POV-Ray : Newsgroups : povray.off-topic : PIPA and SOPA Server Time
30 Jul 2026 14:36:58 EDT (-0400)
  PIPA and SOPA (Message 161 to 170 of 188)
Subject: Re: PIPA and SOPA
Date: 3 Feb 2012 07:45:39
Message: <4f2bd6f3@news.povray.org>
On 02/02/2012 10:24 AM, Invisible wrote:
> On top of that, at peak times iPlayer becomes almost unusable. It
> freezes constantly. I'm not sure whether it's the BBC servers or the ISP
> network that can't keep up, but you just can't watch anything. But then,
> if you select "high quality mode", then it runs like that all the time.
There is free software you can use that will download and save the
streaming media to your hard drive. So that you can watch or listen to
the programmes without all those buffering waits.
Regards
Date: 3 Feb 2012 07:58:35
Message: <4f2bd9fb$1@news.povray.org>
Oh, iPlayer lets you do that anyway. But yeah, it would be kinda useful
if I could do that to YouTube. (E.g., there used to be a video of a
really great performance on a Wurlitzer. It's now vanished...)
Date: 3 Feb 2012 08:03:29
Message: <4f2bdb21@news.povray.org>
http://www.youtubedownloadersite.com/
Regards
Date: 3 Feb 2012 09:09:52
Message: <4f2beab0$1@news.povray.org>
Le 2012-02-03 04:22, Invisible a écrit :
>> I have absolutely never
>> had to use the $ key on my keyboard, unless I was programming in Perl.
> This comment makes the whole discussion worth it! :-D
>>>> "In another building" DOES NOT mean "over the Internet". Private data
>>>> circuits predate the internet, and no company would use the Internet to
>>>> link two data centres together.
>>> How is that even *possible*? It's not like you can just go to the
>>> hardware store and buy 25km of copper wire and then put it into the
>>> ground with a shovel on your day off or something...
>> You don't do it yourself, unless you are in a campus environment and can
>> easily rip up the parking lot and lay down your own fibre or copper.
>> Step 1. Call your telco rep and order a circuit between site A and
>> site A.
>> Step 2. Telco will forward the request to a planner who will determine
>> if the existing cabling between both sites and central offices (CO) has
>> enough available bandwidth.
>> Step 3a. If not, the planner will forward the request to their
>> infrastructure group who will get diging permits from the
>> city/county/whatever and lay down new bundles of cables.
>> Step 3b. If the answer is yes, or once the new cables have been laid,
>> the telco planner will forward your request to an enabler who will
>> configure the CO switches to map the circuit from Site A's demarcation
>> point to Site B's demarcation point.
>> Step 4. Technicians will come on site, at both locations, and terminate
>> the circuit from their demarc point to the exact rack you ask them to.
>> Step 5. You plug in the circuit in your equipment (router, switch, or
>> mainframe front-end-processor, to name a few)
>> Tada!
>> Usually, all of this is done for a small nominal fee. Any work they have
>> to do between demarc points will be undertaken at their own expense,
>> which they will recoup on your monthly usage bill, of course.
>> By the way, if you ordered an "internet" link, the exact same steps
>> would have to take place, except that they would be duplicated for site
>> A to ISP and ISP to site B, and then the ISP would add its own routers
>> at both ends and charge you twice as much and more for the "managed
>> services".
> Think is, if you order an Internet link, the telco has to run a few
> hundred yards of cable to the nearest junction box at one end, and a few
> hundred yards at the other end.
Which is exactly what I have described above, except the dealing with
the telco is done by the ISP's engineers, not you.
> If you want a dedicated circuit from one
> end to the other without going via the Internet, they have to run
> several miles of cable just for you. Who the /hell/ can afford that? o_O
No. No. No. No.  What makes you think they would have to lay more cable
for a dedicated circuit than for an internet connection?  Re-read step 2.
A dedicated circuit from my company's site A to site B goes:
Site A -> Telco CO 1 -> Telco Cloud -> Telco CO 2 -> Site B.
An Internet VPN goes:
Site A -> Telco CO 1 -> Telco Cloud -> Telco CO 3 -> ISP -> Telco CO 3
Now, can you see that connecting to an ISP is effectively ordering TWO
dedicated circuits instead of one?
Using an Internet VPN only makes sense when the costs of a dedicated
cricuits becomes prohibitive and you must share the cost with others, at
the expense of latency and garanteed bandwidth.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 3 Feb 2012 09:49:14
Message: <4f2bf3ea$1@news.povray.org>
The fact that rather than connecting you to an existing circuit, they're
building a brand new one from scratch.
If it goes through their main cloud, it isn't a dedicated circuit. It's
a shared circuit.
Date: 3 Feb 2012 12:36:45
Message: <4f2c1b2d$1@news.povray.org>
I never said they would build a new one from scratch, unless there was
no bandwidth available on their existing infrastructure.
> a shared circuit.
You can have dedicated bandwidth allocated to you on a shared physical
circuit.  For example, on a DWDM link, if I assing the 720nm frequency
to you, and the 680nm frequency to me, we would both have dedicated
bandwidth on that fibre strand as it is physically impossible for our
signals to suddenly merge or impact the other.  Likewise for TDM
circuits, where each fram is divided into timeslots, and each customer
is allocated a certain amount of timeslots.  There is no possibility of
overlap or oversubscription.
A "shared" bandwdith scenario would be ATM, Frame-Relay SVCs, X.25,
etc... where packets are sent through the cloud on a
first-come-first-serve basis and where there is the possibility of
oversubscription.
I apologize for using the word dedicated, instead of point-to-point.
Date: 3 Feb 2012 20:31:48
Message: <4f2c8a84$1@news.povray.org>
On 2/3/2012 6:49, Invisible wrote:
> If it goes through their main cloud, it isn't a dedicated circuit. It's a
> shared circuit.
SONET. That's what it's for.  It's dedicated isochronous bandwidth on a
shared circuit, designed to let you merge them together onto a faster
circuit and back out again.
You think when you make an ISDN call you're not getting a 64kbps dedicated
circuit for the duration of the call?
In any case, when you lay cable, you lay down way more than you need,
because the cost of the physical cable is trivial. THe first guy who asks
for a connection causes 900 pairs to be laid. The next 899 require none of
that work.
   People tell me I am the counter-example.
Date: 3 Feb 2012 20:33:08
Message: <4f2c8ad4$1@news.povray.org>
On 2/3/2012 4:58, Invisible wrote:
> Oh, iPlayer lets you do that anyway. But yeah, it would be kinda useful if I
> could do that to YouTube. (E.g., there used to be a video of a really great
It is called, not surprisingly, "Download Helper"
Date: 5 Feb 2012 18:05:35
Message: <4f2f0b3f$1@news.povray.org>
On Fri, 03 Feb 2012 11:19:04 +0000, Invisible wrote:
>> It's time consuming to visit 100 sites to see if there's anything new.
>> It's far easier to be alerted when there's something new that might be
>> of interest.
> 100 sites?! o_O
> Damn, you actually follow that much stuff? Jees...
Yes, I do.  Now for things like Slashdot or The Register, I skim
headlines in Google Reader.  I don't always read the full article - but
if a headline is intriguing, I'll dig in a little deeper.
With Slashdot, if I read the headline and it looks interesting, I'll read
the story there.  If it looks more interesting, then I'll open the link
to the /. story and follow the links to the actual story.
>>>>> That's why I just built a new PC - to experience the Core i7
>>>>> first-hand.
>>>>> :-P
>>>> So then why bother going to Tom's Hardware again?
>>> Sarcasm? :-P
>> Or perhaps to find out what the latest processor is that you might be
>> able to afford?
> For that, I go to various shopping websites. I visit Tom's Hardware to
> find out which products have good performance.
Bingo.  Thank you, you've made my point.  You *can* actually learn stuff
by reading about it on the 'net.
>>> Want to bet that the BBC has servers all over the world?
>> So you just happened to get a crappy connection, while I got a good
>> one?
> Or the BBC offers different quality levels in different parts of the
> world? Heck, maybe they're even using a different codec or something? I
> don't know.
I see.  So the BBC offers really crap quality to those who pay the
licensing fee in the UK, but offers really good quality to those who
don't?
>> Then your eyes are better than mine, or you got a really crappy
>> connection.
> Yes. Because it's the connection that determines the picture quality,
> not the sender. Oh, wait...
Yes, it is the connection that determines the picture quality.  If I only
have a 32 Kbps connection, I'm not going to get a good quality HD picture.
> Sure, it's all compressed. But that almost always means lossy
> compression. You have to trade how much bandwidth you have for what
> level of picture quality you want. And that's the problem - it seems
> that to stream realtime over the Internet, you have to accept really low
> picture quality.
Would you like me to take a picture of Netflix streaming on my 10' wide
screen with a 3 Mbps ADSL connection?  Would that make you happy?
Jim
Date: 5 Feb 2012 18:28:00
Message: <4f2f1080@news.povray.org>
> don't?
Hmm!
I use get_iplayer to download progs and the blurb on the site says:
The iPhone H.264 feeds from the BBC are higher quality than in the Flash
iPlayer (normal quality). See the beebhack wiki for a comparison. They
are intended for the Apple iPhone and are consequently difficult to
download for any other OS. The same goes for the iPhone MP3 radio
streams. get_iplayer also allows recording of the high-quality (even HD
720p) flash based content using rtmpdump. None of the above content is
‘protected’ by DRM. get_iplayer cannot remove DRM.
http://www.infradead.org/get_iplayer/html/get_iplayer.html
BTW Just a minute starts its 62nd series on Monday. Happy 45th Birthday,
Just A Minute!
http://www.bbc.co.uk/programmes/b01blgp6
Regards
