POV-Ray : Newsgroups : povray.off-topic : Vampires? Server Time
17 Jun 2026 15:28:55 EDT (-0400)
  Vampires? (Message 71 to 80 of 100)
Subject: Re: Vampires?
Date: 17 Sep 2011 10:10:15
Message: <4e74aa47@news.povray.org>
On 9/16/2011 23:37, Warp wrote:
> Darren New<dne### [at] sanrrcom>  wrote:
>> It doesn't matter if it hits a measuring device. It only matters if you look
>> at the measurement.
>    And how does the particle know that the measurement was looked at?
Clearly individual particles don't "know" anything in the traditional sense.
I suspect if we knew *why* it worked that way, we'd be much closer to a GUT.
>    But that has nothing to do with whether someone "looked" at the measurement
> or not. It has to do with whether the two possible paths of the emitted
> particle were kept separate or whether they were merged before the particle
> hit the measurement device.
You misunderstand. The actual particle hitting the measurement device and
being checked for interference fringes is *not* the particle being measured.
*That* particle takes exactly the same path in both cases.
> If I understand correctly, the interference
> pattern would disappear if the emitted particles are kept separate even if
> nobody "looks" at the result. It has nothing to do with an observer, only
> with how the original particles and the emitted particles interact.
I'm not sure what the "emitted" particle is here.
The experiment says basically this:
1) Emit one particle.
2) Run it thru two slits.
3) Split it into an entangled pair, A and B.
4) Let A hit the detector that looks for interference.
5) Some time later, bounce B off a half-silvered mirror,
    such that if it goes through, you can tell what slit it came from,
    and if it doesn't, you can't tell which slit it came from.
The behavior of whether A creates an interference fringe is
determined by whether you can tell which slit B came through. You never need
to touch A, look at A, or figure out which slit A came through. Two "A"
photons will cause interference if they weren't in the machine at the same
time, as long as you don't look at two *other* photons *after* you've
already determined where the two "A" particles hit the screen. Indeed, you
could put the detectors for "B" so far from the experiment that thousands of
"A" particles could have gone through the machine and been detected one at a
time before you even look at the first "B" particle.
>    While at macroscopic levels it's hard to understand how particles affect
> each other from a significant distance (and even time) this way, it kind of
> makes sense, if you imagine that the particles are somehow "bound" together
> even though they are in their own separate paths: This way what happens to
> one particle affects what happens to the other. If the path of the
> "measurement" particle is merged, it affects the original particle (even
> through time, via some quantum oddity), and if it's not merged, it also
> likewise affects it.
Yes. Except that you can take the second measurement after the first
particle had already given you an answer. And it works even over time-like
distances (i.e., if the second detector is so far away that you'd need FTL
signals for it to affect the first detector), even if you discount the fact
that it's actually affecting stuff already measured.
>    However, what does not make sense even in this context is that the particle
> somehow "knows" whether someone "looked" or not.
Nope, that doesn't really make sense. :-) Even the multi-worlds
interpretation of it doesn't make sense, if you actually think about it with
common sense.
   How come I never get only one kudo?
Date: 17 Sep 2011 12:44:39
Message: <4e74ce76@news.povray.org>
  No I don't. When I say "emitted particle" I'm talking about the secondary
particle emitted at the slit towards the measurement device that (possibly)
tells which slit the original particle went through.
  It's particle B in your list. If the two possible paths that B could take
are merged, the interference pattern appears, but if they are not merged,
the interference pattern disappears. This regardless of whether someone
"looks" at the result of B or not.
  Clearly what happens to B's path affects A (even if this effect happens
through space and time). It's not dependent on whether someone "looks" at
it.
Date: 17 Sep 2011 12:58:42
Message: <4e74d1c2$1@news.povray.org>
On 9/16/2011 3:07 PM, Darren New wrote:
> On 9/16/2011 14:11, Warp wrote:
>> Now, how does the football (or atom, or particle) "know" that what those
>> emitted particles hit is not "measurement"?
> Well, that is indeed the fundamental problem exposed by Schrodinger's cat.
>> measurement device that can tell the difference?
> look at the measurement.
No, no, no.
Observer in the case of quantum mechanics is not a "person" looking at
the thing, its "any object/particle that interacts, to take a
measurement." Whether or not something living looks at the result is
*not* what produces the effect. Geeze, if that interpretation where
true, then quantum effects would never have happened *at all* for
billions of years prior to the formation of life. *Any* interaction
"measures" the state of the particle *period*. Schrodinger's cat is just
a goofy anthropomorphizing of the process, which a lot of people,
including apparently people on here, get wrong, because people see
"observer" and assume that has to be "person", or something that
otherwise thinks. That is just plain wrong.
Date: 17 Sep 2011 13:13:43
Message: <4e74d547@news.povray.org>
  Clearly the cat is a good measurement device for whether the poison was
released or not. That's not the point. The point is whether the cat is
dead or alive from outside of the box.
Date: 18 Sep 2011 04:02:53
Message: <4e75a5ad$1@news.povray.org>
Sigh. Outside doesn't matter. The cat is a hypothetical. Just because
"you" don't know the state, until you open the box, doesn't mean it
hasn't collapsed, if you are dealing with a literal cat. But that isn't
what is intended here. The cat is the state itself, in the thought
experiment, so whether it is one or the other *requires* an outside
influence. A real cat would already invalidate the experiment, as would
anything else you might use, like a sheet of radiation sensitive
material, where you want to "observe" if the material decayed yet, or
not. It happens, in such cases, whether you open the box now, or 4
million years from now. That you don't know what happened isn't relevant.
But, if you are talking about the cat as a "state", and the observation
as checking to see if the state changed, the situation is, in principle,
valid. But, you have to make everything hypothetical to have it mean
anything. Did the laser fire (the poison release)? Did it emit a
particle in the right direction (no leaks in the box)? Did that particle
split as intended (the cat breathed it, maybe it was a really short
lived poison)? When it did, what happened to the pair you are testing
(was the cat effected)? The cat is just one of the cogs in the system.
Assuming event #1 happened, as planned, something happens in the rest of
the system, whether you did anything yourself or not. The *real* trick
is the fact that you can create conditions where you "know" what the
outcome will be, instead of just looking into the box to find out.
Normally, you can't, because all the stuff going on happens "in the box".
Date: 18 Sep 2011 12:22:40
Message: <4e761ad0@news.povray.org>
easurement
ed
rticle
and
sured.
ndary
bly)
Ah. With that clarification in mind... The interference pattern disappear
s
if you don't actually look at the "emitted" particle at all. If you let t
he
emitted particle hit the detector, then you don't use that detector's
results, you get no interference pattern - you get just a level output.
That's what this paragraph means:
Note that the total pattern of all signal photons at D0, whose entangled
idlers went to multiple different detectors, will never show interference
regardless of what happens to the idler photons.[3] One can get an idea o
f
how this works by looking carefully at both the graph of the subset of
signal photons whose idlers went to detector D1 (fig. 3 in the paper[1])
and
the graph of the subset of signal photons whose idlers went to detector D
2
(fig. 4), and observing that the peaks of the first interference pattern
line up with the troughs of the second and vice versa (noted in the paper
 as
'a π phase shift between the two interference fringes'), so that the
 sum of
the two will not show interference.
In this particular experimental setup, if you don't look at which detecto
r
it hit, you can't tell because you can't separate out the inteference fro
m
it's half-phase-shifted brother.
en if
only
 take
d,
In this experiment at least, you *have* to look at B in order to determin
e
which category A falls into. If you don't look at B at all, you don't get
interference fringes, or more precisely, you get two sets of interference
fringes that are half a fringe offset.
ens
at
> it.
In this case, not *quite*, I think. (Again, you're skirting the edges of
my
understanding... :-)  There have been other experiments proposed (by
Wheeler, for example) that don't involve a second entangled photon at all
but are hard to set up because you need devices that are light-seconds lo
ng
to make them work. :-)
Date: 18 Sep 2011 12:25:21
Message: <4e761b71$1@news.povray.org>
On 9/17/2011 9:58, Patrick Elliott wrote:
> Observer in the case of quantum mechanics is not a "person" looking at the
> thing, its "any object/particle that interacts, to take a measurement."
Nope.  Contradicted by experimental evidence. Go read the other branch of
the thread, and read the quantum erasure articles.
> Whether or not something living looks at the result is *not* what produces
> the effect. Geeze, if that interpretation where true, then quantum effects
> would never have happened *at all* for billions of years prior to the
> formation of life.
No, quantum *collapse* wouldn't have happened. :-)
> *Any* interaction "measures" the state of the particle
> *period*.
Again, this is contradicted by experimental evidence.
Unless you have something else to point to, that shows where an experiment
where the scientists took a measurement but then didn't look at it still
caused the collapse?
Date: 18 Sep 2011 12:27:32
Message: <4e761bf4$1@news.povray.org>
On 9/18/2011 1:02, Patrick Elliott wrote:
> The *real* trick is the fact that you can create conditions
> where you "know" what the outcome will be, instead of just looking into the
> box to find out.
That's exactly what the quantum eraser does, and if you don't look at the
result, you don't get interference. That's precisely the point I'm making.
You get interference at time T by taking a measurement at time T+D, where D
is a timelike separation from T.
Date: 18 Sep 2011 12:37:05
Message: <4e761e31@news.povray.org>
> In this case, not *quite*, I think. (Again, you're skirting the edges of my
> Wheeler, for example) that don't involve a second entangled photon at all,
> but are hard to set up because you need devices that are light-seconds long
  Btw, I don't understand why the double slit experiment cannot be used to
send information faster than c.
  Suppose you set up the delayed-choice experiment on orbit around Alpha
Centauri such that you simply shoot a beam of light towards the slits,
behind which there's a detector surface which can be used to see if there's
an interference pattern or not. Then you put the photon splitters at the
slits and send the secondary light particles created this way towards Earth.
  On earth we receive these two secondary beams, and here we make a delayed
choice of whether to merge them or not before measurement. If we merge them,
then the interference pattern appears at Alpha Centauri, and if we don't
merge them (but measure which slit the photons went through) the interference
pattern disappears. This way we can send binary data from Earth to Alpha
centauri: To send a 0 we eg. merge the paths, and to send a 1 we don't.
The guys at Alpha Centauri can then read this info by seeing when the
interference pattern appears and when it doesn't.
  Since the particles are entangled, this happens without any delay.
(The secondary beams my take 4 light years to arrive here, but once they
do, we can send data back immediately, without another 4 ly delay. If the
streams are kept constantly on, after the initial 4 ly delay information
can be send continuously from Earth to Alpha Centauri with zero delay.)
  But apparently this is not possible. Why not?
Date: 18 Sep 2011 13:57:04
Message: <4e7630f0$1@news.povray.org>
> pattern disappears.
Except you can't tell, in the case of this specific experiment, which
electrons are part of the interference pattern and which electrons are part
of the non-interference pattern until after you've detected the "B" idler
photons. You're going to get all the photons, and what you have to do to get
the interference pattern is to ignore the photons where I erased the
information about my half of the experiment. Remember that you don't get an
interference pattern from just one particle. You get an interference pattern
statistically, when you let lots of particles build up. There's no way to
look at one individual particle and say "is that part of an interference
pattern?"
The way the particular experiment on the wiki page is described, 1/4th the
particles randomly create an interference pattern, 1/4th randomly create an
interference pattern offset 1/2 a fringe from the first one, and 1/2 of the
particles create no interference pattern. But you don't know which group
each particle is in until you look at the idler "B" emitted photon to see
which way it went.  If you *influence* the emitted particle, you break the
entanglement, and now you have results uncorrelated with the emitted
particle, which (I think) means you'll get an interference fringe from the
"A" particles because you erased what would let you distinguish them.
It's the same as a simpler question: Why can't I send any information at all
over a quantum channel? Any experiment you concoct to measure a quantum
property one way or the other to communicate is going to run up against the
fact that the property you're measuring is influenced by the property you
aren't measuring.
Let's say I decide to measure polarization, diagonal for 1,
horizontal/vertical for 0. I send you half an entangled stream, then measure
diagonal polarization or H/V polarization for each bit. The problem is that
if you measure the H/V polarization when I measure the diagonal
polarization, you just get random nonsense. You already have to know which
polarization I'm going to measure in order to measure the same polarization.
And if we both measure the same polarization, we'll get the same answers,
but the answers will be a random stream of bits.
Or, for a super-simple analogy, let's say I have a glass table. You can see
the underside of the glass table instantly, no matter where you are. So you
go far away, and I stand next to the glass table. However, the only thing
you can see through the glass of the table is a coin I have flipped.
So if I flip a coin and it lands heads up, I know instantly that you
instantly saw the tails side of the coin. If it lands tails up, I know
instantly that you know instantly that it landed heads up. That's FTL.
Now, what can we do with that data? Not much. It's a random stream of bits
over which I have no control. If I set the coin down in a specific way, you
can't see it. I know you saw the compliment of what I saw, but I have no way
to influence that. If I try to influence it, the whole process collapses and
you can no longer see the results from far away.
That's why, if you look at quantum cryptography, the quantum part of the
process is used to generate a OTP, then to ensure the OTP hasn't been
intercepted by someone else. But the actual communication, including the
part where you ensure the OTP hasn't been intercepted, happens over normal
non-quantum channels.
