POV-Ray : Newsgroups : povray.off-topic : Dual Server Failure Server Time
16 Jun 2026 13:24:47 EDT (-0400)
  Dual Server Failure (Message 11 to 20 of 65)
Subject: Re: Dual Server Failure
Date: 16 Jan 2012 11:07:52
Message: <4f144b58@news.povray.org>
>> Yeah, it's funny... I've noticed this strange correlation between
>> expensive down-time and management willingness to invest in
>> fault-tolerant equipment. ;-)
> As we get more people and process more data - the more down time will
> cost. Eventually we may get to higher uptime requirements - but for now
> 2 hours of downtime 2x a year is not too bad.
As with everything, it depends on just how expensive down-time actually
is. If the answer is "not very", you don't need to worry about fixing it
too much.
Amusing anecdote: One of our servers had a hardware RAID system. The
idea is that if one of the drives dies, the RAID controller will keep
the server operational. You know what died? THE RAID CONTROLLER! >_<
Date: 16 Jan 2012 14:12:37
Message: <4f1476a5$1@news.povray.org>
> too much.
I like what Google has set up - files are stored everywhere on cheap
hardware.  If something fails, then it just gets swapped out.  But the
cheap hardware fails often and requires more manpower to manage and
replace it.
Date: 16 Jan 2012 15:03:50
Message: <4f1482a6@news.povray.org>
On 16/01/2012 7:12 PM, Tom Austin wrote:
> But the cheap hardware fails often and requires more manpower to manage
> and replace it.
Jobs! :-D
Regards
Date: 17 Jan 2012 04:06:16
Message: <4f153a08@news.povray.org>
> replace it.
Yeah, but most people can't do that. Most people don't have the space,
ventilation or power requirements to host hundreds of boxes, nor the
money to pay a team of twenty people to keep it all running.
On top of that, most applications are /not/ designed for distributed
implementation. If you're Google, you can just /write/ the software you
need. Most business buy it off the shelf.
Date: 17 Jan 2012 22:04:13
Message: <4f1636ad$1@news.povray.org>
> ventilation or power requirements to host hundreds of boxes, nor the money
Google has hundreds of computers in their data centers. Unfortunately for
you, Google counts "a shipping container full of thousands of mother boards
and disk drives" as "a computer". ;-)  It's really quite awesome. Upgrading
a server is known as "forklifting" it.
And you know, I really, really miss SQL. :-)
   People tell me I am the counter-example.
Date: 18 Jan 2012 04:06:13
Message: <4f168b85$1@news.povray.org>
> for you, Google counts "a shipping container full of thousands of mother
> boards and disk drives" as "a computer". ;-) It's really quite awesome.
> Upgrading a server is known as "forklifting" it.
Pictures or it didn't happen. :-P
Actually, I was just thinking about how many scrap PCs you could
scavenge and wire together to make a cluster. I wonder how much old junk
you would need to even come close to the processing power of a single
high-spec PC?
Even if it does violate the relational model? Aww, it must be wuv...
Date: 18 Jan 2012 08:42:40
Message: <4f16cc50@news.povray.org>
>> and replace it.
> Jobs! :-D
No.  He died a while back.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 18 Jan 2012 08:45:30
Message: <4f16ccfa$1@news.povray.org>
>> Jobs! :-D
Oldies but goldies...
Date: 18 Jan 2012 10:15:34
Message: <4f16e216@news.povray.org>
>>> and replace it.
>> Jobs! :-D
Jobbies! Then. :-P
Regards
Date: 18 Jan 2012 12:27:34
Message: <4f170106$1@news.povray.org>
On 1/13/2012 2:07 PM, Tom Austin wrote:
> So now the hunt - why did winbind die......
It died because I made a small configuration change.
I did not make a backup of the config file because I was making a very
simple change that was very easily undoable.
Just a simple x = y line.
Well, in VI I hit i too many times and that little extra 'i' got added
to the domain for winbind - in a hard to see place.
So, lesson learned - no matter how simple the modification - always make
a copy that you can fall back to that is UNMODIFIED from what works.
At least now I have a simple smb.conf for sharing files in an emergency.
