POV-Ray : Newsgroups : povray.off-topic : PIPA and SOPA Server Time
28 Jul 2026 13:34:09 EDT (-0400)
  PIPA and SOPA (Message 179 to 188 of 188)
Subject: Re: PIPA and SOPA
Date: 7 Feb 2012 08:28:34
Message: <4f312702$1@news.povray.org>
Le 2012-02-07 04:16, Invisible a écrit :
>>> Damn. How do you ever get anything done?! o_O
>> I use Google Reader so I don't have to visit all those sites to see
>> what's new. Takes me about an hour in the evening to go through the
>> day's posts and see what's new.
> It used to take me about 4 hours in the evening (i.e., my entire
> evening) just to read this newsgroup. (Although it seems a lot quieter
> lately...)
>>>> Yes, it is the connection that determines the picture quality.
>>> Erm, no. It's the quality that the file is transcoded at.
>> A connection that isn't fast enough isn't going to show you the full
>> definition. I defy you to demonstrate a high quality video over a slow
>> connection.
> If the bitrate of the source is higher than the available bandwidth, it
> just won't play in realtime. It'll constantly stall to rebuffer. So
> presumably the guys behind iPlayer (and every other Internet video
> system) have to transcode to a low enough bitrate that it will actually
> play in realtime. The result is obviously poor image quality.
Once again, you presumed wrong, since other people are able to see the
full image!
> Consider, for example, that it took me 3 days to download Star Wreck,
> which is only about an hour long. OK, that was only using a 2 Mbit
> connection, but I don't suppose you can download almost 4GB of data over
> an 8 Mbit connection in one hour flat either.
Bad example.  Assuming you downloaded it via bit-torrent from other
users, you were constrained by their very limited upload speeds.  If you
downloaded it from an FTP server, you were also porbably constrained by
the number of connections clobbering said server.
Netflix, and other streaming sites have banks of high performance
servers connected to very large internet pipes, in multiple sites that
are close to the users.  This way, there are fewer bottlenecks and
little to no latency issues that can interfere with the stream.
>> <sigh>
>> https://lh6.googleusercontent.com/-UJGO-U7Whto/TzAdp1huWOI/
>> AAAAAAAABbs/1IPtFRGNv6Q/s912/2012-02-06.jpg
>> Now consider that's a quick photo of a 10' screen streaming realtime at 3
>> Mbps. The bluriness you see there is an artifact of the camera used, not
>> the actual image on the screen.
>> Obviously the necessary bandwidth exists.
> Yes, the picture looks fine. I still don't understand how that can be
> possible though. The Internet isn't fast enough. I don't see how you can
> get the data from A to B fast enough for realtime playback.
Which part of the Internet isn't fast enough?
Is HD tv available in the UK, from cable tv providers?  Stop and think
for a few nanoseconds how that signal is delivered to your cablebox.
Netflix and co. are the same thing, except the source server is just a
few 10Gbps hops further away on the Internet backbone.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 7 Feb 2012 09:06:34
Message: <4f312fea$1@news.povray.org>
Except that you're downloading it from dozens of clients at once, should
should counteract that problem.
The last mile, as always.
I have no idea what "cable" is. I do know you can receive HD TV with an
aerial; presumably this uses higher bandwidth than a normal Internet
connection.
Date: 7 Feb 2012 11:15:01
Message: <web.4f314d6dd1155342352a052d0@news.povray.org>
> connection.
it's also far cheaper, since it's broadcast, i.e. all users receive the very
same stream, not a stream per millions of users...
Date: 7 Feb 2012 15:00:05
Message: <4f3182c5$1@news.povray.org>
> lately...)
I probably spend a couple hours a day reading my 200+ newsgroups.  Again
usually just skimming subjects for things that are interesting.
>> connection.
Clearly not, as shown in my photo.  In the case of Netflix, they use a
dynamically adjusting algorithm so it can display lower quality if the
bandwidth is throttled.  You'll note that I noted to Stephen that Netflix
shows "Medium/HD" as the quality for that image - that's usually what I
get.  If I had a slower connection, I get "High/SD" or "Low/HD".  If I
had a faster connection, I'd get "High/HD".
That was at a fixed quality setting, not being streamed.
>> <sigh>
>> 3 Mbps.  The bluriness you see there is an artifact of the camera used,
>> not the actual image on the screen.
Compression.  We've been over this before.
Jim
Date: 8 Feb 2012 04:05:50
Message: <4f323aee$1@news.povray.org>
Damn. If I had that much stuff to look at, I'd *never* get any work
done... Oh, wait.
So they actually offer multiple quality levels? Well, I guess that makes
good sense. I'm not sure how you'd automatically detect which one to
use, but I guess with the right client software it ought to be possible.
Lossy compression allows you to make the file size be anything you want
it to be. But this does not happen by magic; it happens by degrading the
picture quality. So while it obviously /is/ possible to reduce a video
stream to, say, 3KB per second, it wouldn't be worth watching. What I
can't figure out is how they can shrink it down to realtime download
speeds without it looking awful.
Date: 8 Feb 2012 08:25:40
Message: <4f3277d4@news.povray.org>
Not always.
Which varies a lot from place to place.  First, because your DSL speed
will be affected by the distance or the CO from your house, and by the
quality of the wires.  On top of that, different carriers have different
services.  For example, on top of various DSL packages, my telephone
company offers fibre connections at 7, 10, 16 or 25 Mbps.  My Cable
provider offers comparable packages as well.
> connection.
Presumably?  Again.  After having been shown 4759483758975 times in this
thread alone that your assumptions were wrong, you still persevere!!!
Also, http://en.wikipedia.org/wiki/Cable_television
Date: 8 Feb 2012 09:08:10
Message: <4f3281ca$1@news.povray.org>
> Not always.
As in "you're not always downloading from that many clients", or as in
"downloading from many clients doesn't give you greater bandwidth"?
> will be affected by
Yes, but given that 8 Mbit/sec is the maximum speed that current ADSL
standard allow, we can take it as read that nobody is going faster than
that.
Oh, really? Well, if you're getting 25 Mbit/sec then yes, streaming
full-quality video in realtime /should/ work just fine.
(At least, for SD video. Apparently BRD has a transfer rate of 36
Mbit/sec, so it looks like HD video still wouldn't work.)
>> connection.
And to think people tell me I don't persevere enough...
At any rate, a cursory inspection of Wikipedia seems to indicate that,
yes, digital TV is higher bandwidth.
Oh, is /that/ what that means? OK. I didn't know you could use this for
anything other than analogue TV. Our house used to have this, before
everything went digital.
Date: 8 Feb 2012 15:37:02
Message: <4f32dcee$1@news.povray.org>
>> Again usually just skimming subjects for things that are interesting.
> done... Oh, wait.
Certainly if you didn't have a way of handling it more quickly, you
wouldn't.  That's kinda my point.
You start with the lowest quality and increase the quality until you hit
some sort of limitation.  Buffer enough so it doesn't stutter when you
hit the limitation, and then back off.
>>> can get the data from A to B fast enough for realtime playback.
Measuring latency and throughput.  It's not magic.
Jim
Date: 8 Feb 2012 22:35:23
Message: <4f333efb$1@news.povray.org>
> standard allow, we can take it as read that nobody is going faster than that.
It depends entirely over the distance you are from the head end. I get
12Mbps on the DSL line that only has to go down to the street from my condo.
> (At least, for SD video. Apparently BRD has a transfer rate of 36 Mbit/sec,
Have you tried watching an HD youtube video, out of curiosity?
   People tell me I am the counter-example.
Date: 9 Feb 2012 04:25:15
Message: <4f3390fb$1@news.povray.org>
>> than that.
No, it does not.
http://en.wikipedia.org/wiki/ANSI_T1.413_Issue_2
"The maximum achievable downstream data rate is 8.128 Mbit/s."
If you're too far from the exchange, you will get less than 8 Mb, but
you will never get /more/ than 8 Mb. That's like saying that if you
connect a USB 1.0 device with a short enough cable, you can make it go
faster than 12 Mb. Erm, no, no you cannot, because the USB 1.0 standard
specifies a maximum data rate of 12 Mb.
So, like I said, unless you're using something other than ADSL, you
cannot go faster than 8 Mbit/sec.
I think I've tried flicking the quality switches at some point. From
what I recall, turning the quality up makes playback a bit less
reliable, and the picture quality a bit less awful. But it's certainly
not as good as SD TV picture quality.
(Or rather, certain SD channels. I've noticed that some digital TV
channels are also fairly heavily compressed...)
