POV-Ray : Newsgroups : povray.off-topic : Is this the end of the world as we know it? Server Time
18 Jul 2026 08:54:38 EDT (-0400)
  Is this the end of the world as we know it? (Message 356 to 365 of 545)
Subject: Re: Is this the end of the world as we know it?
Date: 13 Oct 2011 15:16:22
Message: <4e973906@news.povray.org>
On 13/10/2011 07:48 PM, Darren New wrote:
> On 10/13/2011 1:28, Invisible wrote:
>> Um, why did it page it *out* in the first place?! I thought it was only
>> supposed to swap stuff out if the space was needed for something else?
> Other stuff, like Windows Update or disk defragger, might have run in
> the background. Note that processes like Superfetch are supposed to
> minimize this effect.
I thought that's only in newer versions of Windows. I'm using XP here.
> (I saw an interesting lecture on the changes
> they'd made to prevent "back from lunch syndrome.")
Yeah, I vaguely remember reading something like that... Can't remember
how I found it now.
http://blog.orphi.me.uk/
Date: 13 Oct 2011 15:55:17
Message: <4E974227.10306@gmail.com>
On 13-10-2011 20:51, Darren New wrote:
> On 10/13/2011 9:12, andrel wrote:
>> Might be, but why design it this way? Why has cntrl-alt-del not a higher
>> priority than disk-IO and indeed any other program/process?
> Sure, but what's it going to do when it gets that keystroke? It has to
> fire up the code that handles it, presents the UI, etc. *That* is what
> takes time to page in.
So that moves the question to: why is the ctrl-alt-del handler paged
out? And the UI: why has that to be on the GUI, with all the page faults
that may result from swapping pixels to disk? Remember we are sending a
low level high importance interrupt and the user knows that.
>> modern machines: why not dedicate one core to the OS and the OS alone?)
> The core isn't the problem.
I know. I am just asking if there is still a reason to handle the kernel
like any other user process.
> The disk is the problem, because
> rescheduling disk is slow. You can interrupt the CPU in a few hundred
> machine cycles. You can't really interrupt a disk seek.
But, is there any reason to stop the entire kernel because of a disk seek?
> Indeed, I suspect if Windows figured out your startup programs, figured
> out that you actually have more than enough RAM to load them all, and
> would just load the entire file sequentially instead of letting them
> page in on demand, you'd cut boot time tremendously.
>> IIRC also the Amiga did not suffer from virtual lock up (nor do I
>> remember
>> it so badly from earlier version of MS-DOS).
> The Amiga didn't have demand paging, so you only suffered a long
> shut-down time when you had allocated a lot of small chunks of memory
> and needed to deallocate them before exiting. That happened on occasion.
That is true. And on many occasions it would still be sensible to load
no more than what you have as memory. At least I am normally only using
one large dataset at a time. Whenever it starts paging heavily I quit
anyway to rethink what I am doing.
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
Date: 13 Oct 2011 17:48:42
Message: <4e975cba$1@news.povray.org>
On 10/13/2011 12:55, andrel wrote:
> So that moves the question to: why is the ctrl-alt-del handler paged out?
How much of it do you want to keep in core? I've had very little trouble
getting the CAD handler to come up in things like Vista, but the next step
of picking something off the menu can cause a new program to get launched.
However, it launches task manager or some such in XP, I forget.
> And the UI: why has that to be on the GUI, with all the page faults that may
> result from swapping pixels to disk? Remember we are sending a low level
Well, yes. That gets handled right away, most likely. Then it has to *do*
something in response. I'm not sure what your point is. Your keystroke is of
course taken into the kernel pretty much immediately. It's the thing that
comes after I'm talking about.
The problem is not in the kernel's response. It's the fact that the
complaint is the task manager takes a long time to come up, preventing you
from killing the task.
In UNIX terms, it's like complaining that /bin/kill takes a long time to
load when the system is thrashing, and you asking why the kill() kernel trap
would be paged out in the first place.
No. Nor does that happen. Otherwise, disk seeks wouldn't continue to get in
the way?
   How come I never get only one kudo?
Date: 13 Oct 2011 18:15:03
Message: <4e9762e7@news.povray.org>
> remember it so badly from earlier version of MS-DOS).
IIRC, MS-DOS did not use paging nor virtual memory.
The main reason probably been that it was made to run on a computer
without any hard drive but just a single floppy or possibly two, at
least, initialy.
Some applications did implement some paging using internal or external
modules that where used only by a single application at a time.
Date: 13 Oct 2011 19:01:12
Message: <4e976db8@news.povray.org>
It also didn't have multi-tasking, so you didn't need to deallocate just
the
memory for the job that was exiting. You could just delete all the memory
allocated since the program started.
Date: 14 Oct 2011 12:28:58
Message: <4E98634F.50408@gmail.com>
To address most issues in one: you have normal operation in a system and
emergency situations. You should not design normal operations in such a
way that you can not handle emergencies.
What i'd do* is have the CAD handler (and a primitive task handler) in a
small space. Preferably in one self consistent page. Immediately suspend
all running user level programs and switch to vga to prevent the GUI
manager from page swapping.
*) at least without thinking all problems completely through.
> step of picking something off the menu can cause a new program to get
> launched. However, it launches task manager or some such in XP, I forget.
>> that may
> *do* something in response. I'm not sure what your point is. Your
> keystroke is of course taken into the kernel pretty much immediately.
> It's the thing that comes after I'm talking about.
> you from killing the task.
Because the task manager is implemented at the same priority level as
Blender?
> trap would be paged out in the first place.
Can that happen?
>> seek?
> in the way?
What apparently happens is that a program causes a page fault, possibly
holding up the kernel because it also needs a page. After the page is
loaded it then gets an opportunity to create another page fault before
the scheduler hands control back to the kernel.
My reaction as a user is: 'hello, I just pressed CAD, stop all other
programs and process that interrupt before doing anything else!'
Something is terribly wrong with the priorities of my machine.
citizen per day.
Date: 14 Oct 2011 13:09:03
Message: <4e986caf@news.povray.org>
> small space.
I think this is more like what post-XP OSes do.
> Immediately suspend all running user level programs
Always mount a scratch monkey.
You really don't want the guy at the keyboard hitting CAD and suspending
your corporate web server.
> and switch to vga to prevent the GUI manager
> from page swapping.
I don't think it goes that far, but certainly the newer CAD handlers could
do something like that, visually speaking.
> Because the task manager is implemented at the same priority level as Blender?
No it isn't. The problem isn't with the CPU. The problem is with the disk.
Now, the problem is that when the task manager pages in a page, now it's
going to run long enough for Blender to ask for a page. Now you've started a
disk seek, which you can't satisfy or abort before the task manager needs
its next page.
One simple solution might be to page in the entire task-manager task rather
than doing it on demand, but that's exactly the sort of "disk scheduling
sucks in modern desktop OSes" that I'm talking about.
> Can that happen?
No. That's my point. You're complaining CAD is unresponsive, when the
problem is that the user-level program you're trying to launch via CAD is
unresponsive.
The kernel doesn't need a page. That's why it's the kernel. The task manager
needs the page. The task manager is a user-level program.
Analogously, kill(1) doesn't need a page. But /bin/kill does, because it's a
user-level program, and it's the quickest way to actually invoke kill(1).
> After the page is loaded
> it then gets an opportunity to create another page fault before the
A page fault *is* handing control back to the kernel.
> programs and process that interrupt before doing anything else!' Something
Well, first, CAD is used for lots of stuff besides "I have too many page
faults". Second, you don't want anyone sitting at the keyboard to shut down
any process running on your machine. These *are* multi-user machines, you know.
Date: 14 Oct 2011 15:36:26
Message: <4E988F3D.5050500@gmail.com>
>> small space.
Nor do you want him to effectively freeze it for 10 minutes by doing
something stupid. See also below.
>> from page swapping.
> could do something like that, visually speaking.
>> Blender?
> disk.
IIRC you have said that before. Actually several times and I have never
contradicted you.
> now it's going to run long enough for Blender to ask for a page. Now
> you've started a disk seek, which you can't satisfy or abort before the
> task manager needs its next page.
> rather than doing it on demand, but that's exactly the sort of "disk
> scheduling sucks in modern desktop OSes" that I'm talking about.
>> Can that happen?
> is unresponsive.
Actually my point is that it *should not* be a user program.
> manager needs the page. The task manager is a user-level program.
> it's a user-level program, and it's the quickest way to actually invoke
> kill(1).
I know that (long, long time ago I studied OS's a bit). I obviously
meant the part of the kernel (and user level program in badly designed
systems) that handles the CAD.
>> Something
> down any process running on your machine. These *are* multi-user
> machines, you know.
I disagree, there is no other user on my machine than me*. And that is
also why your corporate webserver is a wrong example. webservers and
user machines are something different. You should not mix those. Or at
least the OS should behave different. Specifically in the area that we
are discussing. CAD on a webserver should leave everything running
(probably should even be disabled), but when I press CAD on my keyboard
because I want control, i *want control* and I know what other processes
I am also stopping.
*) that is at least my view of the machine. Technically it is not true.
citizen per day.
Date: 14 Oct 2011 19:02:44
Message: <4e98bf94@news.povray.org>
Agreed.
>>> Blender?
>> disk.
> contradicted you.
Well, sure. But the problem is that nobody implements effective disk
priorities any more (which is what I'm saying), so just saying "priority"
implies CPU priority.
That's likely true.  However, the frequency with which this happens probably
doesn't warrant a kernel mechanism for a UI for picking a task and killing
it, either. Especially since many times it happens, it's nothing to do with
a task that's still running that you could actually do anything about.
Indeed, it would seem what you'd really want is a way to indicate that if a
job got to the point where it was paging too often, that would be enough to
kill it or deprioritize its disk I/O, to the point of suspending it for a
second or more each time some other process went after the disk, sort of
like how Linux (seems to) does "low priority" disk I/O.
> I know that (long, long time ago I studied OS's a bit). I obviously meant
> the part of the kernel (and user level program in badly designed systems)
Oh, well, you want an entire process management system built into the
kernel, invocable by a simple keystroke. Probably not realistic in modern OSes.
> I disagree, there is no other user on my machine than me*. And that is also
> why your corporate webserver is a wrong example. webservers and user
If your corporate web server is thrashing, how are you going to stop it?
> OS should behave different. Specifically in the area that we are discussing.
> CAD on a webserver should leave everything running (probably should even be
> disabled), but when I press CAD on my keyboard because I want control, i
> *want control* and I know what other processes I am also stopping.
Well, as the Linux enthusiasts would say, "we eagerly await your patch." :-)
CAD should certainly not be disabled on a web server, as it does far more
than just bring up the task manager. That's the other half of the problem.
In pretty much every situation other than disk thrashing, CAD works pretty
much instantly. In many cases of disk thrashing, there's nothing you can do
about it, like my example of sync'ing gigabytes of changes to the disk. And
modern OSes are set up to treat file reading and page faulting as
essentially similar in many ways (and then there's memmap, which adds
another confusion on top), so it's not really even obvious when there's
thrashing which process is causing it or what to do about it, because it's
entirely possible there wouldn't be thrashing if there weren't 3 or 4
programs all doing something at once.
Well, that's kind of the point I'm making. :)
Date: 15 Oct 2011 05:08:11
Message: <4E994D80.2010705@gmail.com>
> probably doesn't warrant a kernel mechanism for a UI for picking a task
> and killing it, either. Especially since many times it happens, it's
> nothing to do with a task that's still running that you could actually
> do anything about.
> if a job got to the point where it was paging too often, that would be
> enough to kill it or deprioritize its disk I/O, to the point of
> suspending it for a second or more each time some other process went
> after the disk, sort of like how Linux (seems to) does "low priority"
> disk I/O.
> modern OSes.
Taking both points together. Breaking out to a program that just lets
you modify priorities would be enough. If that process runs at the
highest level itself it would solve most of the problems.
That said, windows does have a priority mechanism, and the taskmanager
is running at a high level, two levels higher than Blender and Matlab,
so why does it not work?
>> also
If it is because someone is using it for other things, like POVray,
Blender or a game fire that person. If it is because of tasks that
should run there fire the IT manager or the financial director,
depending on who was responsible for buying the wrong infrastructure.
>> discussing.
>> even be
Windows is open source now? I missed that.
> more than just bring up the task manager. That's the other half of the
> problem.
> pretty much instantly. In many cases of disk thrashing, there's nothing
> you can do about it, like my example of sync'ing gigabytes of changes to
> the disk. And modern OSes are set up to treat file reading and page
> faulting as essentially similar in many ways (and then there's memmap,
> which adds another confusion on top), so it's not really even obvious
> when there's thrashing which process is causing it or what to do about
> it, because it's entirely possible there wouldn't be thrashing if there
> weren't 3 or 4 programs all doing something at once.
citizen per day.
