trouble with XSLT (Message 65 to 84 of 84)
<<< Previous 50 Messages Goto Initial 50 Messages
Subject: Re: The trouble with XML
Date: 5 Mar 2012 08:25:45
Message: <4f54bed9$1@news.povray.org>
Le 2012-03-05 03:54, Invisible a écrit :
>>> That tells an XML processor what the character encoding is. It does not
>>> tell your text editor what the encoding is.
>> How about rephrasing this: "It does not /necessarily/ tell your text
>> editor what the encoding is."
>> What part of "get a decent text editor" didn't you understand? :-P
> Can you name one single text editor which can actually change character
> encoding based on a mere XML encoding specification?
I would bet emacs does it, since it does everything, including sorting
laundry and fixing tires.
But seriously, though, http://www.lmgtfy.com/?q=xml+editors
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 5 Mar 2012 13:19:11
Message: <4f55039f$1@news.povray.org>
Yeah. But then I'd have to use Emacs...
Right. Because my text editor only needs to edit XML. Oh, wait...
In all seriousness though. I could probably just configure my editor to
always use UTF-8. That still doesn't solve the problem of typing obscure
characters in the first place. And it still doesn't change the fact that
as soon as I open the file in any other program, it's going to break
because that other program doesn't know what the hell character encoding
to use.
Date: 5 Mar 2012 13:51:17
Message: <4f550b25$1@news.povray.org>
Am 05.03.2012 09:54, schrieb Invisible:
The integrated text editors of both MS Visual Studio 2010 and
BeyondCompare 3.0 definitely do it (and yes, I'm talking about plain
"ASCII" text editors, not dedicated XML editor components).
As for stand-alone text editors, I've not used any for years, but I
wouldn't be surprised if current versions of e.g. UltraEdit would be
doing this as well (it does have some "auto-detect UTF-8 encoding"
option after all, though I can't find any details about the magic used
in there).
Date: 5 Mar 2012 14:10:57
Message: <4f550fc1$1@news.povray.org>
Am 05.03.2012 19:19, schrieb Orchid Win7 v1:
Did you know that good text editors allow you to define your own fancy
keystroke combinations? So you can place your favorite special
characters on some easily memorizable combo of Alt-Shift-Explode or
whatever suits your needs.
> to use.
That's plain stupid nonsense. A non-UTF-8-aware text editor (or any
other piece of software capable of processing extended-ASCII text files)
confronted with a UTF-8 text file will display apparently random stuff
in place of any non-ASCII characters, but that random stuff saves fine,
and parses back as later UTF-8 without problem. Just make sure you don't
insert non-ASCII characters in the troublesome editor, and don't insert
anything into that random stuff.
This property is one of the fun things about UTF-8: Anything that can
handle at least /one/ extended-ASCII codepage can also handle UTF-8
transparently without even knowing.
(You /will/ get into trouble though if your <?xml ...?> declaration
doesn't match the actual character encoding of the file, but I guess
that should be obvious.)
Date: 5 Mar 2012 16:01:59
Message: <4f5529c7$1@news.povray.org>
On Mon, 05 Mar 2012 20:10:56 +0100, clipka wrote:
> Alt-Shift-Explode
I need a keyboard that has that as an option on it. :)
Jim
Date: 5 Mar 2012 22:13:44
Message: <4f5580e8$1@news.povray.org>
On 3/4/2012 18:05, clipka wrote:
> ... which is why there is XML Schema. And XML namespaces.
Actually, I'd be happy if once, once in my career, someone would provide me
"an XML feed" that could actually be parsed by an XML library without first
having to do a bunch of string crap to it to make it right.
   People tell me I am the counter-example.
Date: 5 Mar 2012 22:15:57
Message: <4f55816d$1@news.povray.org>
I expect you could set up vim to do it, since you can set it up to recognize
Python, Bash, etc.
Date: 9 Mar 2012 15:50:01
Message: <web.4f5a6cccc07fe63964c6b3fb0@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> On 26/02/2012 12:35 AM, Darren New wrote:
> > On 2/25/2012 2:37, Orchid Win7 v1 wrote:
> >> For example, to say "this XML file actually contains XHTML", you're
> >> supposed
> >> to add something like 5 separate headers, each about 25 million miles
> >> long,
> >> to the top of the file. Why? Would one header not be sufficient?
> > Really? What do you have to add? I suspect you exaggerate a bit.
> First, you must say
> <?xml version="1.0" encoding="ISO-8859-1" ?>
Gaah! No! Use UTF-8! 8859-1 is Western European/United States only! Any
characters that are not in this set will be rendered as ? or worse. UTF-8 gives
access to the whole of the Unicode codeset, so no data will be mangled by the
encoding. Sorry, I'm a big proponent of using a more universal character set,
especially when handling data.
> Which is fair enough, although the 5-digit ISO code number isn't exactly
> easy to remember. Then you have to say
> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
> Yeah, I'm really going to remember that without looking it up. :-P No,
> you can't just say "this is XHTML". You really do have to write all that
> crap. And after /that/, you still have to say
Yeah, the DTD is a bear; what you do is set up a starting point and use that so
you don't have to remember the DTD all the time.
> <html xmlns="http://www.w3.org/1999/xhtml">
> Um, didn't I just declare this as XHTML already? At least this URL is a
> bit shorter, I guess...
You set a doctype processing instruction that gives a web browser information on
how to handle your document, remember, HTML comes in many different flavors.
Your xhtml document is an xml document. The xmlns attrubute is specifying that
this document should conform to the specifications of the xhtml standard. I
think this is actually optional, but allows better validation. This uses an xsd
file which defines the schema.
> In short, that's a /hell/ of a lot of typing, before I've even written
> my document. It's also a lot of typing that I have to go look up on
> three different websites every single damned time I want to write XHTML.
Meh. You create a starter file and copy that when you want to do an xhtml file.
> >> Then there's all that stupidity with character entities. It should be
> >> possible to include character entities in /all/ XML documents, not just
> >> XHTML. But to this day, I have never discovered a way of doing this.
> > You have to declare the entities. Otherwise, you run across &frump; and
> > don't know what it means. That's what DTDs are for.
> So why isn't there a DTD somewhere that contains all the entities that
> everybody uses, which I can just link to? More to the point, since
> everybody uses the same set of entities, why aren't they built in?
Because sgml is a standard that allows a large amount of flexibility in what it
actually is.
> >> One of the nice ideas of XML is that you can use namespaces to include
> >> one
> >> sort of XML document inside enought - e.g., you could put an SVG file
> >> inside
> >> an XHTML file. But nooo, apparently you need a specialised DTD to do
> >> that.
> > You can. Of course, your various processors have to know what the
> > various namespaces *mean*, so you have to declare them and you have to
> > have a processor that understands them (which is where the DTDs come in).
> You would /think/ you could just say "hey, this stuff here is in the
> XHTML namespace, this stuff here is in the SVG namespace", and that
> would work. But it doesn't. You need to use a DTD specially written for
> the exact combination of XHTML+SVG. To me, this indicates that the
> system is fundamentally broken. It should not be necessary to write a
> separate DTD for every possible combination of XML documents imaginable.
> You should just be able to refer to the DTD for XHTML and the DTD for
> SVG and have it work.
Thing is, the DTD and schema can be defined anywhere. That's why all of the
clunky URL's.
Subject: Re: The trouble with XSLT
Date: 9 Mar 2012 15:55:01
Message: <web.4f5a6d50f77903f464c6b3fb0@news.povray.org>
Le_Forgeron <lef### [at] freefr> wrote:
> Le 23/02/2012 10:11, Invisible a écrit :
> > This still leaves me with the problem of how to generate unusual
> > characters in the first place. Typing → is pretty simple. Figuring
> > out how to actually generate the arrow character is not.
> You just need the right documentation.
> Either you search it each time on the web (like "utf-8 chartable"... )
> or you call it correctly, and ask for unicode (utf-8 is one
> presentation, unicode is what you really want), and get to print the
> parts that you need often.
> See http://unicode.org/charts/
> And soon you will discover that there is no single font to display all
> possible unicode glyphs.
> You also need a unicode-compatible editor...
Code2000 comes close for Plane 1... The higher planes are a different story
alltogether, but most of those are rather specialized anyway.
Date: 9 Mar 2012 15:56:10
Message: <4f5a6e6a@news.povray.org>
  Nothing stops you from using &#xx; codes regardless of the encoding.
Date: 9 Mar 2012 16:00:00
Message: <web.4f5a6e76f77903f464c6b3fb0@news.povray.org>
> OK, so I've written a program that generates a bunch of XML as output.
> If you open that in a web browser, it shows up as a simple parse tree.
> Which is OK, but a little verbose.
> Fortunately, using the wonders of XSL (specifically, XSLT) you can have
> the browser transform the raw XML into a pretty-looking XHTML document.
> But *only* if you edit the original XML file to mention the XSLT file
> that you want to apply.
> Now, it ought to be simple to write a 3-line file that says "take this
> XML file and that XSLT file, and display the result". But after over a
> week searching the Internet and even consulting Stack Overflow, I cannot
> find any way of doing this. I literally cannot *believe* that something
> so trivially simple is also so utterly impossible.
> If there /is/ a way of doing this, every single XSL tutorial in
> Christendom fails to mention it. No XSL FAQs mention it either - it's
> not even that they say it can't be done, it's that none of them even
> contain a question about this topic. This raises the alarming
> possibility that what I'm trying to do might actually be impossible
> after all. (Which is slightly daft, given that it's the entire point of
> XSL existing in the first place...)
> To be clear: It seems to be perfectly possible to apply any XSL to any
> XML if you use an external 3rd-party tool. You just can't do it with a
> *web browser*. You know, those programs that know about XML and XSL and
> are installed on every computer in the world. No, you have to select and
> download a special CLI utility if you want to perform such advanced
> wizardry. *sigh*
> My first thought: XSL lets you include one stylesheet inside another, so
> maybe you can include one source document inside... erm, no. No you can't.
> It looks like it /might/ be plausible to do something with the XSL
> document() function - but I haven't figured out exactly how yet.
> Apparently XML itself has a general include feature called XInclude.
> According to Wikipedia, "Browser support: None". *facepalm* OK, so
> that's really going to help then.
> About the closest thing I've found is a website that says that if you
> copy and paste a few miles of convoluted JavaScript code, you can make a
> web page that runs the script which then loads the required XML in the
> background, lots the XSL, applies one to the other, and inserts the
> result into a specific position in the DOM of the current document. In
> particular, it cannot /replace/ the current document, it can only be
> /inserted into/ it. So if your XSL generates an entire XHTML document...
> forget it.
> (I presume it goes without saying that the first thing this code snippet
> has to do is test whether it's running on Internet Explorer or a
> standards compliant browser. :-P Some things never change...)
> So it looks like I'm going to have to sit down and write a special tool
> to take an XML file and copy it, inserting the correct XSL reference
> into the header. How pathetic...
I coded one up in C# in about 15 minutes. It doesn't take much if your language
of choice already has a library for handling xml/xslt.
I found this post rather interesting as my current project is one big stylesheet
to turn raw xml into a legible report. I've learned just how powerful the
language is. There's a ton you can do with it, and I now wonder why everyone
always moans and groans about how difficult it is to deal with.
Date: 9 Mar 2012 16:37:09
Message: <4f5a7805$1@news.povray.org>
On 09/03/2012 20:56, Warp wrote:
>    Nothing stops you from using&#xx; codes regardless of the encoding.
Correction: The finite limitations of the human mind stop you using hex
codes. :-P
Date: 9 Mar 2012 16:38:18
Message: <4f5a784a$1@news.povray.org>
Tell it to [every piece of Windows software that inspects text files].
All of these programs seem to default to that encoding, not UTF-8.
Date: 9 Mar 2012 16:43:15
Message: <4f5a7973$1@news.povray.org>
It only takes 15 /seconds/ to type in a command if you have a 3rd party
external XSLT processor (e.g., Saxon). But apparently you can't get the
/web browser/ to do this. You have to create a new, separate,
transformed version of the file.
It might not sound like much, but it means every time you change the
program that generates the XML, you can't just rerun that program. You
have to rerun the program, and then rerun Saxon (or whatever), and then
reload the browser page. It's a PITA.
What I ended up doing, obviously, was providing a way to change the XSL
reference that the original program inserts into the XML file. :-P
[I presume you're talking about XSLT here.]
It's interesting that there's one set of facilities for processing the
input functionally, and a separate, redundant set for processing it
imperatively. The latter set is much less powerful to boot. (Perhaps
that was deliberate.)
What I can't figure out is this: How do I make it process an element one
way if it contains a "small" amount of content, and process it a
different way if it contains a "large" amount of content?
Date: 9 Mar 2012 20:06:35
Message: <4f5aa91b$1@news.povray.org>
> codes. :-P
step 1: www.google.com
step 2: "unicode chart for _____ characters"
step 3: File | print
step 4: Tape to side of computer screen.
Back when dinosaurs roamed the Earth, that's what most of us did for
DOS-based editors when we needed accented characters, or for the more
daring, ASCII graphics.
Date: 9 Mar 2012 20:07:58
Message: <4f5aa96e$1@news.povray.org>
Change your local settings to Bulgaria or Czech Republic and it won't!
Date: 10 Mar 2012 04:23:01
Message: <4f5b1d75$1@news.povray.org>
Won't default to UTF-8? Yes, I know. ;-)
Date: 19 Mar 2012 12:21:27
Message: <4f675d07$1@news.povray.org>
This is true, but, in general, UTF-8 is the better way to go, but if the
data displayed on the page comes form a different source...
Date: 19 Mar 2012 12:23:23
Message: <4f675d7b$1@news.povray.org>
That's because nobody bothers with the encoding. But what drives me nuts
is when web-authors stick in an encoding, then use UTF-8 characters in
it. You get all sorts of ugliness.
Date: 19 Mar 2012 12:27:38
Message: <4f675e7a$1@news.povray.org>
Use xsl:choose and have the when statements with the appropriate test?
I'm unclear as to what constitutes a small amount of content v.s. a
large amount of content.
You could have it trigger on the string-length of the node's value, for
instance. Or, you could trigger on the number of nodes (using count)
