POV-Ray : Newsgroups : povray.off-topic : Memories Server Time
4 Jul 2026 08:03:59 EDT (-0400)
  Memories (Message 31 to 40 of 94)
Subject: Re: Memories
Date: 20 Aug 2011 08:26:52
Message: <4e4fa80c$1@news.povray.org>
>> The circle is the locus of all points equidistant from the centre. It's
>> not especially hard to do that with simple integer arithmetic.
>    Doing it *fast* is not all that trivial.
>    Also, don't confuse the length of the implementation with its complexity.
> A fast circle drawing algorithm using integer math only (and only additions
> and subtractions at that, no multiplications or divisions) is a relatively
> short algorithm in terms of lines of code, but *understanding* it is a bit
> more difficult. (Coming up with it on your own is even more difficult, but
> not impossible, if you think about it long enough.)
Our graphics lecturer asserted that it's a minor modification of
Bresenham's algorithm, and Wikipedia concurs. It would take a while with
pencil and paper to figure out the math, and there's probably a few
tricky special cases, but it doesn't look intractible.
http://blog.orphi.me.uk/
Date: 20 Aug 2011 08:30:37
Message: <4e4fa8ed$1@news.povray.org>
>> Seriously. If you know how it works, do you really need to do it 200
>> times over just to *prove* that you know how it works?
> Wrong, it's not to prove that it works. It is to drum into your "thick
> little head" how to do it with out thinking. Compare it to repeating a
> dance step until your body does not think of the individual moves. Then
> you can build on it.
Doing arithmetic "without thinking" is how we ended up with Verizon Math
Fail.
>> It's not even
>> like it's particularly important to be able to *do* long division; it
>> isn't something you're going to need to do every day of your adult life.
> You don't know how to do mental arithmetic, then?
Nobody ever needs to compute the exact quotient of two 4-figure numbers
mentally. It's not necessary. You just need to be able to estimate the
answer with sufficient accuracy. (Something which apparently a great
many people can't do for some reason...)
>> Once you've got that, practising it on endless question sheets is just
>> an utter waste of time.
> It is if you don't want to be numerate.
Practising something you're going to need to do every single day of your
life is worth while. Practising something which you will never, ever
need to actually do is pointless.
Nobody computes 6-figure quotients mentally. Nobody needs to.
> And BTW adding, subtracting, dividing and multiplying is arithmetic not maths.
...which was the entire point of my rant, yes. Our "maths" class covered
*only* arithmetic, and nothing else.
Date: 20 Aug 2011 08:40:32
Message: <4e4fab40@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
> In the simple case of lines beginning and ending on pixel boundaries,
> it's pretty easy.
  How so?
  Ok, maybe if you assume each pixel to be a circle (instead of a square)
it would become simply calculating the distance between the (edge of the)
line and the center of the pixel. That might work as a quite accurate
approximation.
  However, since pixels are squares, not circles, and if you want a very
accurate antialiasing, you would have to calculate how much of the square
is covered by the line. I'm not aware of a very trivial way of doing that.
(I'm not saying it's *complicated*. I'm saying it's *not trivial*, like
eg. a simple one-liner.)
> On the other hand, if you want lines that begin and end at fractional
> coordinates, or have rounded ends or whatever, the problem becames far
> more complicated.
  The ends of the line, especially if the line is wider than one pixel
(and especially if you use antialiasing) become a quite ambiguous problem.
Should the line be essentially a rectangle? Or two circles joined by a
rectangle? What if you draw two consecutive lines, what should the joint
point look like?
Date: 20 Aug 2011 09:10:37
Message: <4e4fb24d$1@news.povray.org>
Suppose, for argument's sake, that your line is nearly horizontal.
Assume also that pixels are square, and the line is exactly 1 pixel thick.
Now for every pixel that the line intersects, the edge of the line cuts
the pixel into two regions: an "inside" and an "outside" region. In the
simplest case, we want the darkness of the pixel to be proportional to
the area that is "inside".
(In more advanced applications, people sometimes use more complicated
methods that take into account the actual real-world fuzziness of the
pixels and so forth. That obviously complicates things drastically.)
Bresenham's algorithm would draw a horizontal line by iterating over all
the X-coordinates and tracking, for each one, the fractional Y
coordinate of the center of the line. (But represented in integral
form.) In the standard Bresenham's algorithm, this fractional-Y is
simply rounded to the nearest integral-Y, and that is what is plotted.
Let us assume that integral coordinates correspond to the centers of
pixels (rather than one of their corners or something). In that case,
the fractional-Y is the Y value of the line at the center of a column of
pixels.
The slanted area cut by the line actually has the same area as a
rectangle with the same center hieght. (This is why the trapezoidal rule
for numerical integration works.)
Hence, for every X-value, we colour floor(Y) according to floor(Y) - Y,
and ceiling(Y) according to ceiling(Y) - Y (which, you'll notice, is
equal to 1 - floor(Y) - Y). This trivial piece of math gives us
antialisaing almost "for free".
>> more complicated.
> point look like?
Most real drawing systems let you select the kind of end-caps and join
styles you want, and so forth. Implementing this properly is highly
non-trivial, I would expect.
A more "interesting" problem is what happens when multiple
different-coloured lines overlap...
Date: 20 Aug 2011 09:39:01
Message: <4e4fb8f5$1@news.povray.org>
> Fail.
Straw man, straw man.
True.
Again true.
Well it surprises me that you never need to calculate something when you
are away from some form of calculator.
True.
>> not maths.
> ....which was the entire point of my rant, yes. Our "maths" class
> covered *only* arithmetic, and nothing else.
You have said before that your school was not a particularly good one.
But then I was taught arithmetic in primary school and we did not
progress to mathematics until secondary school.
Regards
Date: 20 Aug 2011 10:43:27
Message: <4e4fc80f$1@news.povray.org>
On 8/20/2011 4:11, Warp wrote:
>    Drawing an accurate antialiased line (of certain width) is not a trivial
> problem. Basically for each pixel you need to calculate how much of it is
> covered by the line. Doing this accurately with integer math only can be
> complicated.
I am not sure you can do it accurately with integer math at all, given that
there's a "portion of a pixel" involved in there somewhere. At best you'd be
working in scaled fixed-point.
That said, the AA equivalent of bressenham is Wu:
https://secure.wikimedia.org/wikipedia/en/wiki/Xiaolin_Wu%27s_line_algorithm
   How come I never get only one kudo?
Date: 20 Aug 2011 10:56:27
Message: <4e4fcb1b$1@news.povray.org>
On 8/20/2011 2:45, Orchid XP v8 wrote:
>>> OK. Is that for legacy reasons, or because ATM is actually good at
>>> something?
>> ATM is a lot less legacy than IP is. Yes, of course it's actually good
>> at something.
> Well, you know, RS232 is a pretty sucky design. But it's still here. That
> *isn't* because it's good at anything. It's because it's widely implemented,
> i.e. legacy.
>>> "Yeah, IP really sucks, except for being really flexible." Yes, because
>>> flexibility is a really sucky thing to have.
>> I didn't say that. I said it sacrifices other things in preference to
>> being flexible. There's no resource allocation. There's no way to force
>> a particular route thru the network (well, there is, but nobody actually
>> implemented it in their switches), the addressing sucks for large
>> networks, the address space (in IPv4 at least) is exceedingly limited,
>> remote management of hardware is extremely limited, there's no access
>> control, admission control, or decent rate regulation other than
>> actually dropping packets, etc etc etc.
> Most of this sounds like "IP is sucky for managing network hardware". Well,
> no, that's not what IP is for. It's deliberately hardware-neutral.
Well, yes, that's what I said. IP really sucks, except for being
hardware-neutral. You didn't seem to understand what I was saying before I
gave the list of many things IP sucks at.
Oh, and it also sucks at things like bandwidth allocation, sophisticated
routing, and isochronous connections, so it's not just the management part
that sucks.
 > The idea
> is that you have some infrastructure for controlling your hardware, and then
> run IP on the top. IP is for moving data from A to B.
IP is for moving data from one port on your network to the next port on your
network, as long as you don't care how long that takes or how quickly it
gets there.
There's no reservation, no connection control, no access control, and no
routing control. Even if the hardware fails, you have no way of determining
how to route around that failure efficiently and promptly.
> If you asked me what was "sucky" about IP, the one I'd probably pick is that
> the entire design philosophy fundamentally assumes that everybody will
> follow the rules.
That too. But tell me how you tell whether the reason you lost your
connection is whether the remote machine went down, or just some router in
the middle is rebooting? Tell me how to ask, in IP, whether there's enough
bandwidth to carry your 64Kbps conversation in each direction with a maximum
of 85ms delay in each direction. OK, I'm going to start displaying a digital
movie from the producer to a theater for the next two hours seven minutes:
How do I pick a route that guarantees me enough bandwidth that the audience
doesn't see stutters?
You're looking at the things IP does well, and saying "well, it's a bit
limited here and there." You're not even looking at the stuff that ATM or
SONET does that IP is never even asked to do.
>> Heck, it doesn't even do roaming, which cell phones have been managing
>> for 10 years.
> Cell phones do that by being controlled by a single central authority.
If they were controlled by a single central authority, you wouldn't need
roaming agreements, now would you?
>> See above. Every packet has the full source and destination address, and
>> there's no information anywhere about the physical network.
> Ooo, 64 bits, bit deal.
Well, yes, when you're transporting voice packets a couple dozen bytes long,
96+ bits of routing information is indeed a big deal.
> It sounds like you're basically complaining that IP isn't
> connection-oriented.
That's one of its failings, yes.
 > You know, if what you're trying to do isn't
> connection-oriented, that's an advantage, right?
Yep. How much of your networking isn't connection oriented? Here's a hint:
all networking is connection oriented. IP layers non-connection-oriented
networking on top of that, and then layers TCP to turn it back into
connection-oriented, poorly. If IP wasn't connection oriented, you wouldn't
need routing tables on each machine.
> I'm unfamiliar with the data protocols that enable this to be possible. (I
> was under the impression that everybody runs their voice data over IP now
> anyway, so they only need to maintain one big IP network for their voice
> services *and* their broadband offerings...)
In the last mile, that might be true. I'm fairly sure it isn't IP that's
running on the undersea fibers or bouncing off satellites.  Know how I know?
There aren't enough IP addresses.
Date: 20 Aug 2011 10:58:26
Message: <4e4fcb92$1@news.povray.org>
On 8/20/2011 3:49, Orchid XP v8 wrote:
> Seriously though. I was awful at maths when I was at school. Then again,
> when I was at school, "maths" consisted of doing endless arithmetic.
We did that in second grade. What "school" were you in when you were doing this?
> Can you imagine anything more MIND-NUMBINGLY BORING than staring at a sheet
> of 40 long division problems? YES, I GET IT! I KNOW HOW LONG DIVISION WORKS!
> STOP BUGGING ME ALREADY! >_<
You realize that most people aren't that smart, right?  I always got crap in
school for only doing one homework problem of each type, and then I'd say
"No, I get it, OK."  And everyone would make fun of me, and then I'd be the
only one to ace the test.
Date: 20 Aug 2011 14:05:10
Message: <4e4ff756@news.povray.org>
> doing this?
Admittedly it was a school for mentally retarded people such as myself...
>> sheet
>> WORKS!
Pro tip: If I can answer 20 long-division questions correctly, I can
probably answer 2,000 long-division question correctly. It'll just take
me 100 times longer. :-P Thus, there's no real point to actually
*making* me answer 2,000 questions...
> I always got crap
> in school for only doing one homework problem of each type, and then I'd
> say "No, I get it, OK." And everyone would make fun of me, and then I'd
> be the only one to ace the test.
I was just having a chuckle about my science teacher whining about how I
"don't apply myself" in class. His final comment was "more effort
required". I notice he was the only teacher who forgot to actually fill
out the performance ratings in the school report. MORE EFFORT REQUIRED! :-P
This amuses me, of course, because I got a B grade for my science, a
grade which is apparently unprecedented in the history of the school.
Yeah, I really need to "apply myself" more. :-P Self-important idiot of
a teacher...
Date: 20 Aug 2011 14:55:57
Message: <4e50033d@news.povray.org>
  That takes care of the situation where the edge of the line crosses the
opposite sides of the pixel. However, you have to take into account
separately the cases where the edge crosses two adjacent sides of the pixel
(in which case the cross-section is a triangle rather than a trapezoid).
And of course the triangle can be either the inside or the outside of the
line, so that has to be taken into account.
  Then there's the special case where *both* edges of the line cross the
*same* pixel. This can happen even if the line width is that of one pixel,
when the line crosses the pixel diagonally (but can also more obviously
happen when the width of the line is less than a pixel). In this case you
have to calculate the area covered by one edge, then the area *not* covered
by the other and subtract them.
  So no, you don't get it "almost for free". Not if you want a high degree
of accuracy.
  What's the problem in that? Just draw them one at a time (taking the
transparency of the antialiased pixels into account).
